[单片机资料]
CS5212AN DP转VGA方案/ CS5212AN代理商
668|0
一、 CS5212AN功能概述
CS5212是一款DisplayPort端口到VGA转换器,它结合了DisplayPort输入接口和模拟RGB DAC输出接口。嵌入式单片机基于工业标准8051核心。
CS5212适用于多个细分市场和显示器应用程序,如笔记本电脑、主板、台式机、适配器、转换器和转接器。
图1-1 CS5212方框图
二、 CS5212AN特性
总则
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg       2-lane通道VESA DisplayPort v1.1兼容接收机
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg      VGA输出接口,DAC速度高达210MHz,8位
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg      分辨率高达1920x1200x60(RB,缩小消隐),24位色深,1920x1440x60(RB,缩小消隐),或2048x152x60(RB,缩小消隐),24位色深,2048x1536x60(RB,缩小消隐),18位色深。
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       内置振荡器,不需要外部晶体
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       嵌入式线性压降调节器(LDO)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       嵌入式微控制器
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       嵌入式EDID(如果终端设备没有,CS5212将响应EDID)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       嵌入式V-sync/H-sync 5V缓冲器
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       使用内部预吹ROM支持EEPROM自定义模式
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       内部电源复位(POR)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       QFN32 4x4封装
DisplayPort数字输入
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       支持2通道数字输入,速度为RBR(1.62-Gbps)/HBR(2.7-Gbps)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       符合VESA DisplayPort v1.1
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       内置高性能自适应均衡器
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       支持1-MHz AUX channel
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       支持HPD
VGA输出接口
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       z三重8位DAC(数模转换器),时钟高达210 MHz
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       支持高达1920x1200x60、1920x1440x60(缩小消隐)、2048x152x60(缩小消隐)和2048x1536x60(缩小消隐)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       用于VGA连接器引脚的HBM 4-KV
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg       VESA VSIS v1r2兼容
内置MCU控制器
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg       业标准8051芯
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg       支持I2C主从,支持400kHz。
电力与技术
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg       3.3V电源
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg       V-sync/H-sync 5V缓冲器的5V选项
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg       超低待机功率<100uW
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg       所有引脚的HBM 8-KV
安格瑞是台湾瑞奇达Capstone的代理商,专注于CS5212AN, 瑞奇达CS5212AN ,CS5212AN代理商, |DPVGAic| DPVGA ic方案,若您需要CS5212AN, 瑞奇达CS5212AN中文规格书 , CS5212AN样品样片, CS5212AN设计资料, CS5212Demo,欢迎联系瑞奇达瑞代理商400-880-5552,也可与本站在线客服联系
三、 CS5212AN引脚定义
1、CS5212AN引脚分配
2管脚说明
表3-1 CS5212引脚定义
CS5212引脚定义详情请联系台湾瑞奇达Capstone的代理商,CS5212AN代理商安格瑞,也可与本站在线客服联系
四、 CS5212AN接口和能力
DisplayPort 显示端口输入
作为标准的DisplayPort接收机,CS5212由两个通道的主链路差分对、一个辅助信道差分对和一个HPD信号组成。
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg       主要环节
双通道差分对,能够操作HBR(2.7-Gbps)和RBR(1.62-高清晰度未压缩视频的数据速率变速器主链路完全符合DisplayPortv1.1规范。
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image014.jpg  AUX Channel频道
用于显示端口源设备和接收器设备之间的边带通信的差分半双工双向信道。这个这条链路的带宽高达1Mbps。
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpg     热插拔检测(HPD)
HPD信号完全符合DisplayPortv1.1。这包括所有输入电压要求和热插拔和IRQ_HPD事件的生成。
1.1        模拟VGA输出
CS5212集成了三个8bit-210MHz-DAC(数模转换器),每个DAC分配给每个颜色,R(红色)、G(绿色)和B(蓝色)。CS5212的模拟VGA接口符合VESA VSIS v1r2。真实的-CS5212还集成了时间热插拔检测机制.
CS5212支持的视频格式如下表2所示。但是,CS5212支持的格式不限于此表。这些格式的数据传输带宽较低CS5212还可以支持比2通道DisplayPortHBR主链路的带宽和(b)比DAC速度210 MHz慢的像素频率。
CS5212支持的分辨率,请联系台湾瑞奇达Capstone的代理商,CS5212AN代理商安格瑞400-880-5552,也可与本站在线客服联系
操作条件
表5-2正常工作条件(请联系台湾瑞奇达Capstone的代理商,CS5212AN代理商安格瑞)
1.1        电气规范
表5-3直流电气规范(请联系台湾瑞奇达Capstone的代理商,CS5212AN代理商安格瑞)
表5-4交流电气规范(请联系台湾瑞奇达Capstone的代理商,CS5212AN代理商安格瑞)
1.2        CS5212功耗
不同的应用会导致CS5212。例如,是否采用嵌入式振荡器,视频时钟频率的快慢,都是影响功率的关键因素CS5212的消耗量。下表显示了CS5212在几种不同应用条件下的参考功耗
表5-5CS5212典型功耗(请联系台湾瑞奇达Capstone的代理商,CS5212AN代理商安格瑞)
六、 CS5212AN包装规格
插入CS5212封装外形(QFN32引线4x4mm2)
图6-1CS5212封装外形(QFN32引线4x4mm2)
