[MCU] TI MSP430 如何实现模拟串口通信
1253|25
 楼主| 八层楼 发表于 2020-8-5 17:13 | 显示全部楼层 |阅读模式
1、背景:
很多时候由于硬件资源有限,但又需要使用串口通信,此时可以考虑使用模拟串口;
2、前提:
要实现特定bps的串口速率,需要相应频率的定时器,保证误码率在可以接受的范围内;
例如:
1MHz的时钟最高可模拟9600bps的通信速率:1M/9600 = 104  误码率<1%
3、参考代码:
  • //  ACLK = TACLK = LFXT1 = 32768Hz, MCLK = SMCLK = default DCO
  • //  //* An external watch crystal is required on XIN XOUT for ACLK *//
  • //               MSP430G2xx1
  • //        /|\|              XIN|-
  • //         | |                 | 32kHz
  • //         --|RST          XOUT|-
  • //           |   CCI0B/TXD/P1.1|-------->
  • //           |                 | 9600 8N1
  • //           |   CCI0A/RXD/P1.2|<--------
  • #include <msp430.h>
  • // Hardware-related definitions
  • #define UART_TXD   0x02                     // TXD on P1.1 (Timer0_A.OUT0)
  • #define UART_RXD   0x04                     // RXD on P1.2 (Timer0_A.CCI1A)
  • // Conditions for 9600 Baud SW UART, SMCLK = 1MHz
  • #define UART_TBIT_DIV_2     (1000000 / (9600 * 2))
  • #define UART_TBIT           (1000000 / 9600)
  • // Global variables used for full-duplex UART communication
  • unsigned int txData;                        // UART internal variable for TX
  • unsigned char rxBuffer;                     // Received UART character
  • // Function prototypes
  • void TimerA_UART_init(void);
  • void TimerA_UART_tx(unsigned char byte);
  • void TimerA_UART_print(char *string);
  • // main()
  • int main(void)
  •     WDTCTL = WDTPW + WDTHOLD;               // Stop watchdog timer
  •     if (CALBC1_1MHZ==0xFF)                                        // If calibration constants erased
  •       while(1);                             // do not load, trap CPU!!
  •     DCOCTL = 0;                             // Select lowest DCOx and MODx settings
  •     BCSCTL1 = CALBC1_1MHZ;
  •     DCOCTL = CALDCO_1MHZ;
  •     P1OUT = 0x00;                           // Initialize all GPIO
  •     P1SEL = UART_TXD + UART_RXD;            // Timer function for TXD/RXD pins
  •     P1DIR = 0xFF & ~UART_RXD;               // Set all pins but RXD to output
  •     P2OUT = 0x00;
  •     P2SEL = 0x00;
  •     P2DIR = 0xFF;
  •     __enable_interrupt();
  •     TimerA_UART_init();                     // Start Timer_A UART
  •     TimerA_UART_print("G2xx1 TimerA UART\r\n");
  •     TimerA_UART_print("READY.\r\n");
  •     for (;;)
  •         // Wait for incoming character
  •         __bis_SR_register(LPM0_bits);
  •         // Update board outputs according to received byte
  •         if (rxBuffer & 0x01) P1OUT |= 0x01; else P1OUT &= ~0x01;    // P1.0
  •         if (rxBuffer & 0x02) P1OUT |= 0x08; else P1OUT &= ~0x08;    // P1.3
  •         if (rxBuffer & 0x04) P1OUT |= 0x10; else P1OUT &= ~0x10;    // P1.4
  •         if (rxBuffer & 0x08) P1OUT |= 0x20; else P1OUT &= ~0x20;    // P1.5
  •         if (rxBuffer & 0x10) P1OUT |= 0x40; else P1OUT &= ~0x40;    // P1.6
  •         if (rxBuffer & 0x20) P1OUT |= 0x80; else P1OUT &= ~0x80;    // P1.7
  •         if (rxBuffer & 0x40) P2OUT |= 0x40; else P2OUT &= ~0x40;    // P2.6
  •         if (rxBuffer & 0x80) P2OUT |= 0x80; else P2OUT &= ~0x80;    // P2.7
  •         // Echo received character
  •         TimerA_UART_tx(rxBuffer);
  • // Function configures Timer_A for full-duplex UART operation
  •     TACCTL0 = OUT;                          // Set TXD Idle as Mark = '1'
  •     TACCTL1 = SCS + CM1 + CAP + CCIE;       // Sync, Neg Edge, Capture, Int
  •     TACTL = TASSEL_2 + MC_2;                // SMCLK, start in continuous mode
  • // Outputs one byte using the Timer_A UART
  •     while (TACCTL0 & CCIE);                 // Ensure last char got TX'd
  •     TACCR0 = TAR;                           // Current state of TA counter
  •     TACCR0 += UART_TBIT;                    // One bit time till first bit
  •     TACCTL0 = OUTMOD0 + CCIE;               // Set TXD on EQU0, Int
  •     txData = byte;                          // Load global variable
  •     txData |= 0x100;                        // Add mark stop bit to TXData
  •     txData <<= 1;                           // Add space start bit
  • // Prints a string over using the Timer_A UART
  •     while (*string) {
  •         TimerA_UART_tx(*string++);
  • // Timer_A UART - Transmit Interrupt Handler
  • #pragma vector = TIMERA0_VECTOR
  • __interrupt void Timer_A0_ISR(void)
  •     static unsigned char txBitCnt = 10;
  •     TACCR0 += UART_TBIT;                    // Add Offset to CCRx
  •     if (txBitCnt == 0) {                    // All bits TXed?
