STM32F407主频超到536M是的问题?
447|0
 楼主| 石头张 发表于 2018-7-29 16:28 | 显示全部楼层 |阅读模式
用STM32F407的定时器3定时500ms,在定时器3中断服务程序中,让IO口状态反转,通过示波器来测试定时器的定时时间是否准确。发现在程序中设置定时500ms,结构示波器显示1.29us,于是调用 RCC_GetClocksFreq()函数查看系统主频,发现主频是536M多。不知道什么原因?大家帮忙看看,下面是我的代码:
void GPIO_Config(void)
        GPIO_InitTypeDef GPIO_InitStructure ;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOI|RCC_AHB1Periph_GPIOF|RCC_AHB1Periph_GPIOC,ENABLE);
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10|GPIO_Pin_8;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOI,&GPIO_InitStructure);
RCC_ClocksTypeDef* RCC_Clocks;
int main(void)
        GPIO_Config();
        bsp_Time3_Init(5000-1,8400-1);//定时500ms
        while(1)
                RCC_GetClocksFreq(RCC_Clocks);
void bsp_Time3_Init(uint32_t arr,uint32_t psc)
        /*定义定时器结构体*/
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        /*使能定时器的时钟*/
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
        /*参数设置*/
        TIM_TimeBaseInitStructure.TIM_Period = arr; //设置自动重载计数周期值
        TIM_TimeBaseInitStructure.TIM_Prescaler = psc; //设置分频系数
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up; //向上计数模式
        TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1; //设置时钟分频因子
        TIM_TimeBaseInitStructure.TIM_RepetitionCounter = 0x0000;                /* TIM1 和 TIM8 必须设置 */
        /*初始化定时器结构体*/
        TIM_TimeBaseInit(TIM3,&TIM_TimeBaseInitStructure);
        /*配置定时器3中断*/
        Time3_NVIC_Configuration();
        /*允许定时器更新中断*/
        TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
        TIM_ARRPreloadConfig(TIM3, ENABLE);
        /*定时器使能*/
        TIM_Cmd(TIM3,ENABLE);
uint8_t ledflag2=0;
void TIM3_IRQHandler(void)
        if(TIM_GetITStatus(TIM3,TIM_IT_Update) != RESET)
                 ledflag2 = ~ledflag2;
                 if(ledflag2 ==0x00)
                    GPIOI->BSRRL = GPIO_Pin_8;
                 else
                    GPIOI->BSRRH = GPIO_Pin_8;
        /*清除中断表示位*/
        TIM_ClearITPendingBit(TIM3,TIM_FLAG_Break);
调试结果如下:
主频 :536887720
定时时间:1.27us
