[应用相关] F407 初始化SD卡
2238|35
jinglixixi 发表于 2021-1-28 22:11 | 显示全部楼层
能上传个使用的例程(Project)就好了。。。
 楼主| junpeng324 发表于 2021-1-29 17:27 | 显示全部楼层
SD_Error CmdResp3Error(void)
  u32 status;
  while(1)
    status = SDIO1->STS;
    if(status & ((1 << 0) | (1 << 2) | (1 << 6))) //CRC错误/命令响应超时/已经收到响应
      break;
  if(SDIO_GetFlagStatus(SDIO1, SDIO_**_CMDTIMEOUT) != RESET) //响应超时
    SDIO_ClearFlag(SDIO1, SDIO_**_CMDTIMEOUT);
    return SD_CMD_RSP_TIMEOUT;
  SDIO_ClearFlag(SDIO1, SDIO_STATIC_FLAGS);
  return SD_OK;
 楼主| junpeng324 发表于 2021-1-29 17:28 | 显示全部楼层
SD_Error CmdResp2Error(void)
  SD_Error errorstatus = SD_OK;
  u32 status;
  u32 timeout = SDIO_CMD0TIMEOUT;
  while(timeout--)
      break;
  if((timeout == 0) || (status & (1 << 2))) //响应超时
    errorstatus = SD_CMD_RSP_TIMEOUT;
    return errorstatus;
  if(SDIO_GetFlagStatus(SDIO1, SDIO_**_CMDFAIL) != RESET)   //CRC错误
    errorstatus = SD_CMD_FAIL;
    SDIO_ClearFlag(SDIO1, SDIO_**_CMDFAIL);
  SDIO_ClearFlag(SDIO1, SDIO_STATIC_FLAGS); //清除所有标记
  return errorstatus;
 楼主| junpeng324 发表于 2021-1-29 17:29 | 显示全部楼层
SD_Error CmdResp4Error(u8 cmd)
  u32 status;
  while(1)
      break;
    return SD_CMD_FAIL;
  if(SDIO1->RSPCMD != cmd) //命令不匹配
    return SD_ILLEGAL_CMD;
  return SD_OK;
SD_Error CmdResp5Error(u8 cmd)
  u32 status;
  while(1)
      break;
    return SD_CMD_FAIL;
  if (SDIO1->RSP1 & SD_R5_OUT_OF_RANGE)
    return SD_CMD_OUT_OF_RANGE;
  if (SDIO1->RSP1 & SD_R5_FUNCTION_NUMBER)
    return SD_SDIO_UNKNOWN_FUNC;
  if (SDIO1->RSP1 & SD_R5_ERROR)
    return SD_GENERAL_UNKNOWN_ERROR;
  return SD_OK;
 楼主| junpeng324 发表于 2021-1-29 17:31 | 显示全部楼层
SD_Error CmdResp6Error(u8 cmd, u16*prca)
  u32 status;
  u32 rspr1;
  while(1)
      break;
    return SD_CMD_FAIL;
  if(SDIO1->RSPCMD != cmd) //判断是否响应cmd命令
  rspr1 = SDIO1->RSP1;
  if(SD_ALLZERO == (rspr1 & (SD_R6_GENERAL_UNKNOWN_ERROR | SD_R6_ILLEGAL_CMD | SD_R6_CMD_CRC_FAILED)))
    *prca = (u16)(rspr1 >> 16);
    return errorstatus;
  if(rspr1 & SD_R6_GENERAL_UNKNOWN_ERROR)
  if(rspr1 & SD_R6_ILLEGAL_CMD)
  if(rspr1 & SD_R6_CMD_CRC_FAILED)
    return SD_CMD_CRC_FAILED;
  return errorstatus;
 楼主| junpeng324 发表于 2021-1-29 17:34 | 显示全部楼层
SD_Error SDEnWideBus(u8 enx)
  u8 arg = 0X00;
  if(enx)
    arg = 0X02;
  else
    arg = 0X00;
  if(SDIO1->RSP1 & SD_CARD_LOCKED) //SD卡处于LOCKED状态
    return SD_LOCK_UNLOCK_FAILED;
  if(SDCardInfo.SD_scr.SD_BUS_WIDTHS)   //支持宽总线
    SDIO_CmdInitStructure.SDIO_Argu = (uint32_t) SDCardInfo.RCA << 16;//发送CMD55+RCA,短响应
    SDIO_CmdInitStructure.SDIO_CmdIdx = SD_CMD_APP_CMD;
    SDIO_CmdInitStructure.SDIO_Resp = SDIO_Rsp_Short;
    SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;
    SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;
    SDIO_SendCommand(SDIO1, &SDIO_CmdInitStructure);
    errorstatus = CmdResp1Error(SD_CMD_APP_CMD);
    if(errorstatus != SD_OK)
      return errorstatus;
    SDIO_CmdInitStructure.SDIO_Argu = arg; //发送ACMD6,短响应,参数:10,4位;00,1位.