  •         TACCTL0 &= ~CCIE;                   // All bits TXed, disable interrupt
  •         txBitCnt = 10;                      // Re-load bit counter
  •     else {
  •         if (txData & 0x01) {
  •           TACCTL0 &= ~OUTMOD2;              // TX Mark '1'
  •         else {
  •           TACCTL0 |= OUTMOD2;               // TX Space '0'
  •         txData >>= 1;
  •         txBitCnt--;
  • // Timer_A UART - Receive Interrupt Handler
  • #pragma vector = TIMERA1_VECTOR
  • __interrupt void Timer_A1_ISR(void)
  •     static unsigned char rxBitCnt = 8;
  •     static unsigned char rxData = 0;
  •     switch (__even_in_range(TAIV, TAIV_TAIFG)) { // Use calculated branching
  •         case TAIV_TACCR1:                        // TACCR1 CCIFG - UART RX
  •             TACCR1 += UART_TBIT;                 // Add Offset to CCRx
  •             if (TACCTL1 & CAP) {                 // Capture mode = start bit edge
  •                 TACCTL1 &= ~CAP;                 // Switch capture to compare mode
  •                 TACCR1 += UART_TBIT_DIV_2;       // Point CCRx to middle of D0
  •             else {
  •                 rxData >>= 1;
  •                 if (TACCTL1 & SCCI) {            // Get bit waiting in receive latch
  •                     rxData |= 0x80;
  •                 rxBitCnt--;
  •                 if (rxBitCnt == 0) {             // All bits RXed?
  •                     rxBuffer = rxData;           // Store in global variable
  •                     rxBitCnt = 8;                // Re-load bit counter
  •                     TACCTL1 |= CAP;              // Switch compare to capture mode
  •                     __bic_SR_register_on_exit(LPM0_bits);  // Clear LPM0 bits from 0(SR)
  •             break;
10299823 发表于 2020-8-5 20:14 | 显示全部楼层
串口通信,或者 IIC 通信,应该是由专门的硬件,来完成的
jimmhu 发表于 2020-8-5 20:14 | 显示全部楼层
用IO模拟SPI或者I2C都可以
lihuami 发表于 2020-8-5 20:14 | 显示全部楼层
xiaoyaozt 发表于 2020-8-5 20:15 | 显示全部楼层
用单片机IO口模拟的,只能是半双工的
uptown 发表于 2020-8-5 20:15 | 显示全部楼层
用来模拟串口接收的I/O是两个外中断口 之一,可以做到接收中断
cehuafan 发表于 2020-8-5 20:15 | 显示全部楼层
用一个普通IO口作为TXD发送口,外部中断口作为RXD接收口
usysm 发表于 2020-8-5 20:16 | 显示全部楼层
单片机一般只有一个串行接口
typeof 发表于 2020-8-5 20:16 | 显示全部楼层
用延时来实现定时
yujielun 发表于 2020-8-5 20:17 | 显示全部楼层
模拟串口可行性怎么样
htmlme 发表于 2020-8-5 20:17 | 显示全部楼层
定时器是最简单的方式了
uptown 发表于 2020-8-5 20:17 | 显示全部楼层
边沿触发的移位寄存器
xiaoyaozt 发表于 2020-8-5 20:17 | 显示全部楼层
主要就是定时器实现波特率定时
cehuafan 发表于 2020-8-5 20:17 | 显示全部楼层
就可以模拟串口通讯了。
lihuami 发表于 2020-8-5 20:17 | 显示全部楼层
谢谢楼主分享的资料了。
usysm 发表于 2020-8-5 20:17 | 显示全部楼层
模拟串口主要是先要考虑到波特率和数据格式
jimmhu 发表于 2020-8-5 20:18 | 显示全部楼层
如果一定要用延时的方式来接收
typeof 发表于 2020-8-5 20:18 | 显示全部楼层
示例软件模拟串口的方法
10299823 发表于 2020-8-5 20:18 | 显示全部楼层
可以考虑使用模拟串口
yujielun 发表于 2020-8-5 20:18 | 显示全部楼层
学习一下。
