[DemoCode下载]
n76E003使用SDCC
1005|7
jiekou001|  楼主 | 2020-10-21 20:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
https://github.com/wkaster/N76E003/tree/master/N76_sdcc
jiekou001|  楼主 | 2020-10-21 20:22 | 只看该作者
N76E003-master.zip (1010.08 KB)
Example:
Keil C51 code:
mov        TA, #0xAA                                ; TA = 0xAA
mov        TA, #0x55                                ; TA = 0x55 {'U'}
orl        SFRS, #0x01                          ; SFRS |= 0x01
SDCC non corrected code:
mov        R6, SFRS                                ; R6 = SFRS
orl        0x06, #0x01                         ; 0x06 |= 0x01
mov        SFRS, R6                                ; SFRS = R6
Solution 1
Use a peep.def file containing:
replace {
  mov  %1,%2
  orl  a%1,%3
  mov  %2,%1
} by {
  orl  %2,%3
Solution 2 (Thanks to Vladimir Shevtsov / MrFeek)
Make a modified SFR_Macro.h replacing all "|=" statments
Example:
Replace this:  #define  set_SMOD    PCON |= SET_BIT7; // Original
By this:             #define  set_SMOD   _asm_ ("orl _PCON,#0x80");  // SDCC compatible
Disable Power-On Reset (POR)
Nuvoton (strongly) recommends disable POR at startup. See section 24.1 of
the datasheet for more information. That could be done using the
"_sdcc_external_startup" function as shown below.
unsigned char _sdcc_external_startup (void)
    __asm
    mov        0xC7, #0xAA
    mov        0xC7, #0x55
    mov        0xFD, #0x5A
    mov        0xC7, #0xAA
    mov        0xC7, #0x55
    mov        0xFD, #0xA5
    __endasm;
    return 0;
nawu| | 2020-11-10 13:45 | 只看该作者
SDCC是什么  工具还是芯片?
qcliu| | 2020-11-10 13:45 | 只看该作者
有C语言的例程吗
tfqi| | 2020-11-10 13:45 | 只看该作者
我只能说 我没看懂
wiba| | 2020-11-10 13:46 | 只看该作者
能实现什么功能呢
zljiu| | 2020-11-10 13:46 | 只看该作者
先去网址学习一下再说
