STM32H7的HAL库串口中断服务程序里面的串口FIFO发送空中断处理估计是手抖多写出来的一个处理
460|0
哈金|  楼主 | 2018-8-10 11:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个地方的确有些莫名其妙,串口HAL里面全程无发送FIFO空中断使能,中断里面搞了一个检测。
后面再深入研究下是不是手抖造成的。
  * @brief Handle UART interrupt request.
  * @param huart: UART handle.
  * @retval None
void HAL_UART_IRQHandler(UART_HandleTypeDef *huart)
  uint32_t isrflags   = READ_REG(huart->Instance->ISR);
  uint32_t cr1its     = READ_REG(huart->Instance->CR1);
  uint32_t cr3its     = READ_REG(huart->Instance->CR3);
  uint32_t errorflags;
  /* If no error occurs */
  errorflags = (isrflags & (uint32_t)(USART_ISR_PE | USART_ISR_FE | USART_ISR_ORE | USART_ISR_NE));
  if (errorflags == RESET)
    /* UART in mode Receiver ---------------------------------------------------*/
    if(((isrflags & USART_ISR_RXNE) != RESET)
     && (   ((cr1its & USART_CR1_RXNEIE) != RESET)
         || ((cr3its & USART_CR3_RXFTIE) != RESET)) )
      UART_Receive_IT(huart);
      return;
  /* If some errors occur */
  if(   (errorflags != RESET)
     && (   ((cr3its & (USART_CR3_RXFTIE | USART_CR3_EIE)) != RESET)
         || ((cr1its & (USART_CR1_RXNEIE | USART_CR1_PEIE)) != RESET)))
    /* UART parity error interrupt occurred -------------------------------------*/
    if(((isrflags & USART_ISR_PE) != RESET) && ((cr1its & USART_CR1_PEIE) != RESET))
      __HAL_UART_CLEAR_IT(huart, UART_CLEAR_PEF);
      huart->ErrorCode |= HAL_UART_ERROR_PE;
    /* UART frame error interrupt occurred --------------------------------------*/
    if(((isrflags & USART_ISR_FE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET))
      __HAL_UART_CLEAR_IT(huart, UART_CLEAR_FEF);
      huart->ErrorCode |= HAL_UART_ERROR_FE;
    /* UART noise error interrupt occurred --------------------------------------*/
    if(((isrflags & USART_ISR_NE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET))
      __HAL_UART_CLEAR_IT(huart, UART_CLEAR_NEF);
      huart->ErrorCode |= HAL_UART_ERROR_NE;
    /* UART Over-Run interrupt occurred -----------------------------------------*/
    if(   ((isrflags & USART_ISR_ORE) != RESET)
        &&(  ((cr1its & USART_CR1_RXNEIE) != RESET) ||
             ((cr3its & USART_CR3_RXFTIE) != RESET) ||
             ((cr3its & USART_CR3_EIE) != RESET)) )
      __HAL_UART_CLEAR_IT(huart, UART_CLEAR_OREF);
      huart->ErrorCode |= HAL_UART_ERROR_ORE;
    /* Call UART Error Call back function if need be --------------------------*/
    if(huart->ErrorCode != HAL_UART_ERROR_NONE)
      /* If Overrun error occurs, or if any error occurs in DMA mode reception,
         consider error as blocking */
      if (((huart->ErrorCode & HAL_UART_ERROR_ORE) != RESET) ||
          (HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR)))
        /* Blocking error : transfer is aborted
           Set the UART state ready to be able to start again the process,
           Disable Rx Interrupts, and disable Rx DMA request, if ongoing */
        UART_EndRxTransfer(huart);
        /* Disable the UART DMA Rx request if enabled */
        if (HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR))
          CLEAR_BIT(huart->Instance->CR3, USART_CR3_DMAR);
          /* Abort the UART DMA Rx channel */
          if(huart->hdmarx != NULL)
            /* Set the UART DMA Abort callback :
               will lead to call HAL_UART_ErrorCallback() at end of DMA abort procedure */
            huart->hdmarx->XferAbortCallback = UART_DMAAbortOnError;
            /* Abort DMA RX */
            if(HAL_DMA_Abort_IT(huart->hdmarx) != HAL_OK)
              /* Call Directly huart->hdmarx->XferAbortCallback function in case of error */
              huart->hdmarx->XferAbortCallback(huart->hdmarx);
          else
            /* Call user error callback */
            HAL_UART_ErrorCallback(huart);
        else
      else
        /* Non Blocking error : transfer could go on.
           Error is notified to user through user error callback */
        huart->ErrorCode = HAL_UART_ERROR_NONE;
    return;
  } /* End if some error occurs */
  /* UART wakeup from Stop mode interrupt occurred ---------------------------*/
  if(((isrflags & USART_ISR_WUF) != RESET) && ((cr3its & USART_CR3_WUFIE) != RESET))
    __HAL_UART_CLEAR_IT(huart, UART_CLEAR_WUF);
    /* Set the UART state ready to be able to start again the process */
    huart->gState  = HAL_UART_STATE_READY;
    huart->RxState = HAL_UART_STATE_READY;
    HAL_UARTEx_WakeupCallback(huart);
    return;
  /* UART in mode Transmitter ------------------------------------------------*/
  if(((isrflags & USART_ISR_TXE) != RESET)
     && (   ((cr1its & USART_CR1_TXEIE) != RESET)
         || ((cr3its & USART_CR3_TXFTIE) != RESET)) )
    UART_Transmit_IT(huart);
    return;
  /* UART in mode Transmitter (transmission end) -----------------------------*/
  if(((isrflags & USART_ISR_TC) != RESET) && ((cr1its & USART_CR1_TCIE) != RESET))
    UART_EndTransmit_IT(huart);
    return;
  /* UART TX FIFO Empty  -----------------------------------------------------*/
  if(((isrflags & USART_ISR_TXFE) != RESET) && ((cr1its & USART_CR1_TXFEIE) != RESET))
    CLEAR_BIT(huart->Instance->CR1, USART_CR1_TXFEIE);
