- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.0
- * $Revision: 3 $
- * $Date: 17/05/04 1:15p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Perform A/D Conversion with ADC single cycle scan mode.
- * @note
- * Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NUC029xGE.h"
- #define PLL_CLOCK 72000000
- /* Define Function Prototypes */
- void SYS_Init(void);
- void UART0_Init(void);
- void AdcVBG(void);
- /* Init System Clock */
- /* Enable HIRC clock (Internal RC 22.1184MHz) */
- CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
- /* Waiting for HIRC clock ready */
- CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
- /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Enable HXT clock (external XTAL 12MHz) */
- CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
- /* Waiting for HXT clock ready */
- CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Waiting for PLL clock ready */
- CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Enable ADC module clock */
- CLK_EnableModuleClock(ADC_MODULE);
- /* Select UART module clock source as HXT and UART module clock divider as 1 */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
- /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
- CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADCSEL_HIRC, CLK_CLKDIV0_ADC(7));
- /* Init I/O Multi-function */
- /* Set multi-function pins for UART0 RXD and TXD */
- SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
- SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
- /* Init UART */
- void UART0_Init()
- /* Reset IP */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* Function: AdcSingleCycleScanModeTest */
- /* Parameters: */
- /* None. */
- /* Returns: */
- /* None. */
- /* Description: */
- /* ADC single cycle scan mode test. */
- void AdcVBG()
- int32_t i32ConversionData;
- printf("\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| ADC VBG |\n");
- while(1)
- printf("\n\nSelect input mode:\n");
- printf(" [1] Single end input (channel 29 VBG)\n");
- /* Set the ADC operation mode as single-cycle, input mode as single-end and
- enable the analog input channel 29 */
- ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE_CYCLE, BIT29);
- /* Power on ADC module */
- ADC_POWER_ON(ADC);
- /* Clear the A/D interrupt flag for safe */
- ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
- /* Start A/D conversion */
- ADC_START_CONV(ADC);
- /* Wait conversion done */
- while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT)){}
- i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 29);
- printf("VBG Conversion result of channel %d: 0x%X (%d)\n", 29, i32ConversionData, i32ConversionData);
- printf("\n--按任意键进入下一次测试--\n");
- getchar();
- /* MAIN function */
- int main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- /* SAMPLE CODE */
- printf("\nSystem clock rate: %d Hz", SystemCoreClock);
- /* Single cycle scan mode test */
- AdcVBG();
- /* Disable ADC module */
- ADC_Close(ADC);
- /* Disable ADC IP clock */
- CLK_DisableModuleClock(ADC_MODULE);
- /* Disable External Interrupt */
- NVIC_DisableIRQ(ADC_IRQn);
- printf("\nExit ADC sample code\n");
- while(1);
- /*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
根据这个结果测量VBG=1642,而12位的ADC满量程为4095
根据比例可以求出VCC=4095*1.21/1642=3.0176V
完全符合实际。
