PIC C30编译器,内部函数调用出错。
3022|0
 楼主| lhzw2001 发表于 2012-2-7 08:34 | 显示全部楼层 |阅读模式
int __attribute__ ((space(eedata))) eeData = 0x1234; // Variable located in EEPROM
unsigned int offset;
// Set up NVMCON to erase one word of data EEPROM
NVMCON = 0x4058;
// Set up a pointer to the EEPROM location to be erased
TBLPAG = __builtin_tblpage(&eeData); // Initialize EE Data page pointer
offset = __builtin_tbloffset(&eeData); // Initizlize lower word of address
__builtin_tblwtl(offset, 0); // Write EEPROM data to write latch
asm volatile ("disi #5"); // Disable Interrupts For 5 Instructions
__builtin_write_NVM(); // Issue Unlock Sequence & Start Write Cycle
error: Argument to __builtin_tblpage() is not the address
