[STM32F1]
Tim1输出PWM和串口复用冲突如何解决?
1239|25
ousj| | 2021-2-9 22:40 | 只看该作者
楼主详细说说怎么回事啊,这么说太笼统了
heweibig|  楼主 | 2021-2-9 22:43 | 只看该作者
单片输出PWM只用了PA8脚,串口用到了PA9和PA10,出现串口无法发送数据的情况,查看了TIM1的复用表格,发现和UART1重复,会是这个原因吗?
heweibig|  楼主 | 2021-2-9 22:46 | 只看该作者
程序里注销TIM1的初始化串口就正常了。
langgq| | 2021-2-9 22:49 | 只看该作者
配置看下
heweibig|  楼主 | 2021-2-9 22:53 | 只看该作者
static void TIM1_GPIO_Config(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
static void TIM1_Mode_Config(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        TIM_DeInit(TIM1);
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = Frequency_Max;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 0;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(TIM1, ENABLE);
        TIM_CtrlPWMOutputs(TIM1,ENABLE);
  TIM_Cmd(TIM1, ENABLE);
/******************************串口配置**************************************/
void USART1_Config(void)
        USART_InitTypeDef USART_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        USART_InitStructure.USART_BaudRate = 9600;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        USART_Init(USART1, &USART_InitStructure);
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
        USART_Cmd(USART1, ENABLE);
                /****************************485使能脚初始化************************************/
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
void UART1_NVIC_Configuration(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
liliang9554| | 2021-2-9 22:57 | 只看该作者
zhanghqi| | 2021-2-9 22:59 | 只看该作者
感谢楼主分享,感觉很有使用价值。
jlyuan| | 2021-2-9 23:04 | 只看该作者
PA9应该是TX管脚,配置成输出模式就可以 PA10 最好配置成上拉输入输入,查看一下复用表格,
juventus9554| | 2021-2-9 23:06 | 只看该作者
建议定时器和串口都不要开启复用功能 ,根据板子实际情况再去确定,某一个功能是否用复用功能
dingy| | 2021-2-9 23:08 | 只看该作者
主要针对GPIO进行配置 是配置成定时器 还是配置成串口功能 要看好
supernan| | 2021-2-9 23:11 | 只看该作者
复用问题
liuzaiy| | 2021-2-9 23:13 | 只看该作者
程序问题
morrisk| | 2021-2-9 23:16 | 只看该作者
keil编译出错了
heweibig|  楼主 | 2021-2-9 23:20 | 只看该作者
嗯,后来修改一些配置后重新编译几次后偶尔会有可以运行 的出来。
shimx| | 2021-2-9 23:23 | 只看该作者
你好,能给我说下keil改如何配置么,我的也出现了问题
午夜粪车| | 2021-2-9 23:26 | 只看该作者
楼主能说一下怎么解决的吗?
heweibig|  楼主 | 2021-2-9 23:29 | 只看该作者
修改不同的优化等级编译后试试,总有一款适合你。如果没有,那就是你程序上还有问题。
zhaoxqi| | 2021-2-9 23:30 | 只看该作者
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_OCStructInit(&TIM_OCInitStructure);
这样设置缺省值,将PWM的TIM1定时器的复用功能重新默认填充,之前出现不能用的情况,个人认为是串口使用的TIM1通道CH将PWM使用的通道占用了
heweibig|  楼主 | 2021-2-9 23:34 | 只看该作者
嗯,我再好好缕一缕吧,有了好消息及时通知大家
