配置gd32串口的代码,支持中断发送和接收
1037|0
 楼主| hua_ren 发表于 2020-12-22 11:26 | 显示全部楼层 |阅读模式
void Uart2_init(void)
{    /* enable GPIO clock */
    rcu_periph_clock_enable(RCU_GPIOB);
    /* enable USART clock */
    rcu_periph_clock_enable(RCU_USART2);
                                            /* connect port to USARTx_Tx */
    gpio_init(GPIOB, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_10);
    /* connect port to USARTx_Rx */
    gpio_init(GPIOB, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_11);
    usart_deinit(USART2);
    usart_baudrate_set(USART2, 9600U);
    usart_word_length_set(USART2, USART_WL_8BIT);
    usart_stop_bit_set(USART2, USART_STB_1BIT);
    usart_parity_config(USART2, USART_PM_NONE);
    usart_hardware_flow_rts_config(USART2, USART_RTS_DISABLE);
    usart_hardware_flow_cts_config(USART2, USART_CTS_DISABLE);
    usart_receive_config(USART2, USART_RECEIVE_ENABLE);
    usart_transmit_config(USART2, USART_TRANSMIT_ENABLE);
            nvic_irq_enable(USART2_IRQn, 10, 0);
    /* configure COM2 */
    usart_interrupt_enable(USART2, USART_INT_TBE);
    usart_interrupt_enable(USART2, USART_INT_RBNE);
                usart_receiver_timeout_enable(USART2);
    usart_receiver_timeout_threshold_config(USART2, 10);
        //        usart_interrupt_enable(USART2, USART_INT_IDLE);
//    /* wait until USART send the transmitter_buffer */
//    while(txcount < tx_size);
//    while(RESET == usart_flag_get(USART0, USART_FLAG_TC));
    usart_enable(USART2);
