TIM4的PD12,PD13,PD14输出不了PWM
699|0
 楼主| 向日葵的武士 发表于 2018-6-30 19:06 | 显示全部楼层 |阅读模式
pd, PWM, TI, ST, ni
#include "bsp_pwm_output.h"
1号舵机 PD12
2号舵机 PD13
3号舵机 PD14
static void TIM4_GPIO_Config(void)
        /* 设置TIM3CLK 为 72MHZ */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_12 | GPIO_Pin_13| GPIO_Pin_14;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
static void TIM4_Mode_Config(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_TimeBaseStructure.TIM_Period = 19999;
  TIM_TimeBaseStructure.TIM_Prescaler = 71;            //设置预分频:不预分频,即为72MHz
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;        //设置时钟分频系数:不分频(这里用不到)
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上计数模式
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
void Steering_1(int a)
   TIM_OCInitTypeDef  TIM_OCInitStructure;
   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;            //配置为PWM模式1
   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
   TIM_OCInitStructure.TIM_Pulse = a;           //设置跳变值,当计数器计数到这个值时,电平发生跳变
   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //当定时器计数值小于CCR1_Val时为高电平
   TIM_OC1Init(TIM4, &TIM_OCInitStructure);         //使能通道1
   TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
   TIM_Cmd(TIM4, ENABLE);
void Steering_2(int b)
  TIM_OCInitStructure.TIM_Pulse =b;          //设置通道2的电平跳变值,输出另外一个占空比的PWM
  TIM_OC2Init(TIM4, &TIM_OCInitStructure);          //使能通道2
  TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);
void Steering_3(int c)
  TIM_OCInitStructure.TIM_Pulse =c;        //设置通道3的电平跳变值,输出另外一个占空比的PWM
  TIM_OC3Init(TIM4, &TIM_OCInitStructure);         //使能通道3
  TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);
void TIM4_PWM_Init(void)
TIM4_GPIO_Config();
TIM4_Mode_Config();
