[其他ST产品] [欧比特测控]stm32mp157的边缘计算控制器
1203|0
 楼主| wenming 发表于 2020-6-30 18:54 | 显示全部楼层 |阅读模式
Hybrid is a configurable, manageable, and scalable edge computing platform for industrial IoT applications with wide connectivity choices of Ethernet,4G/LTE, CAN-FD, and LoRaWAN.
EdgeBox-Hybrid, a bridge between the field network bus and the cloud,it is an open source software based on solution for smart homes, buildings automation and industry.As field devices they are performing cyclic IO data exchange with the PLC and communicate furthermore with IoT capable field devices directly at the same time. These exchanged field data build the basis for intelligent cloud applications of control systems and M2M solutions.
The devices are designed for continuous operations in environments with permanent intranet or internet connection. Security mechanisms such as physical separation of the automation and IT network, a secure operating system, the execution of signed firmware and packets only are securing the data integrity and encryption techniques of the latest standards protecting against data theft. The gateways base function builds a IDE. It serves to model the data flow in the devices.
User apps and data profiles are created in minutes with predefined function blocks. OPC UA and MQTT functions address objects in IoT field devices or in the cloud over standardized IoT protocols. With software package of OpenEmbed service the base function can be advanced by further applications or communication profiles to specific clouds.
Features:
  • ST STM32MP157  SOC
  • State-of-the-art Aluminium chassis for Harsh environment
  • Integrated passive heatsink
  • Built-in mini PCIe socket with  USB,SPI,and UART support
  • SMA antenna holes x2
  • Modbus over RS485 or Ethernet support
  • Gigabyte ethernet for uplink to cloud and fast ethernet for field bus
  • CAN-FD inteface up to 5 Mbit/s for distributed I/O or motion control
  • Encryption chip ATECC608A
  • Hardware Watchdog
  • RTC with Super Capacitor
  • Wide power supply from 10.8 to 36V DC
  • 35mm DIN Rail support
CPU
  • ST STM32MP157  running at  800 MHz
Memory
  • 1 GB DDR3
  • 16 MB SPI FLASH
  • 8 GB eMMC
Interfaces
  • 1 × RJ45 ethernet port support 10/100M/1000M
  • 2 × USB host ports
  • 2 × solated CAN bus ports with CAN-FD support
  • 1 x Isolated RS485
  • 1 x RS232
  • 1 x mini-PCIe socket with sim card and mini-PCIe support
  • 2 x antennas for wireless add-on card
  • 2 x dual color LED indicators
  • 10.8-36V DC power supply
Misc
  • RTC with super capacitance
  • Encryp unit
  • Hardware watch dog timer
Dimensions
  • 124x68x35 mm
Software
  • Open source linux OS
  • C/C++,Golang SDK
  • Modbus tcp and Modbus RTU
  • MQTT
Complicances
CE and FCC  under processing
个人签名:嵌入式Linux工业控制板,提供ODM与OEM,只做批量,不卖开发板! 欧比特测控   www.OpenEmbed.com
108
