- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x.h"
- #include "stmflash.h"
- #include <stdlib.h>
- #include <stdio.h>
- #include <string.h>
- #include "bsp_GPIO.h"
- char led[96]={0xff,0x02,0x03,0x00,0x02,0x03,0xff,0x02,0x03,0xff,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0xff,0x02,0x03,0x00,0x02,0x03,0xff,0x02,0x03,0xff,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0xff,0x02,0x03,0x00,0x02,0x03,0xff,0x02,0x03,0xff,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0xff,0x02,0x03,0x00,0x02,0x03,0xff,0x02,0x03,0xff,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03,0x01,0x02,0x03};
- char onePix[3]={0xff,0x00,0xf00};
- int i,j,k,l,m;
- int main(void)
-         for(i=0;i<96;i++)
-                 led[i]=0x00;
-         GPIO_Config();
-         while (1)
-                 for(i=0;i<1000;i++)
-                         for(j=0;j<200;j++);
-                 l++;
-                 if(l==4)l=0;
-                 for(i=0;i<96;)
-                         led[i++]=0x02;
-                         led[i++]=0x02;
-                         led[i++]=0x02;
-                 for(k=0;k<8;k++)
-                         if((m>=0)&&(m<100))
-                                 led[(k*12)+((l)*3)]=0xff;
-                         if((m>=100)&&(m<200))
-                                 led[(k*12)+(l*3)+1]=0xff;
-                         if((m>=200)&&(m<300))
-                                 led[(k*12)+(l*3)+2]=0xff;
-                         if((m>=300)&&(m<400))
-                         if((m>=400)&&(m<500))
-                         if((m>=500)&&(m<600))
-                         if((m>=600)&&(m<700))
-                 SendOneFrame(led);
-                 m++;
-                 m++;
-                 m++;
-                 m++;
-                 m++;
-                 if(m>700)m=0;
-       END FILE
-   * [url=home.php?mod=space&uid=247401]@brief[/url]  初始化控制LED的IO
-   * @param  无
-   * @retval 无
- void GPIO_Config(void)
-         GPIO_InitTypeDef GPIO_InitStructure;
-         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
-         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
-         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
-         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
-         GPIO_Init(GPIOB, &GPIO_InitStructure);
- void ResetDataFlow(void)
-         unsigned int i,j;
-         GPIO_WriteBit(GPIOB, GPIO_Pin_10, 0);
-         for(i=0;i<600;i++)                //此处33Mhz时延时65us
-                 //for(j=0;j<10;j++);
- //子程序名称:SendOnePix(unsigned char *ptr)
- //功能:发送一个像素点的24bit数据
- //参数:接收的参数是一个指针,此函数会将此指针指向的地址的连续的三个Byte的数据发送
- //说明:在主函数中直接调用此函数时,在整个帧发送开始前需要先执行 ResetDataFlow()
- //                数据是按归零码的方式发送,速率为800KBPS
- void SendOnePix(unsigned char *ptr)
-         unsigned char i,j,k,l;
-         unsigned char temp;
-         for(j=0;j<3;j++)
-                 temp=ptr[j];
-                 for(i=0;i<8;i++)
-                         if(temp&0x80)                 //从高位开始发送
-                                 //GPIO_WriteBit(GPIOB, GPIO_Pin_10, 1);                         //发送“1”码
-                                 GPIOB->BSRR = GPIO_Pin_10;
-                                 for(k=0;k<4;k++)                //此处33Mhz时延时65us
-                                         //for(l=0;l<10;l++);
-                                 GPIOB->BRR = GPIO_Pin_10;
-                                 for(k=0;k<1;k++)                //此处33Mhz时延时65us
-                         else                                //发送“0”码
-                         temp=(temp<<1);                 //左移位
- //子程序名称:SendOneFrame(unsigned char *ptr)
- //功能:发送一帧数据(即发送整个数组的数据)
- //参数:接收的参数是一个指针,此函数会将此指针指向的地址的整个数组的数据发送
- void SendOneFrame(unsigned char *ptr)
-         unsigned char k;
-         ResetDataFlow();                                 //发送帧复位信号
-         for(k=0;k<SNUM;k++)                                 //发送一帧数据,SNUM是板子LED的个数
-                 SendOnePix(&ptr[(3*k)]);
- //子程序名称:SendSameColor(unsigned char *ptr,unsigned char cnt)
- //功能:相同颜色的点发送cnt次
- //参数:接收的参数是一个指针,指向像素点颜色数组,cnt传递发送个数
- void SendSameColor(unsigned char *ptr,unsigned char cnt)
-         unsigned char k;
-         for(k=0;k<cnt;k++)                                 //发送一帧数据,SNUM是板子LED的个数
-                 SendOnePix(&ptr[0]);
- //子程序名称:SendOneFrameFrom(unsigned char i,unsigned char *ptr)
- //功能:从指定的像素点开始发送一帧数据(即发送整个数组的数据)
- //参数:接收的参数是一个指针,此函数会将此指针指向的地址的整帧数据发送
- //                i:把数组的第0个像素数据发送到第i个像素点(第0个像素是板上标号为01的像素)
- //说明:即原本对应第一个像素的数据会发送到第i个像素点(LED)上
- void SendOneFrameFrom(unsigned char i,unsigned char *ptr)
-         unsigned char k;
-            for(k=(SNUM-i);k<SNUM;k++)                 //发送一帧数据
-         for(k=0;k<(SNUM-i);k++)
- //子程序名称:SendOneFrameSince(unsigned char i,unsigned char *ptr)
- //功能:从第i个像素点的数据开始发送一帧数据(即发送整个数组的数据)
- //                i:把数组的第i个像素数据发送到第1个像素点
- //说明:即原本对应第i像素的数据会发送到第1个像素点(LED)上,第i+1个像素点的数据
- //                发送到第2个像素上
- void SendOneFrameSince(unsigned char i,unsigned char *ptr)
-         unsigned char k;
-         for(k=i;k<SNUM;k++)                                 //发送一帧数据
-         for(k=0;k<i;k++)
- /*********************************************END OF FILE**********************/
