F4的4.3寸触摸屏实验
345|0
 楼主| kaloulin 发表于 2018-7-29 21:24 | 显示全部楼层 |阅读模式
我的4.3寸触摸屏按照教程一步一步进行移植的,为何在测试如下函数时,可以显示字符,但点击屏幕时,不会有任何反应?这是为何呢?(以下是从segger官网下载来的测试程序),
实在是找不出其他的原因了,所以希望各位大神给点思路...
void MainTask(void) {
        GUI_PID_STATE TouchState;
        int xPhys;
        int yPhys;
        GUI_Init();
        // // Check if recommended memory for the sample is available //
        if (GUI_ALLOC_GetNumFreeBytes() < RECOMMENDED_MEMORY) {
                GUI_ErrorOut("Not enough memory available.");
                return;
        GUI_CURSOR_Show();
        GUI_CURSOR_Select(&GUI_CursorCrossL);
        GUI_SetBkColor(GUI_WHITE);
        GUI_SetColor(GUI_BLACK);
        GUI_Clear();
        GUI_DispString("Measurement of
A/D converter values");
         while (1) {
                GUI_TOUCH_GetState(&TouchState); // Get the touch position in pixel
                xPhys = GUI_TOUCH_GetxPhys(); // Get the A/D mesurement result in x
                yPhys = GUI_TOUCH_GetyPhys(); // Get the A/D mesurement result in y //
                // Display the measurement result //
                GUI_SetColor(GUI_BLUE);
                GUI_DispStringAt("Analog input:
", 0, 20);
                GUI_GotoY(GUI_GetDispPosY() + 2);
                GUI_DispString("x:");
                GUI_DispDec(xPhys, 4);
                GUI_DispString(", y:");
                GUI_DispDec(yPhys, 4); // // Display the according position //
                GUI_SetColor(GUI_RED);
                GUI_GotoY(GUI_GetDispPosY() + 4);
                GUI_DispString("
Position:
                GUI_DispDec(TouchState.x,4);
                GUI_DispDec(TouchState.y,4); // // Wait a while //
                GUI_Delay(100);
