[DemoCode下载]
NUC029开发板测试PWM
721|8
捉虫天师|  楼主 | 2020-7-22 09:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 2 $
* $Date: 16/10/25 4:29p $
* @brief
*           Change duty cycle of output waveform by configured period.
* @note
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC029xGE.h"
/* Macro, type and constant definitions        */
#define PLL_CLOCK       144000000
/* Global variables        */
uint32_t CalNewDutyCMR(PWM_T *pwm, uint32_t u32ChannelNum, uint32_t u32DutyCycle, uint32_t u32CycleResolution);
* [url=home.php?mod=space&uid=247401]@brief[/url]       PWM0 IRQ Handler
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     ISR to handle PWM0 interrupt event
void PWM0_IRQHandler(void)
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
// CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HXT, CLK_CLKDIV0_HCLK(1));
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Waiting for PLL clock ready */
    CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
    /* Enable PWM0 module clock */
    CLK_EnableModuleClock(PWM0_MODULE);
    /* PWM clock frequency configuration        */
    /* Select HCLK clock source as PLL and and HCLK clock divider as 2 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL, CLK_CLKDIV0_HCLK(2));
    /* PWM clock frequency can be set equal or double to HCLK by choosing case 1 or case 2 */
    /* case 1.PWM clock frequency is set equal to HCLK: select PWM module clock source as PCLK */
    CLK_SetModuleClock(PWM0_MODULE, CLK_CLKSEL1_PWM0SEL_PCLK0, NULL);
    /* case 2.PWM clock frequency is set double to HCLK: select PWM module clock source as PLL */
    //CLK_SetModuleClock(PWM0_MODULE, CLK_CLKSEL1_PWM0SEL_PLL, NULL);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Reset PWM0 module */
    SYS_ResetModule(PWM0_RST);
    /* Update System Core Clock */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set multi-function pins for UART0 RXD and TXD */
    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
    /* Set PC multi-function pins for PWM0 Channel0~3 */
    SYS->GPC_MFPL = (SYS->GPC_MFPL & ~(SYS_GPC_MFPL_PC0MFP_Msk | SYS_GPC_MFPL_PC1MFP_Msk | SYS_GPC_MFPL_PC2MFP_Msk | SYS_GPC_MFPL_PC3MFP_Msk)) | \
                    (SYS_GPC_MFPL_PC0MFP_PWM0_CH0 | SYS_GPC_MFPL_PC1MFP_PWM0_CH1 | SYS_GPC_MFPL_PC2MFP_PWM0_CH2 | SYS_GPC_MFPL_PC3MFP_PWM0_CH3);
void UART0_Init()
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
* @brief       Calculate the comparator value of new duty by configured period
* @param       pwm                  The pointer of the specified PWM module
* @param       u32ChannelNum        PWM channel number. Valid values are between 0~5
* @param       u32DutyCycle         Target generator duty cycle percentage. Valid range are between 0 ~ u32CycleResolution.
*                                   If u32CycleResolution is 100, and u32DutyCycle is 10 means 10%, 20 means 20% ...
* @param       u32CycleResolution   Target generator duty cycle resolution. The value in general is 100.
* @return      The compatator value by new duty cycle
    return (u32DutyCycle * (PWM_GET_CNR(pwm, u32ChannelNum) + 1) / u32CycleResolution);
/*  Main Function        */
int32_t main(void)
    uint8_t  u8Option;
    uint32_t u32NewDutyCycle = 0, u32NewCMR = 0;
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART to 115200-8n1 for print message */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz(PLL@ %dHz)\n", SystemCoreClock, PllClock);
    printf("PWM0 clock is from %s\n", (CLK->CLKSEL1 & CLK_CLKSEL1_PWM0SEL_Msk) ? "CPU" : "PLL");
    printf("+-----------------------------------------------------------------------------------+\n");
    printf("|                          PWM Driver Sample Code                                   |\n");
    printf("|        |\n");
    printf("  This sample code will use PWM0 channel 0 to output waveform, and switch duty cycle.\n");
    printf("  I/O configuration:\n");
    printf("    waveform output pin: PWM0 channel 0(PC.0)\n");
    printf("\nOutput waveform is 1800Hz and it's duty is 50%.\n");
      Configure PWM0 channel 0 init period and duty(up counter type).
      Period is PLL / (prescaler * (CNR + 1))
      Duty ratio = (CMR) / (CNR + 1)
      Period = 72 MHz / (2 * (19 + 1)) = 1800000 Hz
      Duty ratio = (100) / (19 + 1) = 50%
    /* PWM0 channel 0 frequency is 1800Hz, duty 50%, */
    PWM_ConfigOutputChannel(PWM0, 0, 1800, 50);
    /* Enable output of PWM0 channel 0 */
    PWM_EnableOutput(PWM0, PWM_CH_0_MASK);
    /* Start PWM counter */
    PWM_Start(PWM0, PWM_CH_0_MASK);
    while(1)
        printf("\nSelect new duty: \n");
        printf("[1] 100%% \n");
        printf("[2] 75%% \n");
        printf("[3] 25%% \n");
        printf("[4] 0%% \n");
        printf("[Other] Exit \n");
        u8Option = getchar();
        if(u8Option == '1')
            u32NewDutyCycle = 100;
        else if(u8Option == '2')
            u32NewDutyCycle = 75;
        else if(u8Option == '3')
            u32NewDutyCycle = 25;
        else if(u8Option == '4')
            u32NewDutyCycle = 0;
        else
            printf("Exit\n");
            break;
        /* Get new comparator value by call CalNewDutyCMR() */
        u32NewCMR = CalNewDutyCMR(PWM0, 0, u32NewDutyCycle, 100);
        /* Set new comparator value to register */
        PWM_SET_CMR(PWM0, 0, u32NewCMR);
    /* Stop PWM counter */
    PWM_Stop(PWM0, PWM_CH_0_MASK);
    /* Disable output of PWM0 channel 0 */
    PWM_DisableOutput(PWM0, PWM_CH_0_MASK);
    while(1);
还是非常OK的,就是不知道这个里面注释的名字什么鬼,跟实际没关系。
实际上是PWM_DutySwitch这个的。
mintspring| | 2020-7-22 22:35 | 只看该作者
收到板子了?
幸福小强| | 2020-7-23 17:43 | 只看该作者
多谢分享。
玛尼玛尼哄| | 2020-7-23 21:32 | 只看该作者
感觉好多地方可以用到。
小灵通2018| | 2020-7-25 11:44 | 只看该作者
非常赞。
jiekou001| | 2020-7-25 13:23 | 只看该作者
029马上要火。
xinpian101| | 2020-7-26 21:13 | 只看该作者
这个好玩。
xinpian101| | 2020-7-26 21:14 | 只看该作者
准备将这个类似的移植到ML51开发板试试。