    SDIO_CmdInitStructure.SDIO_CmdIdx = SD_CMD_APP_SD_SET_BUSWIDTH;
    errorstatus = CmdResp1Error(SD_CMD_APP_SD_SET_BUSWIDTH);
    return errorstatus;
  else
    return SD_REQ_NOT_APPLICABLE;  //不支持宽总线设置
 楼主| junpeng324 发表于 2021-1-29 17:39 | 显示全部楼层
SD_Error MMC_Switch(u8 set, u8 index, u8 value)
  u32 cardstatus = 0;
  u32 timeout = 0;
  SDIO_CmdInitStructure.SDIO_Argu = (EXT_CSD_Write_byte << 24) | (index << 16) | (value << 8) | set;
  SDIO_CmdInitStructure.SDIO_CmdIdx = SD_CMD_HS_SWITCH;
  errorstatus = CmdResp1Error(SD_CMD_HS_SWITCH);    //等待R1响应
  cardstatus = SDIO1->RSP1;
  if(cardstatus & MMC_SWITCH_ERROR)
    return SD_SWITCH_ERROR;
  timeout = SD_DATATIMEOUT;
  do
    timeout--;
    errorstatus = SD_SendStatus(&cardstatus);
  while(((cardstatus & 0x00000100) == 0) && (timeout > 0)); //检查READY_FOR_DATA位是否置位
  if(timeout == 0)
    return SD_ERROR;
  return errorstatus;
 楼主| junpeng324 发表于 2021-1-29 17:43 | 显示全部楼层
SD_Error SD_Switch(u32 mode, u32 group, u8 value, u8 *resp)
  u8 power;
  u16 blksize;
  if(NULL == resp)
    return SD_INVALID_PARAMETER;
  SDIO1->DTCTRL = 0x0;   //数据控制寄存器清零(关DMA)
  blksize = 64;
  power = convert_from_bytes_to_power_of_two(blksize);
  SDIO_CmdInitStructure.SDIO_Argu =  blksize;
  SDIO_CmdInitStructure.SDIO_CmdIdx = SD_CMD_SET_BLOCKLEN;
  SDIO_SendCommand(SDIO1, &SDIO_CmdInitStructure); //发送CMD16+设置数据长度为blksize,短响应
  errorstatus = CmdResp1Error(SD_CMD_SET_BLOCKLEN); //等待R1响应
    return errorstatus;  //响应错误
  SDIO_DataInitStructure.SDIO_DataBlkSize = power << 4 ; //清除DPSM状态机配置
  SDIO_DataInitStructure.SDIO_DataLen = blksize ;
  SDIO_DataInitStructure.SDIO_DataTimeOut = SD_DATATIMEOUT ;
  SDIO_DataInitStructure.SDIO_DPSM = SDIO_DPSM_Enable;
  SDIO_DataInitStructure.SDIO_TransferDir = SDIO_TransferDir_ToSDIO;
  SDIO_DataInitStructure.SDIO_TransferMode = SDIO_TransferMode_Block;
  SDIO_CmdInitStructure.SDIO_Argu = mode << 31 | 0x00FFFFFF;
  SDIO_CmdInitStructure.SDIO_Argu &= ~(0xF << (group * 4));
  SDIO_CmdInitStructure.SDIO_Argu |= value << (group * 4);
  StopCondition = 0;
  return SDIO_SendDataCommand(&SDIO_CmdInitStructure, &SDIO_DataInitStructure, (u32 *)resp);
 楼主| junpeng324 发表于 2021-1-29 17:57 | 显示全部楼层
SD_Error IsCardProgramming(u8 *pstatus)
  vu32 respR1 = 0, status = 0;
  SDIO_CmdInitStructure.SDIO_Argu = (uint32_t) RCA << 16; //卡相对地址参数
  SDIO_CmdInitStructure.SDIO_CmdIdx = SD_CMD_SEND_STATUS;//发送CMD13
  while(!(status & ((1 << 0) | (1 << 6) | (1 << 2))))
    status = SDIO1->STS;  //等待操作完成
  if(SDIO_GetFlagStatus(SDIO1, SDIO_**_CMDFAIL) != RESET)   //CRC检测失败
