[应用方案] M480BSP_ISP-1:ISP_DFU_20
587|8
 楼主| wangjiahao88 发表于 2021-1-9 14:51 | 显示全部楼层 |阅读模式
 楼主| wangjiahao88 发表于 2021-1-9 15:28 | 显示全部楼层
 楼主| wangjiahao88 发表于 2021-1-9 15:29 | 显示全部楼层
* @file     main.c
* @brief
*           Demonstrate how to upgrade firmware between USB device and PC through USB DFU( Device Firmware Upgrade) class.
*           A windows tool is also included in this sample code to connect with USB device.
* @CopyRight (C) 2019 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
#include "fmc_user.h"
#include "dfu_transfer.h"
uint32_t CLK_GetPLLClockFreq(void)
    return FREQ_192MHZ;
void SYS_Init(void)
    uint32_t volatile i;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
    PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
    CLK->PWRCTL |= (CLK_PWRCTL_HIRCEN_Msk | CLK_PWRCTL_HXTEN_Msk);
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLKSEL_Msk)) | CLK_CLKSEL0_HCLKSEL_HIRC;
    // Waiting for clock switching ok
    while (CLK->STATUS & CLK_STATUS_CLKSFAIL_Msk);
    CLK->PLLCTL = CLK_PLLCTL_PD_Msk; // Disable PLL
    CLK->PLLCTL = 0x8842E;           // Enable PLL & set frequency 192MHz
    while (!(CLK->STATUS & CLK_STATUS_PLLSTB_Msk));
    /* Enable External XTAL (4~24 MHz) */
    CLK->PWRCTL |= CLK_PWRCTL_HXTEN_Msk;
    while ((CLK->STATUS & CLK_STATUS_PLLSTB_Msk) != CLK_STATUS_PLLSTB_Msk);
    CLK->CLKDIV0 = CLK->CLKDIV0 & (~CLK_CLKDIV0_HCLKDIV_Msk);   /* PLL/1 */
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLKSEL_Msk)) | CLK_CLKSEL0_HCLKSEL_PLL;
    /* Set both PCLK0 and PCLK1 as HCLK/2 */
    CLK->PCLKDIV = CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2;
    SYS->USBPHY &= ~SYS_USBPHY_HSUSBROLE_Msk;    /* select HSUSBD */
    /* Enable USB PHY */
    SYS->USBPHY = (SYS->USBPHY & ~(SYS_USBPHY_HSUSBROLE_Msk | SYS_USBPHY_HSUSBACT_Msk)) | SYS_USBPHY_HSUSBEN_Msk;
    for (i = 0; i < 0x1000; i++);  // delay > 10 us
    SYS->USBPHY |= SYS_USBPHY_HSUSBACT_Msk;
    /* Enable IP clock */
    CLK->AHBCLK |= CLK_AHBCLK_HSUSBDCKEN_Msk;   /* USBD20 */
void USBD20_IRQHandler(void);
/*  Main Function        */
int32_t main(void)
    SYS_Init();
    FMC->ISPCTL |= FMC_ISPCTL_ISPEN_Msk;    // (1ul << 0)
    g_apromSize = GetApromSize();
    GetDataFlashInfo(&g_dataFlashAddr, &g_dataFlashSize);
    if (DetectPin != 0)
        goto _APROM;
    /* Open USB controller */
    HSUSBD_Open(NULL, DFU_ClassRequest, NULL);
    /*Init Endpoint configuration for DFU */
    DFU_Init();
    /* Start transaction */
    HSUSBD_CLR_SE0();
    /* polling USBD interrupt flag */
    while (DetectPin == 0)
        USBD20_IRQHandler();
_APROM:
    outpw(&SYS->RSTSTS, 3);//clear bit
    outpw(&FMC->ISPCTL, inpw(&FMC->ISPCTL) & 0xFFFFFFFC);
    outpw(&SCB->AIRCR, (V6M_AIRCR_VECTKEY_DATA | V6M_AIRCR_SYSRESETREQ));
    /* Trap the CPU */
    while (1);
工程文件
不明白这个DFU_20余DFU 有什么不同的地方。
ISP_DFU_20.rar
9.56 MB, 下载次数: 4
coshi 发表于 2021-2-6 10:25 | 显示全部楼层
能介绍一下这个功能吗
zljiu 发表于 2021-2-6 10:27 | 显示全部楼层
这个难道不是以前常用的哪个ISP_DFU吗
wiba 发表于 2021-2-6 10:29 | 显示全部楼层
能详细介绍一个这个东东吗
tfqi 发表于 2021-2-6 10:35 | 显示全部楼层
只读代码的话 也是不太了解
qcliu 发表于 2021-2-6 10:37 | 显示全部楼层
没看到什么优势啊
