[STM32F0]
tim1 ch2 通道捕获不进捕获中断
946|16
chuxh|  楼主 | 2021-4-1 20:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
tim1 ch2 通道捕获不进捕获中断
stly| | 2021-4-1 20:52 | 只看该作者
楼主详细说说怎么回事啊,这么说太笼统了
pengf| | 2021-4-1 20:54 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
chuxh|  楼主 | 2021-4-1 20:56 | 只看该作者
TIM_ICInitTypeDef  TIM_ICInitStructure;
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_DeInit(TIM1);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
  TIM_TimeBaseStructure.TIM_Prescaler = 8 - 1;                       //8·ÖƵ(Óë²¶»ñ·ÖƵÏàͬ)
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;        //ÏòÉϼÆÊýģʽ
  TIM_TimeBaseStructure.TIM_Period = 0xFFFFFFFF;                     //¶¨Ê±ÖÜÆÚ(×Ô¶¯´Ó×°ÔØ¼Ä´æÆ÷ARRµÄÖµ)
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;            //ʱÖÓ·ÖÆµÒò×Ó
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
    TIM_ITConfig(TIM1,TIM_IT_Update|TIM_IT_CC2,ENABLE);
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;                   //ͨµÀ2
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;        //²¶»ñ¼«ÐÔ
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;    //²¶»ñÑ¡Ôñ
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV8;              //²¶»ñ·ÖƵ
  TIM_ICInitStructure.TIM_ICFilter = 0x0;                              //²¶»ñÂ˲¨
  TIM_ICInit(TIM1, &TIM_ICInitStructure);
  TIM_Cmd(TIM1, ENABLE);
void TIMER_IC_GPIO_Configuration(void)
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA   ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;                          //LEDÒý½Å
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;                       //¸´ÓÃģʽ
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                  //¸ßËÙÊä³ö
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;                     //ÍÆÍêÊä³ö
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;                   //ÎÞÉÏÏÂÀ­(¸¡¿Õ)
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_2);               //¸´ÓÃÅäÖÃ
void TIM1_CC_IRQHandler(void)
if(TIM_GetITStatus(TIM1, TIM_IT_CC2) != RESET)
        TIM_ClearFlag(TIM1, TIM_IT_CC2);
chuxh|  楼主 | 2021-4-1 20:58 | 只看该作者
如果把  TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;   屏蔽之后会一直进捕获中断,不屏蔽,一次也不进
zhanghqi| | 2021-4-1 21:00 | 只看该作者
很奇怪的问题
zhenykun| | 2021-4-1 21:03 | 只看该作者
别的通道可以进?
jlyuan| | 2021-4-1 21:04 | 只看该作者
总中断开启了吗
chuxh|  楼主 | 2021-4-1 21:07 | 只看该作者
寄存器是什么状态
juventus9554| | 2021-4-1 21:08 | 只看该作者
换一个通道试试看
stly| | 2021-4-1 21:10 | 只看该作者
io口设置了吗
dingy| | 2021-4-1 21:12 | 只看该作者
没看到你的NVIC的中断设置代码。
supernan| | 2021-4-1 21:14 | 只看该作者
官方的外设库里有几乎一样的例程,参照一下很快就能实现了
jiajs| | 2021-4-1 21:16 | 只看该作者
stm32f0_stdperiph_lib 1.31\STM32F0xx_StdPeriph_Lib_V1.3.1\Projects\STM32F0xx_StdPeriph_Examples\TIM\TIM_InputCapture
chuxh|  楼主 | 2021-4-1 21:17 | 只看该作者
好的,我明天去单位试一下,多谢各位大侠了哈
磨砂| | 2021-5-1 11:03 | 只看该作者
需要看看详细的代码
晓伍| | 2021-5-1 11:07 | 只看该作者
初始化代码出现问题了吧
