定时器失能后 还会输出高电平????
360|0
过期账户|  楼主 | 2018-7-27 20:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
探索者开发板 通过L298N控制二驱小车前进   倒退  停止  ,用三个按键控制,问题是前进或者倒退的时候按停止键 偶尔会出现停不下来,这时候感觉定时器输出PWM通道一直为1了所以反而停不下来
不知道什么原因,麻烦各位大神 分析一下哪里有BUG
int main (void)
        u8 key;
        delay_init(168);
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        LED_INIT();
        KEY_init();
        tim4_init(5000-1,8399);
        while(1)
                                 key=KEY_Scan();
                                if(key)
                                                switch(key)
        case 1: //正转
        TIM_Cmd(TIM4,ENABLE);
        GPIO_SetBits(GPIOF, GPIO_Pin_3);
        GPIO_ResetBits(GPIOF, GPIO_Pin_4);
        GPIO_SetBits(GPIOF, GPIO_Pin_5);
        GPIO_ResetBits(GPIOF, GPIO_Pin_6);
        break;
        case 2://反转
        GPIO_ResetBits(GPIOF, GPIO_Pin_3);
        GPIO_SetBits(GPIOF, GPIO_Pin_4);
        GPIO_ResetBits(GPIOF, GPIO_Pin_5);
        GPIO_SetBits(GPIOF, GPIO_Pin_6);
        break;
        case 3:        //停止
        TIM_Cmd(TIM4,DISABLE);
        GPIO_ResetBits(GPIOB,GPIO_Pin_6|GPIO_Pin_7 );
        break;
#include "LED.h"
#include "stm32f4xx.h"
void LED_INIT(void)
        GPIO_InitTypeDef GPIO_InitStrue;
  GPIO_InitTypeDef  GPIO_InitStru;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF|RCC_AHB1Periph_GPIOB,ENABLE);
        GPIO_InitStrue.GPIO_Mode=GPIO_Mode_OUT;
        GPIO_InitStrue.GPIO_OType=GPIO_OType_PP;
        GPIO_InitStrue.GPIO_Pin=GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStrue.GPIO_PuPd=GPIO_PuPd_DOWN;
        GPIO_InitStrue.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOB,&GPIO_InitStrue);
        GPIO_InitStru.GPIO_Mode=GPIO_Mode_OUT;
        GPIO_InitStru.GPIO_OType=GPIO_OType_PP;
        GPIO_InitStru.GPIO_Pin=GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6;
        GPIO_InitStru.GPIO_PuPd=GPIO_PuPd_DOWN;
        GPIO_InitStru.GPIO_Speed=GPIO_Speed_100MHz;
        GPIO_Init(GPIOF,&GPIO_InitStru);
        GPIO_ResetBits(GPIOF,GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6 );
#include "timer.h"
#include "sys.h"
void tim4_init(u16 arr,u16 psc)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruc;
        TIM_OCInitTypeDef  TIM_OCInitStructR;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE);
        GPIO_InitStrue.GPIO_Mode=GPIO_Mode_AF;
        GPIO_InitStrue.GPIO_PuPd= GPIO_PuPd_DOWN;
        GPIO_InitStrue.GPIO_Speed=GPIO_Speed_100MHz;
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource6,GPIO_AF_TIM4);
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource7,GPIO_AF_TIM4);
        TIM_TimeBaseInitStruc.TIM_Period=arr;
        TIM_TimeBaseInitStruc.TIM_Prescaler=psc;
        TIM_TimeBaseInitStruc.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInitStruc.TIM_CounterMode=TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM4,&TIM_TimeBaseInitStruc);
        TIM_OCInitStructR.TIM_OCMode=TIM_OCMode_PWM1;
        TIM_OCInitStructR.TIM_OCPolarity=TIM_OCPolarity_Low;
        TIM_OCInitStructR.TIM_OutputState=TIM_OutputState_Enable;
        TIM_OCInitStructR.TIM_Pulse=3500;
        TIM_OC1Init(TIM4,&TIM_OCInitStructR);
        TIM_OC2Init(TIM4,&TIM_OCInitStructR);
#include "KEY.h"
#include "sys.h"
#include "delay.h"
#include "timer.h"
#include "LED.h"
void KEY_init(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE,ENABLE);
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4|GPIO_Pin_3|GPIO_Pin_2;
        GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_UP;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;
        GPIO_Init(GPIOE,&GPIO_InitStructure);
u8 KEY_Scan(void)
        static u8 key_up=1;
        if(key_up&&(KEY0==0||KEY1==1||KEY2==0))
                                delay_ms(10);
                                key_up=0;
                                if(KEY0==0)return 1;
                                else if(KEY1==0) return 2;
                          else if(KEY2==0)return 3;
        else if(KEY0==1&&KEY1==1&&KEY2==1)key_up=1;
        return 0;
