关于FMC的CLK不输出的问题
516|0
 楼主| 奔跑的猫ちゃん 发表于 2018-7-7 07:10 | 显示全部楼层 |阅读模式
fm, pi, GPIO, IO, gp
因为项目需要,想用FMC的同步模式来进行Arm与FPGA之间的通讯,但是例化之后,FMC_CLK没有时钟输出,看了手册,FMC_CLK是由AHB3外设时钟来的,程序里面已经使能了,PD3按照手册初始化为推挽输出。但PD3并不输出时钟,没搞明白,,
void HAL_SDRAM_MspInit(SDRAM_HandleTypeDef *hsdram)
    GPIO_InitTypeDef GPIO_Initure;
        __HAL_RCC_SYSCFG_CLK_ENABLE();                                //使能SYSCFG时钟
    __HAL_RCC_FMC_CLK_ENABLE();                 //使能FMC时钟
    __HAL_RCC_GPIOC_CLK_ENABLE();               //使能GPIOC时钟
    __HAL_RCC_GPIOD_CLK_ENABLE();               //使能GPIOD时钟
    __HAL_RCC_GPIOE_CLK_ENABLE();               //使能GPIOE时钟
    __HAL_RCC_GPIOF_CLK_ENABLE();               //使能GPIOF时钟
    __HAL_RCC_GPIOG_CLK_ENABLE();               //使能GPIOG时钟
        //PC2,3引脚模拟开关关闭!!!!!
//        HAL_SYSCFG_AnalogSwitchConfig(SYSCFG_SWITCH_PC2,SYSCFG_SWITCH_PC2_CLOSE);
//        HAL_SYSCFG_AnalogSwitchConfig(SYSCFG_SWITCH_PC3,SYSCFG_SWITCH_PC3_CLOSE);
    //初始化PC0,2,3
    GPIO_Initure.Pin=GPIO_PIN_0|GPIO_PIN_2|GPIO_PIN_3;
    GPIO_Initure.Mode=GPIO_MODE_AF_PP;          //推挽复用
    GPIO_Initure.Pull=GPIO_PULLUP;              //上拉
    GPIO_Initure.Speed=GPIO_SPEED_FREQ_VERY_HIGH;         //高速
    GPIO_Initure.Alternate=GPIO_AF12_FMC;       //复用为FMC
    HAL_GPIO_Init(GPIOC,&GPIO_Initure);         //初始化
    GPIO_Initure.Pin=GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_3|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_14|GPIO_PIN_15; //PD3 FMC_CLK
    HAL_GPIO_Init(GPIOD,&GPIO_Initure); //初始化PD0,1,8,9,10,14,15
    GPIO_Initure.Pin=GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
    HAL_GPIO_Init(GPIOE,&GPIO_Initure); //初始化PE0,1,7,8,9,10,11,12,13,14,15
    GPIO_Initure.Pin=GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
    HAL_GPIO_Init(GPIOF,&GPIO_Initure); //初始化PF0,1,2,3,4,5,11,12,13,14,15
    GPIO_Initure.Pin=GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_8|GPIO_PIN_15;
    HAL_GPIO_Init(GPIOG,&GPIO_Initure);        //初始化PG0,1,2,4,5,8,15
