[STM32F4]
F407 采用串口+DMA采集传感器数据不正确
319|10
houcs|  楼主 | 2021-1-18 22:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
yufe| | 2021-1-18 22:37 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
houcs|  楼主 | 2021-1-18 22:44 | 只看该作者
void USART_Configuration(uint8_t no)
   USART_InitTypeDef USART_InitStructure;
   NVIC_InitTypeDef NVIC_InitStructure;
   DMA_InitTypeDef DMA_InitStruct;
//#if        PRINT_EN
   RCC_AHB1PeriphClockCmd(Open_USART_TX_GPIO_CLK,ENABLE);
   RCC_AHB1PeriphClockCmd(Open_USART_RX_GPIO_CLK,ENABLE);
#if        (USARTx_OPEN == 1 || USARTx_OPEN == 6)
   RCC_APB2PeriphClockCmd(Open_USART_CLK,ENABLE);
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
   RCC_AHB1PeriphResetCmd(RCC_AHB1Periph_DMA2, ENABLE);
   RCC_AHB1PeriphResetCmd(RCC_AHB1Periph_DMA2, DISABLE);
#elif (USARTx_OPEN == 2 || USARTx_OPEN == 3 || USARTx_OPEN == 4 || USARTx_OPEN == 5)
   RCC_APB1PeriphClockCmd(Open_USART_CLK,ENABLE);
#endif
   GPIO_PinAFConfig(Open_USART_TX_GPIO_PORT, Open_USART_TX_SOURCE, Open_USART_TX_AF);
   GPIO_PinAFConfig(Open_USART_RX_GPIO_PORT, Open_USART_RX_SOURCE, Open_USART_RX_AF);
   *  Open_USART_TX -> PA9 , Open_USART_RX -PA10
   GPIO_InitStructure.GPIO_Pin = Open_USART_TX_PIN;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
   GPIO_Init(Open_USART_TX_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin = Open_USART_RX_PIN;
   GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
   GPIO_Init(Open_USART_RX_GPIO_PORT, &GPIO_InitStructure);
                     USARTx configured as follow:
          - BaudRate = 115200 baud
                  - Word Length = 8 Bits
          - One Stop Bit
          - No parity
          - Hardware flow control disabled (RTS and CTS signals)
          - Receive and transmit
   USART_InitStructure.USART_BaudRate = 115200;
   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
   USART_InitStructure.USART_StopBits = USART_StopBits_1;
   USART_InitStructure.USART_Parity = USART_Parity_No;
   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
   USART_Init(Open_USART, &USART_InitStructure);
   /* Enable the Open_USART Transmit interrupt: this interrupt is generated when the
      Open_USART transmit data register is empty */
   (USART_DMAy_Streamx[no-1], DISABLE);
                           //Check if the DMA Stream has been effectively disabled.
                           while (DMA_GetCmdStatus(USART_DMAy_Streamx[no-1]) != DISABLE);
                           //init DMA channel
                           DMA_StructInit(&DMA_InitStruct);
                           DMA_InitStruct.DMA_PeripheralBaseAddr = (uint32_t)&USART_PORT[no-1]->DR;
                           DMA_InitStruct.DMA_Memory0BaseAddr = (uint32_t)&USART_RxBuffer[no-1][0];
                           DMA_InitStruct.DMA_BufferSize = USART_MAX_BUF_LEN;
                           DMA_InitStruct.DMA_Channel = USART_DMA_CHAN[no-1];
                           DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralToMemory;
                           DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
                           DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable;
                           DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
                           DMA_InitStruct.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
                           DMA_InitStruct.DMA_Mode = DMA_Mode_Normal;
                           DMA_InitStruct.DMA_Priority = DMA_Priority_High;
                           DMA_InitStruct.DMA_FIFOMode = DMA_FIFOMode_Disable;
                           DMA_InitStruct.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
                           DMA_InitStruct.DMA_MemoryBurst = DMA_MemoryBurst_Single;
                           DMA_InitStruct.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
                           DMA_Init(USART_DMAy_Streamx[no-1], &DMA_InitStruct);
                           // Enable DMA Stream Transfer Complete interrupt
                           DMA_ITConfig(USART_DMAy_Streamx[no-1], DMA_IT_TC, ENABLE);
                           // DMA Stream enable
                           DMA_Cmd(USART_DMAy_Streamx[no-1], ENABLE);
                           //Check if the DMA Stream has been effectively enabled.
