[应用方案] SPI接收資料
474|1
 楼主| cr315 发表于 2020-12-7 17:02 | 显示全部楼层 |阅读模式
spi, TE, TI, AC
不好意思剛接觸新唐的板子目前想要測試SPI_SLAVE
使用的是官方提供的程式測試
C:\Nuvoton\BSP Library\M051SeriesBSP_CMSIS_Rev3.01.001\SampleCode\RegBased\SPI_SlaveFifoMode
想問的是顯示的方式是用PRINTF
可是我在debug下
debug(printf)Viewer:沒有顯示東西
[IMG] [/ IMG]
不知道我的測試方式是對不對?
我目前是開啟調試後,按下RUN,然後SPI_MASTER端傳送資料過來
新唐的SPI收到資料後,應該就會PRINT到視窗中./
* @file     main.c
* @version  V3.0
* $Revision: 6 $
* $Date: 15/05/22 3:05p $
* @brief    Configure SPI0 as Slave mode and demonstrate how to communicate
*           with an off-chip SPI Master device with FIFO mode. This sample
*           code needs to work with SPI_MasterFifoMode sample code.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#include <gpio.h>
#define TEST_COUNT 16
uint32_t g_au32SourceData[TEST_COUNT];
uint32_t g_au32DestinationData[TEST_COUNT];
volatile uint32_t g_u32TxDataCount;
volatile uint32_t g_u32RxDataCount;
/* Function prototype declaration */
void SYS_Init(void);
void UART0_Init(void);
void SPI_Init(void);
/* Main function */
int main(void)
          GPIO_SetMode(P2,BIT7, GPIO_PMD_OUTPUT);
    volatile uint32_t u32TxDataCount, u32RxDataCount;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O. */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init SPI */
    SPI_Init();
    printf("\n\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|           SPI Slave Mode Sample Code (M05xxDN/DE only)               |\n");
    printf("\n");
    printf("Configure SPI0 as a slave.\n");
    printf("Bit length of a transaction: 32\n");
    printf("The I/O connection for SPI0:\n");
    printf("    SPISS0(P1.4)\n    SPICLK0(P1.7)\n");
    printf("    MISO_0(P1.6)\n    MOSI_0(P1.5)\n\n");
    printf("SPI controller will enable FIFO mode and transfer %d data to a off-chip master device.\n", TEST_COUNT);
    printf("In the meanwhile the SPI controller will receive %d data from the off-chip master device.\n", TEST_COUNT);
    printf("After the transfer is done, the %d received data will be printed out.\n", TEST_COUNT);
    for(u32TxDataCount = 0; u32TxDataCount < TEST_COUNT; u32TxDataCount++)
        /* Write the initial value to source buffer */
        g_au32SourceData[u32TxDataCount] = 0x00AA0000 + u32TxDataCount;
        /* Clear destination buffer */
        g_au32DestinationData[u32TxDataCount] = 0;
    u32TxDataCount = 0;
    u32RxDataCount = 0;
    printf("Press any key if the master device configuration is ready.\n");
    getchar();
    printf("\n");
    /* Access TX and RX FIFO */
    while(u32RxDataCount < TEST_COUNT)
        /* Check TX FULL flag and TX data count */
        if(((SPI0->STATUS & SPI_STATUS_TX_FULL_Msk) == 0) && (u32TxDataCount < TEST_COUNT))
            SPI0->TX0 = g_au32SourceData[u32TxDataCount++]; /* Write to TX FIFO */
        /* Check RX EMPTY flag */
        if((SPI0->STATUS & SPI_STATUS_RX_EMPTY_Msk) == 0)
            g_au32DestinationData[u32RxDataCount++] = SPI0->RX0; /* Read RX FIFO */
    /* Print the received data */
    printf("Received data:\n");
    for(u32RxDataCount = 0; u32RxDataCount < TEST_COUNT; u32RxDataCount++)
        printf("%d:\t0x%X\n", u32RxDataCount, g_au32DestinationData[u32RxDataCount]);
    printf("The data transfer was done.\n");
    printf("\n\nExit SPI driver sample code.\n");
    /* Disable SPI0 peripheral clock */
    CLK->APBCLK &= (~CLK_APBCLK_SPI0_EN_Msk);
    while(1);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable external 12MHz XTAL */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk;
    /* Waiting for clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk));
    /* Select HXT as the clock source of HCLK */
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLK_S_Msk)) | CLK_CLKSEL0_HCLK_S_HXT;
    /* Select HXT as the clock source of UART; select HCLK as the clock source of SPI0. */
    CLK->CLKSEL1 = (CLK->CLKSEL1 & (~(CLK_CLKSEL1_UART_S_Msk | CLK_CLKSEL1_SPI0_S_Msk))) | (CLK_CLKSEL1_UART_S_HXT | CLK_CLKSEL1_SPI0_S_HCLK);
    /* Enable UART0 and SPI0 clock */
    CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk | CLK_APBCLK_SPI0_EN_Msk;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CyclesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Setup SPI0 multi-function pins */
    SYS->P1_MFP = SYS_MFP_P14_SPISS0 | SYS_MFP_P15_MOSI_0 | SYS_MFP_P16_MISO_0 | SYS_MFP_P17_SPICLK0;
    /* Word length is 8 bits; 1 stop bit; no parity bit. */
    UART0->LCR = UART_LCR_WLS_Msk;
    /* Using mode 2 calculation: UART bit rate = UART peripheral clock rate / (BRD setting + 2) */
    /* UART peripheral clock rate 12MHz; UART bit rate 115200 bps. */
    /* 12000000 / 115200 bps ~= 104 */
    /* 104 - 2 = 0x66. */
    UART0->BAUD = UART_BAUD_DIV_X_EN_Msk | UART_BAUD_DIV_X_ONE_Msk | (0x66);
void SPI_Init(void)
    /* Init SPI        */
    /* Configure SPI0 as a slave, clock idle low, 32-bit transaction, drive output on falling clock edge and latch input on rising edge. */
    SPI0->CNTRL = SPI_CNTRL_FIFO_Msk | SPI_CNTRL_SLAVE_Msk | SPI_CNTRL_TX_NEG_Msk;
    /* Configure SPI0 as a low level active device. */
    SPI0->SSR = SPI_SSR_SS_LTRIG_Msk;
    /* Set IP clock divider. SPI peripheral clock rate = HCLK / 2 = 6MHz */
    SPI0->DIVIDER = 0;
/*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
海滨消消 发表于 2020-12-8 09:26 | 显示全部楼层
printf不可以从keil的debug显示出来的,printf实际是从MCU的UART0出来
