F405RG用cube配置can2一直进不了接收中断但能发(can1也配置了能发能收)!
343|0
 楼主| 张さん 发表于 2018-7-27 19:06 | 显示全部楼层 |阅读模式
CAN, ni, pi, IO, rc
最近用cube配置can通信can2一直进不了接收中断can1的功能完好,很烦不知道哪里有错,上网查了很多资料也没有解决,希望这里的大神能帮我解决这个问题,拜谢!下面附上源码。
static CanTxMsgTypeDef     Tx1Message;
static CanRxMsgTypeDef     Rx1Message;
static CanTxMsgTypeDef     Tx2Message;
static CanRxMsgTypeDef     Rx2Message;
u8 canbuf[8];
/* USER CODE END 0 */
CAN_HandleTypeDef hcan1;
CAN_HandleTypeDef hcan2;
/* CAN1 init function */
void MX_CAN1_Init(void)
  hcan1.Instance = CAN1;
    hcan1.pTxMsg=&Tx1Message;
    hcan1.pRxMsg=&Rx1Message;
  hcan1.Init.Prescaler = 3;
  hcan1.Init.Mode = CAN_MODE_LOOPBACK;
  hcan1.Init.SJW = CAN_SJW_1TQ;
  hcan1.Init.BS1 = CAN_BS1_7TQ;
  hcan1.Init.BS2 = CAN_BS2_6TQ;
  hcan1.Init.TTCM = DISABLE;
  hcan1.Init.ABOM = ENABLE;
  hcan1.Init.AWUM = DISABLE;
  hcan1.Init.NART = DISABLE;
  hcan1.Init.RFLM = DISABLE;
  hcan1.Init.TXFP = ENABLE;
  HAL_CAN_Init(&hcan1);
/* CAN2 init function */
void MX_CAN2_Init(void)
  hcan2.Instance = CAN2;
    hcan2.pTxMsg=&Tx2Message;
    hcan2.pRxMsg=&Rx2Message;
  hcan2.Init.Prescaler = 3;
  hcan2.Init.Mode = CAN_MODE_LOOPBACK;
  hcan2.Init.SJW = CAN_SJW_1TQ;
  hcan2.Init.BS1 = CAN_BS1_7TQ;
  hcan2.Init.BS2 = CAN_BS2_6TQ;
  hcan2.Init.TTCM = DISABLE;
  hcan2.Init.ABOM = ENABLE;
  hcan2.Init.AWUM = DISABLE;
  hcan2.Init.NART = DISABLE;
  hcan2.Init.RFLM = DISABLE;
  hcan2.Init.TXFP = ENABLE;
  HAL_CAN_Init(&hcan2);
static int CAN1_CLK_ENABLED=0;
void HAL_CAN_MspInit(CAN_HandleTypeDef* hcan)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(hcan->Instance==CAN1)
  /* USER CODE BEGIN CAN1_MspInit 0 */
        __HAL_RCC_GPIOA_CLK_ENABLE();
  /* USER CODE END CAN1_MspInit 0 */
    /* Peripheral clock enable */
    CAN1_CLK_ENABLED++;
    if(CAN1_CLK_ENABLED==1){
      __CAN1_CLK_ENABLE();
    /**CAN1 GPIO Configuration
    PA11     ------> CAN1_RX
    PA12     ------> CAN1_TX
    GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF9_CAN1;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    /* Peripheral interrupt init*/
    HAL_NVIC_SetPriority(CAN1_RX0_IRQn, 1, 2);
    HAL_NVIC_EnableIRQ(CAN1_RX0_IRQn);
  /* USER CODE BEGIN CAN1_MspInit 1 */
        CAN_FilterConfTypeDef  CAN1_FilerConf;
        CAN1_FilerConf.FilterIdHigh=0X0000;
        CAN1_FilerConf.FilterIdLow=0X0000;
        CAN1_FilerConf.FilterMaskIdHigh=0X0000;
        CAN1_FilerConf.FilterMaskIdLow=0X0000;
        CAN1_FilerConf.FilterFIFOAssignment=CAN_FILTER_FIFO0;
        CAN1_FilerConf.FilterNumber=0;
        CAN1_FilerConf.FilterMode=CAN_FILTERMODE_IDMASK;
        CAN1_FilerConf.FilterScale=CAN_FILTERSCALE_32BIT;
        CAN1_FilerConf.FilterActivation=ENABLE;
        CAN1_FilerConf.BankNumber=14;
        HAL_CAN_ConfigFilter(&hcan1,&CAN1_FilerConf);
        __HAL_CAN_ENABLE_IT(&hcan1,CAN_IT_FMP0);
  /* USER CODE END CAN1_MspInit 1 */
  else if(hcan->Instance==CAN2)
  /* USER CODE BEGIN CAN2_MspInit 0 */
  /* USER CODE END CAN2_MspInit 0 */
    __CAN2_CLK_ENABLE();
    CAN1_CLK_ENABLED++;
    /**CAN2 GPIO Configuration
    PB12     ------> CAN2_RX
    PB13     ------> CAN2_TX
    GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13;
    GPIO_InitStruct.Alternate = GPIO_AF9_CAN2;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    HAL_NVIC_SetPriority(CAN2_RX0_IRQn, 1, 1);
    HAL_NVIC_EnableIRQ(CAN2_RX0_IRQn);
  /* USER CODE BEGIN CAN2_MspInit 1 */
        CAN_FilterConfTypeDef  CAN2_FilerConf;
        CAN2_FilerConf.FilterIdHigh=0X0000;
        CAN2_FilerConf.FilterIdLow=0X0000;
        CAN2_FilerConf.FilterMaskIdHigh=0X0000;
        CAN2_FilerConf.FilterMaskIdLow=0X0000;
        CAN2_FilerConf.FilterFIFOAssignment=CAN_FILTER_FIFO1;
        CAN2_FilerConf.FilterNumber=14;
        CAN2_FilerConf.FilterMode=CAN_FILTERMODE_IDMASK;
        CAN2_FilerConf.FilterScale=CAN_FILTERSCALE_32BIT;
        CAN2_FilerConf.FilterActivation=ENABLE;
        CAN2_FilerConf.BankNumber=14;
        HAL_CAN_ConfigFilter(&hcan2,&CAN2_FilerConf);
        __HAL_CAN_ENABLE_IT(&hcan2,CAN_IT_FMP1);
  /* USER CODE END CAN2_MspInit 1 */
void HAL_CAN_MspDeInit(CAN_HandleTypeDef* hcan)
  /* USER CODE BEGIN CAN1_MspDeInit 0 */
  /* USER CODE END CAN1_MspDeInit 0 */
    /* Peripheral clock disable */
    CAN1_CLK_ENABLED--;
    if(CAN1_CLK_ENABLED==0){
      __CAN1_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_11|GPIO_PIN_12);
    /* Peripheral interrupt Deinit*/
    HAL_NVIC_DisableIRQ(CAN1_RX0_IRQn);
  /* USER CODE BEGIN CAN1_MspDeInit 1 */
  /* USER CODE END CAN1_MspDeInit 1 */
  /* USER CODE BEGIN CAN2_MspDeInit 0 */
  /* USER CODE END CAN2_MspDeInit 0 */
    __CAN2_CLK_DISABLE();
    CAN1_CLK_ENABLED--;
    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_12|GPIO_PIN_13);
    HAL_NVIC_DisableIRQ(CAN2_RX0_IRQn);
  /* USER CODE BEGIN CAN2_MspDeInit 1 */
  /* USER CODE END CAN2_MspDeInit 1 */
