第二步:怎么初始化GPIO的引脚? 先看一下固件库是如何实现GPIO的引脚的初始化的,我们写程序 - void gpio_init(uint32_t gpio_periph, uint32_t mode, uint32_t speed, uint32_t pin)
 -     uint16_t i;
 -     uint32_t temp_mode = 0U;
 -     uint32_t reg = 0U;
-     /* GPIO mode configuration */
 -     temp_mode = (uint32_t)(mode & ((uint32_t)0x0FU));
 -     /* GPIO speed configuration */
 -     if(((uint32_t)0x00U) != ((uint32_t)mode & ((uint32_t)0x10U))){
 -         /* output mode max speed:10MHz,2MHz,50MHz */
 -         temp_mode |= (uint32_t)speed;
-     /* configure the eight low port pins with GPIO_CTL0 */
 -     for(i = 0U;i < 8U;i++){
 -         if((1U << i) & pin){
 -             reg = GPIO_CTL0(gpio_periph);
 -             /* clear the specified pin mode bits */
 -             reg &= ~GPIO_MODE_MASK(i);
 -             /* set the specified pin mode bits */
 -             reg |= GPIO_MODE_SET(i, temp_mode);
 -             /* set IPD or IPU */
 -             if(GPIO_MODE_IPD == mode){
 -                 /* reset the corresponding OCTL bit */
 -                 GPIO_BC(gpio_periph) = (uint32_t)((1U << i) & pin);
 -             }else{
 -                 /* set the corresponding OCTL bit */
 -                 if(GPIO_MODE_IPU == mode){
 -                     GPIO_BOP(gpio_periph) = (uint32_t)((1U << i) & pin);
 -             /* set GPIO_CTL0 register */
 -             GPIO_CTL0(gpio_periph) = reg;
 -     /* configure the eight high port pins with GPIO_CTL1 */
 -     for(i = 8U;i < 16U;i++){
 -             reg = GPIO_CTL1(gpio_periph);
 -             reg &= ~GPIO_MODE_MASK(i - 8U);
 -             reg |= GPIO_MODE_SET(i - 8U, temp_mode);
 -             }else{
 -             /* set GPIO_CTL1 register */
 -             GPIO_CTL1(gpio_periph) = reg;
