RC0和RC1脚不能正常输出
790|11
 楼主| pengf 发表于 2021-1-18 20:51 | 显示全部楼层 |阅读模式
pic18f26k80写程序的时候发现,我明明把RC0和RC1定义成输出,但是调试时却不能正常驱动
llljh 发表于 2021-1-18 20:54 | 显示全部楼层
是因为这两个引脚有其他特殊功能吗
supernan 发表于 2021-1-18 20:56 | 显示全部楼层
配置位信息看下
xxrs 发表于 2021-1-18 20:59 | 显示全部楼层
// CONFIG1L
#pragma config RETEN = OFF      // VREG Sleep Enable bit (Ultra low-power regulator is Disabled (Controlled by REGSLP bit))
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
#pragma config SOSCSEL = HIGH   // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
#pragma config XINST = OFF       // Extended Instruction Set (Enabled)
// CONFIG1H
#pragma config FOSC = INTIO2       // Oscillator (HS oscillator (Medium power, 4 MHz - 16 MHz))
#pragma config PLLCFG = ON      // PLL x4 Enable bit (Enabled)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF       // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = OFF     // Power Up Timer (Disabled)
#pragma config BOREN = SBORDIS  // Brown Out Detect (Enabled in hardware, SBOREN disabled)
#pragma config BORV = 3         // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF       // Watchdog Timer (WDT controlled by SWDTEN bit setting)
#pragma config WDTPS = 1048576  // Watchdog Postscaler (1:1048576)
// CONFIG3H
#pragma config CANMX = PORTB    // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
#pragma config MSSPMSK = MSK7   // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON       // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K     // Boot Block Size (2K word Boot Block size)
// CONFIG5L
#pragma config CP0 = OFF        // Code Protect 00800-03FFF (Disabled)
#pragma config CP1 = OFF        // Code Protect 04000-07FFF (Disabled)
#pragma config CP2 = OFF        // Code Protect 08000-0BFFF (Disabled)
#pragma config CP3 = OFF        // Code Protect 0C000-0FFFF (Disabled)
// CONFIG5H
#pragma config CPB = OFF        // Code Protect Boot (Disabled)
#pragma config CPD = OFF        // Data EE Read Protect (Disabled)
// CONFIG6L
#pragma config WRT0 = OFF       // Table Write Protect 00800-03FFF (Disabled)
#pragma config WRT1 = OFF       // Table Write Protect 04000-07FFF (Disabled)
#pragma config WRT2 = OFF       // Table Write Protect 08000-0BFFF (Disabled)
#pragma config WRT3 = OFF       // Table Write Protect 0C000-0FFFF (Disabled)
// CONFIG6H
#pragma config WRTC = OFF       // Config. Write Protect (Disabled)
#pragma config WRTB = OFF       // Table Write Protect Boot (Disabled)
#pragma config WRTD = OFF       // Data EE Write Protect (Disabled)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protect 00800-03FFF (Disabled)
#pragma config EBTR1 = OFF      // Table Read Protect 04000-07FFF (Disabled)
#pragma config EBTR2 = OFF      // Table Read Protect 08000-0BFFF (Disabled)
#pragma config EBTR3 = OFF      // Table Read Protect 0C000-0FFFF (Disabled)
// CONFIG7H
#pragma config EBTRB = OFF      // Table Read Protect Boot (Disabled)
xxrs 发表于 2021-1-18 21:02 | 显示全部楼层
对了,我也没法这两个端口设置为T1的时钟源,以下是我TMR1的配置信息:
T1CONbits.TMR1CS0 = 0;        //clock source is the system clock (FOSC/4)
  T1CONbits.T1CKPS0 = 0;
  T1CONbits.T1CKPS1 = 0;        //Prescale value = 00  1:1
  T1CONbits.RD16 = 1;           //16bit
  T1CONbits.TMR1ON = 0;        //不使能Timer1
  TMR1H = TMR1_Seted_H;
  TMR1L = TMR1_Seted;
原理图:
                //         PIC18F4580/4585/4680
                //   ----1|MCLR/Vpp/RE3       RX2/RB7/KBI3/PGD|28---
                //   ----2|RA0/AN0/CVref      TX2/RB6/KBI2/PGC|27---
                //   ----3|RA1/AN1           CCP5/RB5/KBI1/PGM|26---
                //   ----4|RA2/AN2/Vref-    ECCP1/RB4/KBI0/AN9|25---
                //   ----5|RA3/AN3/Vref+             RB3/CANRX|24---
                //   ----6|VCAP                           RB2/INT2/CANTX|23---
                //   ----7|RA5/AN4/SS/hlvdin      RB1/INT1/AN8|22---
                //   ----8|Vss                       RB0/INT0/FLT0/AN10|21---
                //   ----9|OSC1/CLKI/RA7                                        Vdd|20---
                //   ---10|OSC2/CLKOU/RA6                              Vss|19---
                //   ---11|RC0/T1OSO/T13CK1          RC7/RX/DT|18---
                //   ---12|RC1/T1OSI                 RC6/TX/CK|17---
                //   ---13|RC2/CCP1                    RC5/SDO|16---
                //   ---14|RC3/SCK/SCL             RC4/SDI/SDA|15---
chenjunt 发表于 2021-1-18 21:04 | 显示全部楼层
配置位没配置好
kangzj 发表于 2021-1-18 21:07 | 显示全部楼层
#pragma config SOSCSEL = DIG    // SOSC Power Selection and mode Configuration bits (Digital (SCLKI) mode)
hanwe 发表于 2021-1-18 21:10 | 显示全部楼层
配置位这个东西,有没有图形化配置的工具。
llia 发表于 2021-1-18 21:13 | 显示全部楼层
MCC听说可以配置字,但是没找到。
 楼主| pengf 发表于 2021-1-18 21:15 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家
奔波儿熊 发表于 2021-1-19 15:20 | 显示全部楼层
配置字不是专门一个图形界面的,一般分散在各个外设里. 如果不需要图形界面,配置字是有一个专门窗口读写的
您没有注意上面各楼层发帖时间的间隔以及发帖者的注册日期吗?  发表于 2021-1-20 10:41
