SPI配置问题
705|0
 楼主| 香菇选手 发表于 2018-7-15 12:22 | 显示全部楼层 |阅读模式
spi, IO, GPIO, gp, ni
目前在做AD采样,用STM32F407操作ADS8684芯片。
按照ADS8684的时序图我配置了STM32,使用SPI2,PB12为SPI2_CS,PB13为SPI2_SCK,PC2为SIP2_MISO,PC2为SIP2_MOSI。
[mw_shl_code=c,true]//以下是SPI模块的初始化代码,配置成主机模式
//SPI口初始化
//这里针是对SPI1的初始化
void SPI2_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  SPI_InitTypeDef  SPI_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOB时钟
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);//使能GPIOC时钟
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);//使能SPI1时钟
  //GPIOB12
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;//PB12
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//输出
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化
  //GPIOFB13初始化设置
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;//PB13复用功能输出
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
  //GPIOFC2,3初始化设置
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;//PC2 PC3复用功能输出
  GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化
  PBout(12)=1;
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource13,GPIO_AF_SPI2); //PB3复用为 SPI1
        GPIO_PinAFConfig(GPIOC,GPIO_PinSource2, GPIO_AF_SPI2); //PB3复用为 SPI1
        GPIO_PinAFConfig(GPIOC,GPIO_PinSource3, GPIO_AF_SPI2); //PB3复用为 SPI1
        //这里只针对SPI口初始化
        RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2,ENABLE);//复位SPI2
        RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2,DISABLE);//停止复位SPI2
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //设置SPI工作模式:设置为主SPI
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;                //设置SPI的数据大小:SPI发送接收16位帧结构
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;                //串行同步时钟的空闲状态为高电平
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;        //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;                //定义波特率预分频的值:波特率预分频值为256
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
        SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值计算的多项式
        SPI_Init(SPI2, &SPI_InitStructure);  //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
        SPI_Cmd(SPI2, ENABLE); //使能SPI外设
        SPI2_ReadWriteByte(0xff);//启动传输
}   [/mw_shl_code]
SPI通信没有正常工作,请问是中间哪里没有配置对吗?