    return SD_CMD_FAIL;
  if(SDIO_GetFlagStatus(SDIO1, SDIO_**_CMDTIMEOUT) != RESET)    //命令超时
  if(SDIO1->RSPCMD != SD_CMD_SEND_STATUS)
  respR1 = SDIO1->RSP1;
  *pstatus = (u8)((respR1 >> 9) & 0x0000000F);
  return SD_OK;
 楼主| junpeng324 发表于 2021-1-29 18:15 | 显示全部楼层
SD_Error SD_SendStatus(u32 *pcardstatus)
  if(pcardstatus == NULL)
    errorstatus = SD_INVALID_PARAMETER;
    return errorstatus;
  SDIO_CmdInitStructure.SDIO_Argu = (uint32_t) RCA << 16;//发送CMD13,短响应
  errorstatus = CmdResp1Error(SD_CMD_SEND_STATUS);  //查询响应状态
    return errorstatus;
  *pcardstatus = SDIO1->RSP1; //读取响应值
  return errorstatus;
 楼主| junpeng324 发表于 2021-1-29 18:16 | 显示全部楼层
SDCardState SD_GetState(void)
  u32 resp1 = 0;
  if(SD_SendStatus(&resp1) != SD_OK)
    return SD_CARD_ERROR;
  else
    return (SDCardState)((resp1 >> 9) & 0x0F);
 楼主| junpeng324 发表于 2021-1-29 18:18 | 显示全部楼层
SD_Error FindSCR(void)
  u32 index = 0;
  u32 *tempscr;
  tempscr = (u32 *) & (SDCardInfo.SD_scr);
  SDIO_CmdInitStructure.SDIO_Argu = (uint32_t)8;     //发送CMD16
  SDIO_CmdInitStructure.SDIO_CmdIdx = SD_CMD_SET_BLOCKLEN; //cmd16
  SDIO_CmdInitStructure.SDIO_Resp = SDIO_Rsp_Short;  //r1
    return errorstatus;
  SDIO_CmdInitStructure.SDIO_CmdIdx = SD_CMD_APP_CMD;//发送CMD55
    return errorstatus;
  SDIO_DataInitStructure.SDIO_DataTimeOut = SD_DATATIMEOUT;
  SDIO_DataInitStructure.SDIO_DataLen = 8;
  SDIO_DataInitStructure.SDIO_DataBlkSize = SDIO_DataBlkSize_8b;  //块大小8byte
  SDIO_DataConfig(SDIO1, &SDIO_DataInitStructure);
  SDIO_CmdInitStructure.SDIO_Argu = 0x0;
  SDIO_CmdInitStructure.SDIO_CmdIdx = SD_CMD_SD_APP_SEND_SCR;   //发送ACMD51
  errorstatus = CmdResp1Error(SD_CMD_SD_APP_SEND_SCR);
    return errorstatus;
  while(!(SDIO1->STS & (SDIO_**_RXERRO | SDIO_**_DTFAIL | SDIO_**_DTTIMEOUT | SDIO_**_DTBLKCMPL | SDIO_**_SBITERR)))
    if(SDIO_GetFlagStatus(SDIO1, SDIO_**_RXBUF) != RESET) //接收FIFO数据可用
      *(tempscr + index) = SDIO_ReadData(SDIO1); //读取FIFO内容
      index++;
  if(SDIO_GetFlagStatus(SDIO1, SDIO_**_DTTIMEOUT) != RESET) //数据超时错误
    SDIO_ClearFlag(SDIO1, SDIO_**_DTTIMEOUT);
    return SD_DATA_TIMEOUT;
  else if(SDIO_GetFlagStatus(SDIO1, SDIO_**_DTFAIL) != RESET)   //数据块CRC错误
    SDIO_ClearFlag(SDIO1, SDIO_**_DTFAIL);
    return SD_DATA_FAIL;
  else if(SDIO_GetFlagStatus(SDIO1, SDIO_**_RXERRO) != RESET)   //接收fifo上溢错误
    SDIO_ClearFlag(SDIO1, SDIO_**_RXERRO);
    return SD_RX_OVERRUN;
  else if(SDIO_GetFlagStatus(SDIO1, SDIO_**_SBITERR) != RESET)  //接收起始位错误
    SDIO_ClearFlag(SDIO1, SDIO_**_SBITERR);
