[MCU] 28031仿真出错
1068|24
 楼主| jiajs 发表于 2020-9-3 19:35 | 显示全部楼层 |阅读模式
错误提示:
C28xx: Failed Software Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: Trouble Reading PC Register: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: GEL: Error while executing OnReset(1): target access failed  at (ST1&~(0x0100)) [f28031.gel:282]  at C28x_Mode() [f28031.gel:32]  at OnReset(1) .
C28xx: Flash Programmer: Error erasing flash memory. Device is locked or not connected. Operation cancelled
C28xx: Flash Programmer: Error erasing Flash memory.
C28xx: Error resuming a profile counter: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: Trouble Writing Memory Block at 0x3f75f6 on Page 0 of Length 0x16: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: GEL: File: C:\ti\tidcs\c28\DSP2803x\v121\DSP2803x_examples\cpu_timer\Debug\Example_2803xCpuTimer.out: Load failed.
zhanghqi 发表于 2020-9-3 19:38 | 显示全部楼层
帮你顶一个   这一块  真心没有用过  希望有高人出现  顶一个  呵呵
zhenykun 发表于 2020-9-3 19:44 | 显示全部楼层
有没有可能软件CCS出问题了,重启一下软件试一下。
 楼主| jiajs 发表于 2020-9-3 19:49 | 显示全部楼层
试过了,不行
chenho 发表于 2020-9-3 19:54 | 显示全部楼层
dingy 发表于 2020-9-3 19:58 | 显示全部楼层
什么仿真器呢?
supernan 发表于 2020-9-3 20:01 | 显示全部楼层
这个程序在其他上能够运行吗
zyf部长 发表于 2020-9-3 20:04 | 显示全部楼层
有可能芯片损坏了
hanwe 发表于 2020-9-3 20:09 | 显示全部楼层
CCS连接不到目标板上  ?
zhuww 发表于 2020-9-3 20:12 | 显示全部楼层
用最新的CCS
bqyj 发表于 2020-9-3 20:17 | 显示全部楼层
板子上的电压都正确?
zhuhuis 发表于 2020-9-3 20:20 | 显示全部楼层
要检测一下你芯片的供电电源是否在手册要求的范围之内
juventus9554 发表于 2020-9-3 20:24 | 显示全部楼层
这个内存分配的问题吧
xxrs 发表于 2020-9-3 20:26 | 显示全部楼层
morrisk 发表于 2020-9-3 20:29 | 显示全部楼层
供电是否正常,是否共地处理了?
yufe 发表于 2020-9-3 20:33 | 显示全部楼层
查查复位引脚接线或设置
yufe 发表于 2020-9-3 20:46 | 显示全部楼层
配置好正确的仿真器,芯片
chenho 发表于 2020-9-3 20:51 | 显示全部楼层
是不是仿真器有问题呢
zwll 发表于 2020-9-3 20:56 | 显示全部楼层
请检查硬件仿真器是否支持CCS对应的版本
chuxh 发表于 2020-9-3 21:02 | 显示全部楼层
如果能够运行,就是仿真器的问题。
