[AT32F421] AT32F421-低频PWM输入捕获
1989|2
 楼主| ArterySW 发表于 2021-1-14 20:17 | 显示全部楼层 |阅读模式
AT32F421-低频PWM输入捕获
1.使用AT32F421捕获低至0.5khzPWM波形,可自动计算占空比和PWM频率;
2.此demo使用421的TMR15实现,PA3为PWM输入口;
3.使用时,需将附件解压在AT32BSP的如下路径:Project/AT_START_F421/Examples/TMR
4.查看打印数据:
5.程序源码:
main函数:
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_at32f413_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_at32f4xx.c file
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC configuration */
  NVIC_Configuration();
  /* Configure the GPIO ports */
  GPIO_Configuration();
  /* Board.c init */
  UART_Print_Init(115200);
  /* TMR15 configuration: PWM Input mode ------------------------
     The external signal is connected to TMR15 CH2 pin (PA.01),
     The Rising edge is used as active edge,
     The TMR15 CCR2 is used to compute the frequency value
     The TMR15 CCR1 is used to compute the duty cycle value
/* TMRe base configuration */
  TMR_TimeBaseStructInit(&TMR_TMReBaseStructure);
  TMR_TMReBaseStructure.TMR_Period = 65535;
  TMR_TMReBaseStructure.TMR_DIV = 3;
  TMR_TMReBaseStructure.TMR_ClockDivision = 0;
  TMR_TMReBaseStructure.TMR_CounterMode = TMR_CounterDIR_Up;
  TMR_TimeBaseInit(TMR15, &TMR_TMReBaseStructure);
  TMR_ICStructInit(&TMR_ICInitStructure);
  TMR_ICInitStructure.TMR_Channel = TMR_Channel_2;
  TMR_ICInitStructure.TMR_ICPolarity = TMR_ICPolarity_Rising;
  TMR_ICInitStructure.TMR_ICSelection = TMR_ICSelection_DirectTI;
  TMR_ICInitStructure.TMR_ICDIV = TMR_ICDIV_DIV1;
  TMR_ICInitStructure.TMR_ICFilter = 0x0;
  TMR_PWMIConfig(TMR15, &TMR_ICInitStructure);
  /* Select the TMR15 Input Trigger: TI2FP2 */
  TMR_SelectInputTrigger(TMR15, TMR_TRGSEL_TI2FP2);
  /* Select the slave Mode: Reset Mode */
  TMR_SelectSlaveMode(TMR15, TMR_SlaveMode_Reset);
  /* Enable the Master/Slave Mode */
  TMR_SelectMasterSlaveMode(TMR15, TMR_MasterSlaveMode_Enable);
  /* TMR enable counter */
  TMR_Cmd(TMR15, ENABLE);
  /* Enable the CC2 Interrupt Request */
  TMR_INTConfig(TMR15, TMR_INT_CC2, ENABLE);
  while (1)
    printf("Frequency=%dHZ,Dutycycle=%d%%\r\n",Frequency,DutyCycle);
中断处理:
void TMR15_GLOBAL_IRQHandler(void)
  /* Clear TMR3 Capture compare interrupt pending bit */
  TMR_ClearITPendingBit(TMR15, TMR_INT_CC2);
  /* Get the Input Capture value */
  IC2Value = TMR_GetCapture2(TMR15);
  if (IC2Value != 0)
    /* Duty cycle computation */
    DutyCycle = (TMR_GetCapture1(TMR15) * 100) / IC2Value;
    /* Frequency computation */
    Frequency = SystemCoreClock / (IC2Value*4);
  else
    DutyCycle = 0;
    Frequency = 0;
pwm_input.rar
1.64 MB, 下载次数: 129
杨寅辉 发表于 2021-1-14 22:16 | 显示全部楼层
捕获频率还可以更低点吗?因为实际中确实还有更低的
miskel 发表于 2022-5-16 13:10 | 显示全部楼层
多谢分享,问下你有V1.0的BSP库例程不分享一个,现在官方都是V2.0的啦,整个函数名称结构都变了
