【提问】PIC16F15345外部辅助振荡器无法起振
1122|2
 楼主| 永远不停 发表于 2021-5-10 19:03 | 显示全部楼层 |阅读模式
如题,需要用到外部32K辅助振荡器,在SOSCO和SOSCI引脚间接入32K晶体
配置字里FEXTOSC 选为 LP(优化为32.768 kHz
#pragma config FEXTOSC = LP    // External Oscillator mode selection bits->Oscillator not enabled
#pragma config RSTOSC = HFINT1    // Power-up default value for COSC bits->HFINTOSC (1MHz)
#pragma config CLKOUTEN = OFF    // Clock Out Enable bit->CLKOUT function is disabled; i/o or oscillator function on OSC2
#pragma config CSWEN = ON    // Clock Switch Enable bit->Writing to NOSC and NDIV is allowed
#pragma config FCMEN = ON   // Fail-Safe Clock Monitor Enable bit->FSCM timer enabled
// CONFIG2
#pragma config MCLRE = ON    // Master Clear Enable bit->MCLR pin is Master Clear function
#pragma config PWRTE = OFF    // Power-up Timer Enable bit->PWRT disabled
#pragma config LPBOREN = OFF    // Low-Power BOR enable bit->ULPBOR disabled
#pragma config BOREN = OFF    // Brown-out reset enable bits->Brown-out Reset Enabled, SBOREN bit is ignored
#pragma config BORV = LO    // Brown-out Reset Voltage Selection->Brown-out Reset Voltage (VBOR) set to 1.9V on LF, and 2.45V on F Devices
#pragma config ZCD = OFF    // Zero-cross detect disable->Zero-cross detect circuit is disabled at POR.
#pragma config PPS1WAY = ON    // Peripheral Pin Select one-way control->The PPSLOCK bit can be cleared and set only once in software
#pragma config STVREN = ON    // Stack Overflow/Underflow Reset Enable bit->Stack Overflow or Underflow will cause a reset
// CONFIG3
#pragma config WDTCPS = WDTCPS_31    // WDT Period Select bits->Divider ratio 1:65536; software control of WDTPS
#pragma config WDTE = OFF    // WDT operating mode->WDT Disabled, SWDTEN is ignored
#pragma config WDTCWS = WDTCWS_7    // WDT Window Select bits->window always open (100%); software control; keyed access not required
#pragma config WDTCCS = SC    // WDT input clock selector->Software Control
// CONFIG4
#pragma config BBSIZE = BB512    // ->512 words boot block size
#pragma config BBEN = OFF    // ->Boot Block disabled
#pragma config SAFEN = OFF    // ->SAF disabled
#pragma config WRTAPP = OFF    // ->Applic
#pragma congig WRTB = OFF
#pragma config WRTC = OFF
#pragma config WRTSAF = OFF
#pragma config LVP = ON
//CONFIG5
#pragma config CP = OFF
同时,时钟配置里选择为辅助振荡器,
    OSCCON1 = 0x40; //选择新的时钟为SOSC
    OSCCON2 = 0X60;
    OSCCON3 = 0x00;
    OSCEN = 0x00;
    OSCFRQ = 0x00;
    // HFTUN 0;
    OSCTUNE = 0x00;
    OSCCON3bits.SOSCPWR =1;//辅助振荡器工作在高功耗模式下
这样配置后晶体无法起振,请问用辅助振荡器还有哪里需要的配置?
用MCC配置试了一下,配置字FEXTOSC 仍然为 LP,但OSCCON1为0x70,即选择了EXTOSC,EXTOSC 按照 FEXTOSC 配置字,这样晶体就可以起振了,但辅助振荡器起振完成标志SOR并没有置1,反倒是外部晶体起振完成标志EXTOR被置1。有哪位大神帮忙讲解一下这究竟是为什么,完全搞不懂了  发表于 2021-5-10 20:09
 楼主| 永远不停 发表于 2021-5-10 20:09 | 显示全部楼层
用MCC配置试了一下,配置字FEXTOSC 仍然为 LP,但OSCCON1为0x70,即选择了EXTOSC。
