[应用相关] 用STM32F103的timer3输出PWM,输出时间有问题
659|8
 楼主| probedog 发表于 2021-4-20 16:20 | 显示全部楼层 |阅读模式
我用STM32F103的timer3输出PWM,在更新中断里通过改变PrescalerValue来频率,但是输出时间有问题啊,在中断里我设置的应该是6s就会点亮(熄灭)一个LED,此LED引脚用于DIR控制,但是实际30多秒才会变。程序比较简单,是个很笨的方法,请前辈们帮帮忙看一下吧,非常感谢了。
main函数的相关程序:
#include "stm32f10x.h"
#include "stm32f10x_tim.h"
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
uint16_t PrescalerValue = 0x1c1f;                                //预分频值=7200,f=10000
uint16_t cishu=0;                                                        //记录中断次数
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
int main(void)
/* System clocks Configuration */
  RCC_Configuration();
  /* GPIO Configuration */
  GPIO_Configuration();
  NVIC_Configuration();
TIM_TimeBaseStructure.TIM_Period = 0x0063;         //ARR=100 10ms
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  //TIM_TimeBaseStructure.TIM_Prescaler = 0x1c1f;            //预分频值=10000
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上计数
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0;      //每次溢出都产生事件更新
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_CleaRFlag(TIM3,TIM_FLAG_Update);          //中断标志位清零
  TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);       //允许更新中断
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 0x0032;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM3, ENABLE);
  /* TIM3 enable counter */
  TIM_Cmd(TIM3, ENABLE);
while (1)
  /* TIM3 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOF |
                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE);
  //GPIO_InitTypeDef GPIO_InitStructure;
#ifdef STM32F10X_CL
  /*GPIOB Configuration: TIM3 channel1, 2, 3 and 4 */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_PinRemapConfig(GPIO_FullRemap_TIM3, ENABLE);
#else
  /* GPIOA Configuration:TIM3 Channel1, 2, 3 and 4 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 ;          //timer3的ch1输出
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;          //DIR控制  PF7
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOF, &GPIO_InitStructure);
  GPIO_SetBits(GPIOF,GPIO_Pin_7);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;         //EN控制   PF6
  GPIO_SetBits(GPIOF,GPIO_Pin_6);
#endif
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn ;  //选择定时器TIM3
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;          //选择抢先式优先级(与中断嵌套级别有关)
NVIC_InitStructure.NVIC_IRQChannelSubPriority        = 1;       //选择子优先级(同抢先式优先级的响应顺序)
NVIC_InitStructure.NVIC_IRQChannelCmd                = ENABLE;    //选择使能中断源
NVIC_Init(&NVIC_InitStructure);
中断程序如下:
void TIM3_IRQHandler(void)
   uint16_t i;
   i=++cishu;
   if ( TIM_GetITStatus(TIM3 , TIM_IT_Update) != RESET )     //自己的程序
  TIM_ClearITPendingBit(TIM3 , TIM_FLAG_Update);
  if(i<50)                                                   //f=100,10ms,50次=0.5s
     TIM_TimeBaseStructureit.TIM_Prescaler = 0x1c1f  ;     //7200
   else if(49<i&&i<150)                                              //f=200,5ms,100次=0.5s
     TIM_TimeBaseStructureit.TIM_Prescaler = 0x0e0f ;      //3600
   else if(149<i&&i<400)                                            //f=500,2ms,250次=0.5s
     TIM_TimeBaseStructureit.TIM_Prescaler = 0x059f ;      //1440
   else if(399<i&&i<3400)                                           //f=1000,1ms,3000次=3s
    TIM_TimeBaseStructureit.TIM_Prescaler = 0x02cf ;      //720
   else if(3399<i&&i<3650)                                              //f=500,2ms,250次=0.5s
    TIM_TimeBaseStructureit.TIM_Prescaler = 0x059f;
   else if(3649<i&&i<3750)                                             //f=200,5ms,100次=0.5s
    TIM_TimeBaseStructureit.TIM_Prescaler = 0x0e0f;
   else if(3749<i&&i<3800)                                             //f=100,10ms,50次=0.5s
    TIM_TimeBaseStructureit.TIM_Prescaler = 0x1c1f;
   else if(3799<i&&i<3850)                                                  //反转
     GPIO_ResetBits(GPIOF,GPIO_Pin_7);
     TIM_TimeBaseStructureit.TIM_Prescaler =0x1c1f;
   else if(3849<i&&i<3950)                                              //f=200,5ms,100次=0.5s
   else if(3949<i&&i<4200)                                            //f=500,2ms,250次=0.5s
   else if(4199<i&&i<7200)                                           //f=1000,1ms,3000次=3s
   else if(7199<i&&i<7450)                                              //f=500,2ms,250次=0.5s
    TIM_TimeBaseStructureit.TIM_Prescaler =0x059f;
   else if(7449<i&&i<7550)                                             //f=200,5ms,100次=0.5s
     TIM_TimeBaseStructureit.TIM_Prescaler =0x0e0f;
   else if(7549<i&&i<7600)                                             //f=100,10ms,50次=0.5s
   else if(i==7600)                                                  //再反转
     cishu=0;
  else {TIM_TimeBaseStructureit.TIM_Prescaler =0x1c1f;}
最后先谢谢大家了,帮帮忙。
onlycook 发表于 2021-4-20 16:25 | 显示全部楼层
TIM_TimeBaseStructureit.TIM_Prescaler=psc中断里根本没有改变TIM3->PSC寄存器的值,可以自己在主函数里不断查询TIM3->PSC这个寄存器看它的只有没有变,可以直接将中断里的结构体成员变量赋值改为寄存器赋值即TIM3->PSC=psc,然后再试试看效果。
内政奇才 发表于 2021-4-20 16:25 | 显示全部楼层
这个要重新初始化。
麻花油条 发表于 2021-4-20 16:28 | 显示全部楼层
0.5V是示波器测的峰峰值,还是万用表测的有效值?
木木guainv 发表于 2021-5-8 13:40 | 显示全部楼层
这个寄存器的值可以写入吗
磨砂 发表于 2021-5-8 13:42 | 显示全部楼层
每次都要重新初始化不成?
晓伍 发表于 2021-5-8 13:43 | 显示全部楼层
改变的时候什么时候生效呢
八层楼 发表于 2021-5-8 13:46 | 显示全部楼层
是不是跑系统耽搁了时间啊
观海 发表于 2021-5-8 13:48 | 显示全部楼层
这个数值是峰峰值还是有效值啊
