[技术问答] 关于NUC123 数据参考手册USB 部分疑问
748|0
 楼主| laocuo1142 发表于 2021-3-5 10:20 | 显示全部楼层 |阅读模式
在USB部分 关于端点0~5 在整个寻址空间内部有两个地方,一个是0x020,另一个是0x500,不知道这样的用意是啥?但是库用的是0x500部分地址。
比如:USB_MXPLD0~5
USB_CFGP0~5
6.16.6Page 486 of 532
  • typedef struct
  • * @VAR USBD_EP_T::BUFSEG0
  • * Offset: 0x500/0x510/0x520/0x530/0x540/0x550/0x560/0x570  Endpoint 0~7 Buffer Segmentation Register
  • * |Bits    |Field     |Descriptions
  • * |[8:3]   |BUFSEG    |Endpoint Buffer Segmentation
  • * |        |          |It is used to indicate the offset address for each endpoint with the USB SRAM starting address The effective starting address of the endpoint is
  • * |        |          |USB_SRAM address + { BUFSEG[8:3], 3'b000}
  • * |        |          |Where the USB_SRAM address = USBD_BA+0x100h.
  • * @var USBD_EP_T::MXPLD0
  • * Offset: 0x504/0x514/0x524/0x534/0x544/0x554/0x564/0x574  Endpoint 0~7 Maximal Payload Register
  • * |[8:0]   |MXPLD     |Maximal Payload
  • * |        |          |Define the data length which is transmitted to host (IN token) or the actual data length which is received from the host (OUT token).
  • * |        |          |It also used to indicate that the endpoint is ready to be transmitted in IN token or received in OUT token.
  • * |        |          |(1) When the register is written by CPU,
  • * |        |          |For IN token, the value of MXPLD is used to define the data length to be transmitted and indicate the data buffer is ready.
  • * |        |          |For OUT token, it means that the controller is ready to receive data from the host and the value of MXPLD is the maximal data length comes from host.
  • * |        |          |(2) When the register is read by CPU,
  • * |        |          |For IN token, the value of MXPLD is indicated by the data length be transmitted to host
  • * |        |          |For OUT token, the value of MXPLD is indicated the actual data length receiving from host.
  • * |        |          |Note: Once MXPLD is written, the data packets will be transmitted/received immediately after IN/OUT token arrived.
  • * @var USBD_EP_T::CFG0
  • * Offset: 0x508/0x518/0x528/0x538/0x548/0x558/0x568/0x578  Endpoint 0~7 Configuration Register
  • * |[3:0]   |EP_NUM    |Endpoint Number
  • * |        |          |These bits are used to define the endpoint number of the current endpoint.
  • * |[4]     |ISOCH     |Isochronous Endpoint
  • * |        |          |This bit is used to set the endpoint as Isochronous endpoint, no handshake.
  • * |        |          |0 = No Isochronous endpoint.
  • * |        |          |1 = Isochronous endpoint.
  • * |[6:5]   |STATE     |Endpoint STATE
  • * |        |          |00 = Endpoint is Disabled.
  • * |        |          |01 = Out endpoint.
  • * |        |          |10 = IN endpoint.
  • * |        |          |11 = Undefined.
  • * |[7]     |DSQ_SYNC  |Data Sequence Synchronization
  • * |        |          |0 = DATA0 PID.
  • * |        |          |1 = DATA1 PID.
  • * |        |          |Note: It is used to specify the DATA0 or DATA1 PID in the following IN token transaction.
  • * |        |          |Hardware will toggle automatically in IN token base on the bit.
  • * |[9]     |CSTALL    |Clear STALL Response
  • * |        |          |0 = Disable the device to clear the STALL handshake in setup stage.
  • * |        |          |1 = Clear the device to response STALL handshake in setup stage.
  • * @var USBD_EP_T::CFGP0
  • * Offset: 0x50C/0x51C/0x52C/0x53C/0x54C/0x55C/0x56C/0x57C  Endpoint 0~7 Set Stall and Clear In/Out Ready Control Register
  •     * |[0]     |CLRRDY    |Clear Ready
  •     * |        |          |When the USB_MXPLD register is set by user, it means that the endpoint is ready to transmit or receive data.
  •     * |        |          |If the user wants to turn off this transaction before the transaction start, users can set this bit to 1 to turn it off and it will be cleared to 0 automatically.
  •     * |        |          |For IN token, write '1' to clear the IN token had ready to transmit the data to USB.
  •     * |        |          |For OUT token, write '1' to clear the OUT token had ready to receive the data from USB.
  •     * |        |          |This bit is write 1 only and is always 0 when it is read back.
  •     * |[1]     |SSTALL    |Set STALL
  •     * |        |          |0 = Disable the device to response STALL.
  •     * |        |          |1 = Set the device to respond STALL automatically.
  •     __IO uint32_t BUFSEG;        /* Offset: 0x500/0x510/0x520/0x530/0x540/0x550/0x560/0x570  Endpoint 0~7 Buffer Segmentation Register */
  •     __IO uint32_t MXPLD;         /* Offset: 0x504/0x514/0x524/0x534/0x544/0x554/0x564/0x574  Endpoint 0~7 Maximal Payload Register */
  •     __IO uint32_t CFG;           /* Offset: 0x508/0x518/0x528/0x538/0x548/0x558/0x568/0x578  Endpoint 0~7 Configuration Register */
  •     __IO uint32_t CFGP;          /* Offset: 0x50C/0x51C/0x52C/0x53C/0x54C/0x55C/0x56C/0x57C  Endpoint 0~7 Set Stall and Clear In/Out Ready Control Register */
  • } USBD_EP_T;
复制代码
