[51单片机]
led点阵动画显示错误
511|2
xukng|  楼主 | 2020-9-15 14:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
#include <intrins.h>
sbit ser = P3^4;
sbit rclk= P3^5;
sbit srclk = P3^6;
unsigned char code ledbuf[40] = {
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
   0x00,0x00,0x41,0x7F,0x7F,0x41,0x00,0x00,
            0x38,0x44,0x42,0x21,0x21,0x42,0x44,0x38,
            0x00,0x00,0x7E,0x7F,0x03,0x03,0x7F,0x7E,
unsigned char code P0buf[8] = {0x7f,0xbf,0xdf,0xef,
                          0xf7,0xdb,0xfd,0xfe};
void HC595SendByte(unsigned char dat)
   unsigned char i;
   srclk = 0;
   rclk = 0;
   for(i=0;i<8;i++)
     ser = dat>>7;
     dat=dat<<1;
     srclk = 1;
     _nop_();
     _nop_();
     srclk = 0;
    rclk = 1;
    _nop_();
    _nop_();
    rclk = 0;
void main()
    TMOD=0x01;
TH0 = 0xfc;
TL0 = 0x67;
EA = 1;
ET0 =1;
TR0 = 1;
while(1);
void InterruptTimer0() interrupt 1
    static unsigned char i= 0;
static unsigned char cnt= 0;
static unsigned char tmr250ms = 0;
TH0 = 0xfc;
TL0 = 0x67;
if(i>=8)
{i=0;}
P0 = 0xff;
HC595SendByte(ledbuf[cnt+i]);
P0 =P0buf[i];  //
i++;
tmr250ms++;
if(tmr250ms>=250)
   cnt++;
   tmr250ms = 0;
   if(cnt>=32)
   cnt = 0;
xukng 2020-9-15 14:23 回复TA
在点阵显示上出现不想要的图形
xukng|  楼主 | 2020-9-15 14:54 | 只看该作者
这里有0xdb写错了,应该是0xfb