    return SD_START_BIT_ERR;
  return errorstatus;
 楼主| junpeng324 发表于 2021-1-29 21:02 | 显示全部楼层
SD_Error ChangeSpeed(u8 speed)
  u8 SwitchSts[64];
  if (speed > 1)
    return SD_ERROR;
  if((SDIO_STD_CAPACITY_SD_CARD_V1_1 == CardType) || (SDIO_STD_CAPACITY_SD_CARD_V2_0 == CardType) || (SDIO_HIGH_CAPACITY_SD_CARD == CardType)) //判断卡类型
    /* Version 1.01 Card does not support CMD6 */
    if (SDCardInfo.SD_scr.SD_SPEC == 0)
      return SD_ERROR;
    /* Check Group 1 function support speed*/
    errorstatus = SD_Switch(0, 0, speed, SwitchSts);
    if (errorstatus != 0)
      return errorstatus;
    if ((SwitchSts[13] & (1 << speed)) == 0)
      return SD_ERROR;
    errorstatus = SD_Switch(1, 0, speed, SwitchSts);
      return errorstatus;
    /* Read it back for confirmation */
    if ((SwitchSts[16] & 0xF) != speed)
      return SD_ERROR;
  else if(SDIO_HIGH_SPEED_MULTIMEDIA_CARD == CardType)
    errorstatus = MMC_Switch(EXT_CSD_CMD_SET_NORMAL, EXT_CSD_BUS_WIDTH, (u8)speed);
      return errorstatus;
  return errorstatus;
 楼主| junpeng324 发表于 2021-1-29 21:04 | 显示全部楼层
u8 convert_from_bytes_to_power_of_two(u16 NumberOfBytes)
  u8 count = 0;
  while(NumberOfBytes != 1)
    NumberOfBytes >>= 1;
    count++;
  return count;
 楼主| junpeng324 发表于 2021-1-29 21:05 | 显示全部楼层
void SD_DMA_Config(u32*mbuf, u32 bufsize, u32 DMA_DIR)
  DMA_InitType DMA_InitStructure;
  RCC_AHBPeriphClockCmd(RCC_AHBPERIPH_DMA2, ENABLE); //使能DMA2时钟
  DMA_Reset(DMA2_Channel4); //复位DMA2通道4
  DMA_ChannelEnable(DMA2_Channel4, DISABLE); //关闭DMA2通道4
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&SDIO1->BUF;  //DMA外设基地址
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)mbuf;  //DMA内存基地址
  DMA_InitStructure.DMA_Direction = DMA_DIR;  //数据传输方向,从内存读取发送到外设
  DMA_InitStructure.DMA_BufferSize = bufsize / 4; //DMA通道的DMA缓存的大小
  DMA_InitStructure.DMA_PeripheralInc = DMA_PERIPHERALINC_DISABLE;  //外设地址寄存器不变
  DMA_InitStructure.DMA_MemoryInc = DMA_MEMORYINC_ENABLE;  //内存地址寄存器递增
  DMA_InitStructure.DMA_PeripheralDataWidth = DMA_PERIPHERALDATAWIDTH_WORD;  //数据宽度为32位
  DMA_InitStructure.DMA_MemoryDataWidth = DMA_MEMORYDATAWIDTH_WORD; //数据宽度为32位
  DMA_InitStructure.DMA_Mode = DMA_MODE_NORMAL;  //工作在正常缓存模式
  DMA_InitStructure.DMA_Priority = DMA_PRIORITY_HIGH; //DMA通道 x拥有高优先级
  DMA_InitStructure.DMA_MTOM = DMA_MEMTOMEM_DISABLE;  //DMA通道x没有设置为内存到内存传输
  DMA_Init(DMA2_Channel4, &DMA_InitStructure);  //根据DMA_InitStruct中指定的参数初始化DMA的通道USART1_Tx_DMA_Channel所标识的寄存器
  DMA_ChannelEnable(DMA2_Channel4, ENABLE); //开启DMA2 通道4
