[MM32软件] Peli can
1445|8
 楼主| faithai 发表于 2021-4-1 17:30 | 显示全部楼层 |阅读模式
请大神帮忙看看 图片中peli_transmit_message的值为何不能成功赋给CAN1_PELI呢
感激不尽
我的CAN 配置函数如下
static void CAN_GPIO_Config(void)
    NVIC_InitTypeDef    NVIC_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1ENR_CAN, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
    //CAN RX PA11
    RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
    GPIO_StructInit(&GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_11;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_FLOATING;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    //CAN TX PA12
    GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_12;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource11, GPIO_AF_4);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource12, GPIO_AF_4);
    NVIC_InitStructure.NVIC_IRQChannel = CAN_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
void CAN_Config(u32 CAN_Pre, CAN_Mode ID, u32 idCode1, u32 idCode2, u32 mask1, u32 mask2)
    CAN_Peli_InitTypeDef          CAN_Peli_InitStructure;
    RCC_ClocksTypeDef             RCC_Clocks;
    u32 idCodeTemp1, idMaskTemp1;
    u32 idCodeTemp2, idMaskTemp2;
    CAN_Peli_FilterInitTypeDef    CAN_Peli_FilterInitStructure;
    //Enter reset mode
    CAN_ResetMode_Cmd(CAN1, ENABLE);
    //CAN enters Peli mode
    CAN_Mode_Cmd(CAN1, CAN_PELIMode);
    RCC_GetClocksFreq(&RCC_Clocks);
    CAN_Peli_StructInit(&CAN_Peli_InitStructure);
    CAN_Peli_FilterStructInit(&CAN_Peli_FilterInitStructure);
    CAN_AutoCfg_BaudParam( &CAN_Peli_InitStructure, RCC_Clocks.PCLK1_Frequency, CAN_Pre);
    //sampling point
    CAN_Peli_InitStructure.SAM = RESET;
    //Self-test mode
    CAN_Peli_InitStructure.STM = DISABLE;
    //Listen to model
    CAN_Peli_InitStructure.LOM = DISABLE;
    //  CAN_Peli_InitStructure.EWLR = 0x96;
    CAN_Peli_Init(&CAN_Peli_InitStructure);
    switch(ID) {
        case StandardFrame_SingleFilter:
            idCodeTemp1 = idCode1 << (3 + 18);
            idMaskTemp1 = mask1 << (3 + 18);
            CAN_Peli_FilterInitStructure.AFM = CAN_FilterMode_Singal;
            CAN_Peli_FilterInitStructure.CAN_FilterId0 = (idCodeTemp1 >> 24) & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterId1 = (idCodeTemp1 >> 16) & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterId2 = (idCodeTemp1 >> 8) & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterId3 = (idCodeTemp1 >> 0) & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId0 = (idMaskTemp1 >> 24) & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId1 = ((idMaskTemp1 >> 16) & 0xff) | 0x1f;
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId2 = ((idMaskTemp1 >> 8) & 0xff) | 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId3 = ((idMaskTemp1 >> 0) & 0xff) | 0xff;
            break;
        case ExtendedFrame_SingleFilter:
            idCodeTemp1 = idCode1 << 3;
            idMaskTemp1 = mask1 << 3;
            CAN_Peli_FilterInitStructure.CAN_FilterId3 = idCodeTemp1 & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId1 = ((idMaskTemp1 >> 16) & 0xff);
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId2 = ((idMaskTemp1 >> 8) & 0xff);
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId3 = ((idMaskTemp1 >> 0) & 0xff);
            break;
        case StandardFrame_DoubleFilter:
            idCodeTemp2 = idCode2 << (3 + 18);
            idMaskTemp2 = mask2 << (3 + 18);
            CAN_Peli_FilterInitStructure.AFM = CAN_FilterMode_Double;
            CAN_Peli_FilterInitStructure.CAN_FilterId2 = (idCodeTemp2 >> 24) & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterId3 = (idCodeTemp2 >> 16) & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId2 = (idMaskTemp2 >> 24) & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId3 = ((idMaskTemp2 >> 16) & 0xff) | 0x1f;
            break;
        case ExtendedFrame_DoubleFilter:
            idCodeTemp1 = idCode1 << (3);
            idMaskTemp1 = mask1 << (3);
            idCodeTemp2 = idCode2 << (3);
            idMaskTemp2 = mask2 << (3);
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId1 = (idMaskTemp1 >> 16) & 0xff;
            CAN_Peli_FilterInitStructure.CAN_FilterMaskId3 = (idMaskTemp2 >> 16) & 0xff;
            break;
        default:
            break;
    CAN_Peli_FilterInit(&CAN_Peli_FilterInitStructure);
    CAN_Peli_ITConfig(CAN_IT_RI, ENABLE);
    //Exit reset mode and enter working mode
    CAN_ResetMode_Cmd(CAN1, DISABLE);
正圆椭圆 发表于 2021-4-1 23:33 | 显示全部楼层
帮忙顶一下 暂时没看出来哪有问题
BettyBerry 发表于 2021-4-1 23:42 | 显示全部楼层
用的是仿真吗还是哪个板子
索尼法 发表于 2021-4-2 23:46 | 显示全部楼层
这个用的应该是仿真把
 楼主| faithai 发表于 2021-4-5 11:38 | 显示全部楼层
这个用的应该是仿真把
对,仿真,,仿真不一样吗
用的是仿真吗还是哪个板子
对,仿真,,仿真不一样吗
随风而去吧 发表于 2021-4-10 10:04 | 显示全部楼层
每日要进步,要加油
yangjiaxu 发表于 2021-5-23 19:27 | 显示全部楼层
要硬件仿真才可以 软件仿真有些时候不准确
piteqiu 发表于 2021-5-24 11:04 | 显示全部楼层
我觉得以串口输出的寄存器信息为准,实时仿真到的可能变化不及时。