                           while (DMA_GetCmdStatus(USART_DMAy_Streamx[no-1]) != ENABLE);
                           /* Enable the DMA Stream IRQ Channel */
                           NVIC_InitStructure.NVIC_IRQChannel = USART_DMA_IRQn[no-1];
                           NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
                           NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
                           NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
                           NVIC_Init(&NVIC_InitStructure);
                         USART_ITConfig(USART_PORT[no-1], USART_IT_IDLE, ENABLE);
                         USART_ITConfig(Open_USART,USART_IT_RXNE,DISABLE);
                           USART_DMACmd(USART_PORT[no-1], USART_DMAReq_Rx, ENABLE);
                   USART_Cmd(USART_PORT[no-1], ENABLE);
                   USART_NVIC_Config(no);
//                  UartData[no-1].len = 0;
//                  UartData[no-1].callback = callback;
//USART_Cmd(Open_USART, ENABLE);
//  USART_NVIC_Config(USARTx_OPEN);
void USART_IRQHandler(uint8_t no)
         volatile char ch;
         if(no > 6)
                 return;
         CoEnterISR();
         if(USART_GetITStatus(USART_PORT[no-1], USART_IT_RXNE) != RESET)
                 ch = USART_ReceiveData(USART_PORT[no-1]);       // get received character
                 if(UartData[no-1].len >= USART_MAX_BUF_LEN)
                         mem_cpy(&UartData[no-1].data[0], &UartData[no-1].data[1], USART_MAX_BUF_LEN-1);
                         UartData[no-1].data[USART_MAX_BUF_LEN-1] = ch;
                 else
                         UartData[no-1].data[UartData[no-1].len] = ch;
                         UartData[no-1].len += 1;
         else if(USART_GetITStatus(USART_PORT[no-1], USART_IT_IDLE) != RESET)
                 ch = USART_ReceiveData(USART_PORT[no-1]);        //clear IDLE flag by read USART_SR and USART_DR
                 //get received data length
                 UartData[no-1].len = USART_MAX_BUF_LEN - USART_DMAy_Streamx[no-1]->NDTR;
                 mem_cpy(&UartData[no-1].data[0], &USART_RxBuffer[no-1][0], UartData[no-1].len);
                 //analyze the received data and send out the response
                 if(UartData[no-1].callback != NULL)
                         ((void (*)(uint8_t))UartData[no-1].callback)(no);
                 switch(no)
                         case 1:
                         case 6:
                                 break;
                         case 2:
                         case 3:
                         case 4:
                         case 5:
                                 RCC_AHB1PeriphResetCmd(RCC_AHB1Periph_DMA1, ENABLE);
                                 RCC_AHB1PeriphResetCmd(RCC_AHB1Periph_DMA1, DISABLE);
                                 break;
                 //disable DMA
                 DMA_Cmd(USART_DMAy_Streamx[no-1], DISABLE);
                 //init DMA channel
         CoExitISR();
wangzsa| | 2021-1-18 22:44 | 只看该作者
还有什么现象?能再详细描述下吗?
houcs|  楼主 | 2021-1-18 22:47 | 只看该作者
将串口1收到的传感器数据在经过串口1打印输出到屏幕上时,与传感器发送数据对不上;若将触感器直接通过串口工具传到串口调试助手上,数据正常,请问大神问题出在哪里?
qcliu| | 2021-2-5 12:07 | 只看该作者
怎么个不正确法?
tfqi| | 2021-2-5 12:07 | 只看该作者
还能再详细的描述一下吗
wiba| | 2021-2-5 12:40 | 只看该作者
那应该不是串口的问题吧
zljiu| | 2021-2-5 12:44 | 只看该作者
不用dma会有错误吗
coshi| | 2021-2-5 12:46 | 只看该作者
周围环境有没有干扰啊
Prry| | 2021-2-6 10:23 | 只看该作者
参考STM32F1DMA收发实现,1.5M波特率不翻车:https://acuity.blog.csdn.net/article/details/108367512
