GD32F150的timer2输入捕获进不了中断
1478|5
 楼主| flasherman 发表于 2021-4-27 14:19 | 显示全部楼层 |阅读模式
void TIM2_init(void)
rcu_periph_clock_enable(RCU_GPIOA);
        gpio_deinit(GPIOA);
        /**************Pulse Input******************/
        gpio_mode_set(GPIOA,GPIO_MODE_AF,GPIO_PUPD_NONE,GPIO_PIN_6);
        gpio_af_set(GPIOA,GPIO_AF_1,GPIO_PIN_6);
                timer_parameter_struct    TIM2_BaseInitStructure;
                timer_ic_parameter_struct TIM2_CaptureInitStructure;
                rcu_periph_clock_enable(RCU_TIMER2);
                timer_deinit(TIMER2);
                TIM2_BaseInitStructure.prescaler          = 225;
                TIM2_BaseInitStructure.alignedmode         = TIMER_COUNTER_EDGE;
                TIM2_BaseInitStructure.counterdirection    = TIMER_COUNTER_UP;
                TIM2_BaseInitStructure.clockdivision       = TIMER_CKDIV_DIV1;
                TIM2_BaseInitStructure.repetitioncounter   = 0;
                TIM2_BaseInitStructure.period              = 0xFFFFFFFF;
                timer_init(TIMER2,&TIM2_BaseInitStructure);
                TIM2_CaptureInitStructure.icpolarity    = TIMER_IC_POLARITY_RISING;
                TIM2_CaptureInitStructure.icselection   = TIMER_IC_SELECTION_DIRECTTI;
                TIM2_CaptureInitStructure.icprescaler   = TIMER_IC_PSC_DIV2;
                TIM2_CaptureInitStructure.icfilter      = 15;
                timer_input_capture_config(TIMER2,TIMER_CH_0,&TIM2_CaptureInitStructure);
                //timer_auto_reload_shadow_enable(TIMER2);
                timer_interrupt_flag_clear(TIMER2,TIMER_INT_FLAG_CH0);
                timer_interrupt_enable(TIMER2,TIMER_INT_CH0);
                nvic_irq_enable(TIMER2,2,1);
                timer_enable(TIMER2);
 楼主| flasherman 发表于 2021-4-27 14:22 | 显示全部楼层
void TIMER2_IRQHandler(void)
        if(timer_interrupt_flag_get(TIMER2, TIMER_INT_FLAG_CH0)!= RESET)
                timer_interrupt_flag_clear(TIMER2, TIMER_INT_FLAG_CH0);
        if(timer_interrupt_flag_get(TIMER2, TIMER_INT_FLAG_UP)!= RESET)
                timer_interrupt_flag_clear(TIMER2, TIMER_INT_FLAG_UP);
 楼主| flasherman 发表于 2021-4-27 14:36 | 显示全部楼层
另一只脚的timer1同样配置,是好的,有谁知道是哪里的问题吗
 楼主| flasherman 发表于 2021-4-27 14:42 | 显示全部楼层
中断标志都有,就是进不了中断
sonicll 发表于 2021-4-27 15:30 | 显示全部楼层
nvic_irq_enable(TIMER2,2,1); 这条语句写错了,要写中断向量编号,不是定时器编号
nvic_irq_enable(TIMER2_IRQn, 2, 1);
 楼主| flasherman 发表于 2021-4-27 18:18 | 显示全部楼层
nvic_irq_enable(TIMER ...
是的,就是这个问题
