配置使用tm4c123的几个串口,发现必须连上usb转串口,这个串口就能使,不连接,程序卡死。什么原因,下面贴上代码
//UART2
void ConfigureUART2(void)
// Enable the peripherals used by this example.
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART2);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
// Enable processor interrupts.
ROM_IntMasterEnable();
//PD7±»êÇËø×¡áËμÄ£¬ê1óøÃòy½ÅμÄÆäËû1|ÄüDèòa½«¸ÃIO¿ú½aËø£¬ÅäÖÃíê1|ÄüoóÔùÖØDÂËø¶¨
//PF0ò2êÇèç′Ë£¬μ«PF0μÄè·¶¨ÖμÎa0x01
HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY; //½aËø
HWREG(GPIO_PORTD_BASE + GPIO_O_CR) |= 0x80;//è·èÏ
HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = 0;//ÖØDÂËø¶¨
ROM_GPIOPinConfigure(GPIO_PD6_U2RX);
ROM_GPIOPinConfigure(GPIO_PD7_U2TX);
ROM_GPIOPinTypeUART(GPIO_PORTD_BASE, GPIO_PIN_6 | GPIO_PIN_7);
// Configure the UART for 115,200, 8-N-1 operation.
ROM_UARTConfigSetExpClk(UART2_BASE, ROM_SysCtlClockGet(), 115200,
(UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
UART_CONFIG_PAR_NONE));
// Enable the UART interrupt.
ROM_IntEnable(INT_UART2);
ROM_UARTIntEnable(UART2_BASE, UART_INT_RX | UART_INT_RT);
//UART3
void ConfigureUART3(void)
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART3);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
// Configure GPIO Pins for UART mode.
ROM_GPIOPinConfigure(GPIO_PC6_U3RX);
ROM_GPIOPinConfigure(GPIO_PC7_U3TX);
ROM_GPIOPinTypeUART(GPIO_PORTC_BASE, GPIO_PIN_6 | GPIO_PIN_7);
ROM_UARTConfigSetExpClk(UART3_BASE, ROM_SysCtlClockGet(), 115200,
ROM_IntEnable(INT_UART3);
ROM_UARTIntEnable(UART3_BASE, UART_INT_RX | UART_INT_RT);
//UART4
void ConfigureUART4(void)
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART4);
ROM_GPIOPinConfigure(GPIO_PC4_U4RX);
ROM_GPIOPinConfigure(GPIO_PC5_U4TX);
ROM_GPIOPinTypeUART(GPIO_PORTC_BASE, GPIO_PIN_4 | GPIO_PIN_5);
ROM_UARTConfigSetExpClk(UART4_BASE, ROM_SysCtlClockGet(), 115200,
ROM_IntEnable(INT_UART4);
ROM_UARTIntEnable(UART4_BASE, UART_INT_RX | UART_INT_RT);
//UART5
void ConfigureUART5(void)
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART5);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
ROM_GPIOPinConfigure(GPIO_PE4_U5RX);
ROM_GPIOPinConfigure(GPIO_PE5_U5TX);
ROM_GPIOPinTypeUART(GPIO_PORTE_BASE, GPIO_PIN_4 | GPIO_PIN_5);
ROM_UARTConfigSetExpClk(UART5_BASE, ROM_SysCtlClockGet(), 115200,
ROM_IntEnable(INT_UART5);
ROM_UARTIntEnable(UART5_BASE, UART_INT_RX | UART_INT_RT);
