[综合信息] 华大HC32F003☆ ---I2C例程分享(部分一)
 楼主| LED2013 发表于 2020-8-7 10:10 | 显示全部楼层 |阅读模式
☆ HC32F003 系列是一款 Low Pin Count、宽电压工作范围的 MCU。集成 12 位 1M sps 高精度SARADC 以及集成了比较器,多路 UART,SPI,I2C 等丰富的通讯外设,具有高整合度、高抗干扰、高可靠性的特点。HC32F003 内核采用 Cortex-M0+ 内核,配合成熟的 Keil μVision 调试开发软件,支持 C 语言及汇编语言,汇编指令。
☆ 华大MCU单片机资料分享连接
HC32F003 HC32F005 HC32L110 HC32L136 HC32F030 HC32M140 HC32F146 HC32L150 HC32L156
/ \file main.c
** A detailed description is available at
** @link Sample Group Some description @endlink
** - 2016-02-16 1.0 XYZ First version for Device Driver Library of Module.
  • Include files
    #include “i2c.h”
    #include “gpio.h”
  • Local pre-processor symbols/macros (’#define’)
  • Global variable definitions (declared in header file with ‘extern’)
  • Local type definitions (‘typedef’)
  • Local function prototypes (‘static’)
  • Local variable definitions (‘static’) *
    #define T1_PORT (3)
    #define T1_PIN (3)
  • Function implementation - global (‘extern’) and local (‘static’)
** \brief Main function of project
** \return uint32_t return value, if needed
** This sample
uint8_t u8Senddata[10] = {0x12,0x34,0x77,0x66,0x55,0x44,0x33,0x22,0x11,0x00};
uint8_t u8Recdata[10]={0x00};
boolean_t bIrq = 0;
uint8_t u8State = 0,u8SendCnt = 0,u8RecCnt = 0;
uint8_t Send** = 0,Comm_** = 0;
uint8_t data=0;
static void I2cCallBack(void)
bIrq = 1;
u8State = I2C_GetState();
if(0 == Send**)
if(0x08 == u8State)
I2C_ClearFunc(I2cStart_En);
I2C_WriteByte(I2c_SlaveWt);//从机地址发送OK
if(0x18 == u8State)
I2C_WriteByte(0x00);//写零地址
if(0x28 == u8State)
I2C_WriteByte(u8Senddata[u8SendCnt]);
u8SendCnt++;
if(u8SendCnt>10)
I2C_SetFunc(I2cStop_En);
Send** = 1;
Comm_** = 1;
else
if(0x08 == u8State)
if(0x18 == u8State)
I2C_WriteByte(0x00);//读取0地址
if(0x28 == u8State)
I2C_SetFunc(I2cStart_En);
if(0x10 == u8State)
        I2C_WriteByte(I2c_SlaveRd);            }    if(0x40 == u8State)    {        I2C_SetFunc(I2cAck_En);    }    if(0x50 == u8State)    {      u8Recdata[u8RecCnt] = I2C_ReadByte();      u8RecCnt++;    }    if(u8RecCnt>10)    {        I2C_SetFunc(I2cStop_En);    }}I2C_ClearIrq();
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 10
  • 11
  • 12
  • 13
  • 14
  • 15
  • 16
  • 17
  • 18
  • 19
int32_t main(void)
stc_i2c_config_t stcI2cCfg;stc_clk_config_t stcCfg;DDL_ZERO_STRUCT(stcCfg);DDL_ZERO_STRUCT(stcI2cCfg);Gpio_InitIOExt(2,5,GpioDirOut,TRUE,FALSE,TRUE,FALSE); Gpio_InitIOExt(2,6,GpioDirOut,TRUE,FALSE,TRUE,FALSE);Gpio_SetFunc_I2CDAT_P25() Gpio_SetFunc_I2CCLK_P26()Clk_SetPeripheralGate(ClkPeripheralI2c,TRUE);stcI2cCfg.enFunc = I2cBaud_En;stcI2cCfg.u8Tm = 0x04;//100K=(4000000/(8*(4+1))stcI2cCfg.pfnI2cCb = I2cCallBack;stcI2cCfg.bTouchNvic = TRUE;I2C_DeInit(); I2C_Init(stcI2cCfg);I2C_SetFunc(I2cMode_En);I2C_SetFunc(I2cStart_En);while(1){
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 10
  • 11
  • 12
  • 13
  • 14
  • 15
  • 16
  • 17
  • 18
  • 19
  • 20
  • 21
  • 22
  • 23
  • 24
#if 1
if(1 == Comm_**)
Comm_** = 0;
delay1ms(100);
#endif
  • EOF (not truncated)
作者:虹芯侠客1
来源:CSDN
原文:https://blog.csdn.net/jetson024/article/details/84619088
版权声明:本文为博主原创**,转载请附上博文链接!
八层楼 发表于 2020-9-4 13:16 | 显示全部楼层
了解了 谢谢楼主
观海 发表于 2020-9-4 13:16 | 显示全部楼层
非常感谢楼主分享
guanjiaer 发表于 2020-9-4 13:17 | 显示全部楼层
额 排版不行啊
heimaojingzhang 发表于 2020-9-4 13:18 | 显示全部楼层
看的我头疼
keaibukelian 发表于 2020-9-4 13:21 | 显示全部楼层
没看太明白
