另外请教前辈,我的R7R9的阻值的选取可有问题?我有看到有人说R7不要超过240Ω的说法。但是看ON的论坛上看到他们家的工程师有说,这个阻值的选取几乎是没有限制的,相反如果你选取的太小,会有很多电流无效损耗。
There is almost no limitation on the value of that resistor ..
Just keep in mind that the voltage across it is constant – very close to 1.25V – so the current through it will be determined by 1.25/R formula, which in fact is used in the “constant current” configuration ..
But if you use smaller resistor than is required for normal operation you will allow more current to flow through the wasteful path ..
