STM32的基本TIM在进行PWM捕获时候不能两个通道同时用?
6376|10
 楼主| b57835o 发表于 2012-3-3 20:14 | 显示全部楼层 |阅读模式
我的芯片是STM32F103ZET6 打算使用TIM4进行PWM信号的捕获,从手册得知是绑定Channel1和Channel2 Channel3和Channel4 CC1和CC3捕获高电平 CC2和CC4捕获低电平 但是在实际编码中,在线调试发现始终是CC1/2在工作,CC3/4处于冻结状态,这样就无法采集Channel2所输入的信号。尝试过修改TIM的捕获设置的每个选项,发现没有效果,不知道问题所在。我的代码如下:
#include "stm32f10x.h"
#include "stm32f10x_usart.h"
#include "stm32f10x_tim.h"
TIM_OCInitTypeDef TIM_OCInitStructure;
void Rcc_Configuration(void);
void NVIC_Configuration(void);
void GPIO_Config(void);
void TIM_Configuration(void);
void Delay(uint32_t nCounts);
int IC2Value = 0;
int main ()
Rcc_Configuration();
NVIC_Configuration();
GPIO_Config();
TIM_Configuration();
while(1)
SystemInit();
//启动GPIO
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE,ENABLE);
//启动AFIO
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
//启动TIM4
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE);
void NVIC_Configuration()
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;                     //NVIC配置
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
u32 uCounts = nCounts;
for(;nCounts > 0;nCounts--)
for(;uCounts > 0;uCounts--);
//TIM4 PB7 CH2  PB9 CH4
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_8|GPIO_Pin_7|GPIO_Pin_9;                               //GPIO配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//LED
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOE, &GPIO_InitStructure);
TIM_TimeBaseInitTypeDef TIM_BaseInitStructure;
TIM_ICInitTypeDef TIM_ICInitStructure;
//TIM4设置
//时基设置
TIM_BaseInitStructure.TIM_Prescaler = 36-1;
TIM_BaseInitStructure.TIM_ClockDivision = 0;
TIM_BaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_BaseInitStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM4,&TIM_BaseInitStructure);
TIM_ICInitStructure.TIM_Channel = TIM_Channel_2|TIM_Channel_4;                   //通道选择
TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;       //上升沿触发
TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI ;    //管脚与寄存器对应关系
TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;           //输入预分频。
TIM_ICInitStructure.TIM_ICFilter = 0x0;                            //滤波设置,经历几个周期跳变认定波形稳定0x0~0xF
TIM_PWMIConfig(TIM4, &TIM_ICInitStructure);                 //根据参数配置TIM外设信息
TIM_SelectInputTrigger(TIM4, TIM_TS_TI1FP1|TIM_TS_TI2FP2);                //选择IC1,2为触发源      这里不大懂触发源是怎么分配到捕获单元的
TIM_SelectSlaveMode(TIM4, TIM_SlaveMode_Reset);//TIM从模式:触发信号的上升沿重新初始化计数器和触发寄存器的更新事件
TIM_SelectMasterSlaveMode(TIM4, TIM_MasterSlaveMode_Enable); //启动定时器的被动触发
TIM_Cmd(TIM4, ENABLE);                                 //启动TIM4
TIM_ITConfig(TIM4, TIM_IT_CC2|TIM_IT_CC4, ENABLE);     //打开中断
中断处理函数:
void TIM4_IRQHandler(void)
  extern u16 IC2Value;
  if(TIM_GetITStatus(TIM4,TIM_IT_CC1) == SET)
TIM_ClearITPendingBit(TIM4, TIM_IT_CC1);                //清楚TIM的中断待处理位
IC2Value = TIM_GetCapture1(TIM4);
  }else if(TIM_GetITStatus(TIM4,TIM_IT_CC4) == SET)
TIM_ClearITPendingBit(TIM4, TIM_IT_CC4);                //清楚TIM的中断待处理位
IC2Value = TIM_GetCapture4(TIM4);
 楼主| b57835o 发表于 2012-3-4 11:57 | 显示全部楼层
为什么只有人看没人回呢?难道是我的代码贴的太长了?
香水城 发表于 2012-3-4 11:59 | 显示全部楼层
STM32的基本TIM在进行PWM捕获时候不能两个通道同时用!
arm菜鸟人 发表于 2012-3-4 12:33 | 显示全部楼层
怎么用TIM进行外部信号捕获呢?
比如一个方波信号每个周期中断一下。
 楼主| b57835o 发表于 2012-3-4 19:30 | 显示全部楼层
3# 香水城 感谢版主,追问一下,基本定时器不可以的话,高级定时器如TIM1 TIM8 是可以多路PWM捕获吗?可以几路?STM32F103ZET6
香水城 发表于 2012-3-5 14:05 | 显示全部楼层
高级定时器也只能进行一路PWM捕获。
heuyck 发表于 2012-3-15 12:13 | 显示全部楼层
使用PWM捕获貌似每路需要两个通道采样,一个通道采样上升沿,一个通道采样下降沿。
我是把每个通道都配置成上升下降沿触发,然后在中断里面读IO口状态。
比如有中断时读IO是高,就说明是低电平跳到高电平,是上升沿。
这样每路只需要一个通道来采样。
liugp25 发表于 2012-3-16 11:13 | 显示全部楼层
学习下
AProgrammer 发表于 2023-12-2 13:56 | 显示全部楼层
楼主问题解决了吗?我也遇到了一个类似的问题
probedog 发表于 2023-12-4 15:21 | 显示全部楼层
检查一下硬件配置
stormwind123 发表于 2023-12-4 15:22 | 显示全部楼层
检查你的代码中TIM的初始化函数和中断处理函数的配置是否正确。特别是要注意捕获模式的选择和中断优先级的设置。
童雨竹 发表于 2024-8-21 07:10 | 显示全部楼层
代码量小的时候用来做条件判断
Wordsworth 发表于 2024-8-21 08:13 | 显示全部楼层
在直流电流上叠加了一些小的交流电流分量
Clyde011 发表于 2024-8-21 09:16 | 显示全部楼层
连接点是产生控制IC所要检测的小电压的所有器件的公共连接点
公羊子丹 发表于 2024-8-21 10:09 | 显示全部楼层
这是个再正常不过的coding习惯
万图 发表于 2024-8-21 11:12 | 显示全部楼层
宽度则与电感量和电阻量成反比
Uriah 发表于 2024-8-21 12:15 | 显示全部楼层
电流要增大
帛灿灿 发表于 2024-8-21 14:11 | 显示全部楼层
有些信号包含丰富的高频分量
Bblythe 发表于 2024-8-21 15:14 | 显示全部楼层
交流电流环路的布线要在其他引线之前布好
周半梅 发表于 2024-8-21 17:10 | 显示全部楼层
对于优秀程序员来说,这不是好代码
