[蓝牙芯片] 关于蓝牙芯片通知与读的区别
800|4
 楼主| 阳仔很无奈 发表于 2020-11-7 15:37 | 显示全部楼层 |阅读模式
在CH573的主机例程中,read和receive noti有什么区别呀,为什么要分成两个部分?
static void centralProcessGATTMsg( gattMsgEvent_t *pMsg )
  if ( centralState != BLE_STATE_CONNECTED )
    // In case a GATT message came after a connection has dropped,
    // ignore the message
    return;
  if ( ( pMsg->method == ATT_EXCHANGE_MTU_RSP ) ||
       ( ( pMsg->method == ATT_ERROR_RSP ) &&
         ( pMsg->msg.errorRsp.reqOpcode == ATT_EXCHANGE_MTU_REQ ) ) )
    if ( pMsg->method == ATT_ERROR_RSP )
      uint8 status = pMsg->msg.errorRsp.errCode;
      PRINT( "Exchange MTU Error: %x\n", status );
    centralProcedureInProgress = FALSE;
  if ( pMsg->method == ATT_MTU_UPDATED_EVENT )
    PRINT("MTU: %x\n",pMsg->msg.mtuEvt.MTU);
  if ( ( pMsg->method == ATT_READ_RSP ) ||
         ( pMsg->msg.errorRsp.reqOpcode == ATT_READ_REQ ) ) )
      PRINT( "Read Error: %x\n", status );
    else
      // After a successful read, display the read value
      PRINT("Read rsp: %x\n",*pMsg->msg.readRsp.pValue);
  else if ( ( pMsg->method == ATT_WRITE_RSP ) ||
         ( pMsg->msg.errorRsp.reqOpcode == ATT_WRITE_REQ ) ) )
      PRINT( "Write Error: %x\n", status );
    else
      // Write success
      PRINT( "Write success \n" );
  else if ( pMsg->method == ATT_HANDLE_VALUE_NOTI )
                PRINT("Receive noti: %x\n",*pMsg->msg.handleValueNoti.pValue);
  else if ( centralDiscState != BLE_DISC_STATE_IDLE )
    centralGATTDiscoveryEvent( pMsg );
  GATT_bm_free(&pMsg->msg, pMsg->method);
WCHTech2 发表于 2020-11-7 15:58 | 显示全部楼层
  if ( centralState != BLE_STATE_CONNECT ...
read 是主机主动去发消息读从机的值,读的是根据主机发的命令返回的值
notify是从机主动发起的通知
明白了,谢谢  发表于 2020-11-7 16:11
随风而去吧 发表于 2021-1-10 19:18 | 显示全部楼层
很棒棒哦,值得学习
