[STM8] 两片STM8通过硬件IIC通信问题,主机匹配完地址后就卡主了
501|0
 楼主| powerantone 发表于 2021-1-5 14:55 | 显示全部楼层 |阅读模式
试着用IIC让两片STM8通信,一片做主机,一片做从机。主机发送地址后,就停留在发送第一个字节字符后,设备一直停在while(!I2C_GetFlagStatus(I2C_FLAG_TXEMPTY));
搞了好久没找到解决办法undefined求组。。。
主机发送信息的代码:
  • <blockquote>void Write2Byte(void)
[color=rgb(51, 102, 153) !important]复制代码
从机初始化IIC,设置了中断:
  • INTERRUPT_HANDLER(I2C_IRQHandler, 19)
  •   uint8_t data;
  •   /* Read SR2 register to get I2C error */
  •   if ((I2C->SR2) != 0)
  •     /* Clears SR2 register */
  •     I2C->SR2 = 0;
  •   Event = I2C_GetLastEvent();
  •   switch (Event)
  •       /******* Slave transmitter ******/
  •       /* check on EV1 */
  •     case I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED:
  •       Tx_Idx = 0;
  •       UART1_Printf("I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED");
  •       break;
  •       /* check on EV3 */
  •     case I2C_EVENT_SLAVE_BYTE_TRANSMITTING:
  •       /* Transmit data */
  •       I2C_SendData(Slave_Buffer_Rx[Tx_Idx++]);
  •       UART1_Printf("I2C_EVENT_SLAVE_BYTE_TRANSMITTING");
  •       break;
  •       /******* Slave receiver **********/
  •       /* check on EV1*/
  •     case I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED:
  •       UART1_Printf("I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED");
  •       break;
  •       /* Check on EV2*/
  •       case I2C_EVENT_SLAVE_BYTE_RECEIVED:
  •       Slave_Buffer_Rx[Rx_Idx++] = I2C_ReceiveData();
  •       UART1_Printf("I2C_EVENT_SLAVE_BYTE_RECEIVED ");
  •       break;
  •       /* Check on EV4 */
  •     case (I2C_EVENT_SLAVE_STOP_DETECTED):
  •             /* write to CR2 to clear STOPF flag */
  •             I2C->CR2 |= I2C_CR2_ACK;
  •             UART1_Printf("I2C_EVENT_SLAVE_STOP_DETECTED ");
  •       break;
  •     default:
  •       break;
