SD卡初始化问题
292|0
SD卡, ni, DM, ck, AN
SD开在初始化的时候进行了如下设置
  uSdHandle.Instance = SDMMC1;
  uSdHandle.Init.ClockDiv            = 2;
  uSdHandle.Init.ClockPowerSave      = SDMMC_CLOCK_POWER_SAVE_DISABLE;
  uSdHandle.Init.ClockEdge           = SDMMC_CLOCK_EDGE_RISING;
  uSdHandle.Init.HardwareFlowControl = SDMMC_HARDWARE_FLOW_CONTROL_DISABLE;
  uSdHandle.Init.BusWide             = SDMMC_BUS_WIDE_4B;复制代码然后调用了
if(HAL_SD_Init(&uSdHandle) != HAL_OK)复制代码继续调用
  /* Initialize the Card parameters */
  if (HAL_SD_InitCard(hsd) != HAL_OK)复制代码在HAL_SD_InitCard中对最前面的结构体成员又进行了一次赋值
HAL_StatusTypeDef HAL_SD_InitCard(SD_HandleTypeDef *hsd)
  uint32_t errorstate;
  HAL_StatusTypeDef status;
  SD_InitTypeDef Init;
  /* Default SDMMC peripheral configuration for SD card initialization */
  Init.BusWide             = SDMMC_BUS_WIDE_1B;
  Init.ClockDiv            = SDMMC_INIT_CLK_DIV;复制代码
请问这里如何理解。
