[VHDL] 一个数组赋值给另外一个数组
 楼主| 仪器设备 发表于 2020-7-23 08:33 | 显示全部楼层 |阅读模式
亲,VHDL ,  我定义了2个数组, 现在将数组B赋值给数组A,
TYPE DATA_SS IS ARRAY(0 TO 79) OF std_logic_vector(11 downto 0);
signal temp_data : DATA_SS;
TYPE DATA_SSS IS ARRAY(0 TO 9) OF std_logic_vector(11 downto 0);
signal ch1_s : DATA_SSS;
  temp_data( 0 to  9) <= ch1_s(0 to 9);
编译时出错,Error (10381): VHDL Type Mismatch error at AA.vhd(329): indexed name returns a value whose type does not match "DATA_SS", the type of the target expression
有好的赋值方法吗? 单独一个一个的赋值是没有问题的,但太麻烦
正点原子FPGA 发表于 2020-7-23 09:09 | 显示全部楼层
帮顶
ucx 发表于 2020-8-1 09:53 | 显示全部楼层
        type Anx12B                is array(natural range <>) of std_logic_vector(11 downto 0);
        subtype DATA_SS                is Anx12B(0 to 79);
        subtype DATA_SSS                is  Anx12B(0 to 9);
这个就不用解释了吧?
