AT32F421C8T7外部中断问题
1607|1
 楼主| 骑行青年 发表于 2021-1-21 21:24 | 显示全部楼层 |阅读模式
程序将PB2引脚作为外部中断引脚,程序配置之后,引脚上电平变化时程序不能进入中断处理函数。以下为代码,请各位帮忙看看是否有配置不对的地方。
void check_gpio_init(void)
    GPIO_InitType   GPIO_InitStructure;
    EXTI_InitType        EXTI_InitStructure;
    NVIC_InitType        NVIC_InitStructure;
    RCC_AHBPeriphClockCmd(RCC_AHBPERIPH_GPIOB,ENABLE);
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
    GPIO_InitStructure.GPIO_Pull = GPIO_Pull_NOPULL;
    GPIO_InitStructure.GPIO_MaxSpeed = GPIO_MaxSpeed_50MHz;
    GPIO_InitStructure.GPIO_OutType = GPIO_OutType_PP;
    GPIO_InitStructure.GPIO_Pins = GPIO_Pins_2;
    GPIO_Init(GPIOB,&GPIO_InitStructure);
    SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOB,EXTI_PinSource2);
    EXTI_InitStructure.EXTI_Line = EXTI_Line2;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
        EXTI_InitStructure.EXTI_LineEnable = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
    NVIC_InitStructure.NVIC_IRQChannel = EXTI3_2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
void EXTI3_2_IRQHandler(void)
    if(EXTI_GetIntStatus(EXTI_Line2) != RESET)
                  if(check_pin_read() == RESET)
            irq_count++;
            if(irq_count >= 20)
                fault_status = 0;
                irq_count = 0;
                //device_check_en(DISABLE);
                EXTI_ClearIntPendingBit(EXTI_Line2);
      下载视频
muyichuan2012 发表于 2021-1-21 22:35 来自手机 | 显示全部楼层
直接跑bsp中exti  example试试。
