[应用相关] 串口收发乱码解决方案
616|3
 楼主| wakayi 发表于 2021-6-4 10:08 | 显示全部楼层 |阅读模式
在使用基于stm32f103rct6芯片的板子实现485收发时,发现可以发送也可以接收,但是收发的数据都是乱码。
第一步,因为可收可发,引脚肯定没问题;
第二步检查波特率,检查后发现波特率也没问题;
第三步检查时钟配置,仿佛也是没问题。。。
此时已经郁闷了。
二话不说,先上485配置代码:
static void uart1_config(uint32_t baud_rate)
    USART_InitTypeDef USART_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
         * UART1_TX  PA9
         * UART1_RX  PA10
         * RS485EN   PA11
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    USART_InitStructure.USART_BaudRate = baud_rate;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_Init(USART1, &USART_InitStructure);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    USART_Cmd(USART1, ENABLE);
    nvic_set(USART1_IRQn, IRQ_PRIO_UART1);
    // 初始化默认接收模式
    UART1_RX_MODE;
void uart_config(void)
    uart1_config(19200);
 楼主| wakayi 发表于 2021-6-4 10:09 | 显示全部楼层
再看时钟的配置:
  * @brief  Configures the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers.
  * @param  None
  * @retval None
static void SetSysClock(void)
#ifdef SYSCLK_FREQ_HSE
  SetSysClockToHSE();
#elif defined SYSCLK_FREQ_24MHz
  SetSysClockTo24();
#elif defined SYSCLK_FREQ_36MHz
  SetSysClockTo36();
#elif defined SYSCLK_FREQ_48MHz
  SetSysClockTo48();
#elif defined SYSCLK_FREQ_56MHz
  SetSysClockTo56();
#elif defined SYSCLK_FREQ_72MHz
  SetSysClockTo72();
#endif
/* If none of the define above is enabled, the HSI is used as System clock
    source (default after reset) */
  * @brief  Sets System clock frequency to 72MHz and configure HCLK, PCLK2
  *         and PCLK1 prescalers.
  * @NOTE   This function should be used only after reset.
  * @param  None
  * @retval None
static void SetSysClockTo72(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Enable Prefetch Buffer */
    FLASH->ACR |= FLASH_ACR_PRFTBE;
    /* Flash 2 wait state */
    FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    /* PCLK1 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
#ifdef STM32F10X_CL
    /* Configure PLLs ------------------------------------------------------*/
    /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
    /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
    RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
                              RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
    RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
                             RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
    /* Enable PLL2 */
    RCC->CR |= RCC_CR_PLL2ON;
    /* Wait till PLL2 is ready */
    while((RCC->CR & RCC_CR_PLL2RDY) == 0)
    /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
    RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
                            RCC_CFGR_PLLMULL9);
#else
    /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
                                        RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
#endif /* STM32F10X_CL */
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
                                  RCC->CR |= (uint32_t)0x00000001;
                // select HSI as PLL source (8M/2)
                RCC->CFGR |= (uint32_t)RCC_CFGR_PLLSRC_HSI_Div2;
                //PLLCLK=8/2*9=36M
                RCC->CFGR |= (uint32_t)RCC_CFGR_PLLMULL9;
                 /* HCLK = SYSCLK/1      */
                /* Enable PLL */
                                                SystemCoreClock = 36000000;
#endif
看起来没有问题吧。。。后来发现这个板子使用的是外部晶振,测试后还是不行;最后检查了一下stm32f10x.h文件,终于发现问题所在了:
板子所用的外部晶振是12M,但是固件库里默认是8M,忘记修改这里了,代码如下:
* @brief In the following line adjust the value of External High Speed oscillator (HSE)
   used in your application
   Tip: To avoid modifying this file each time you need to use different HSE, you
        can define the HSE value in your toolchain compiler preprocessor.
#if !defined  HSE_VALUE
#ifdef STM32F10X_CL
  #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
#else
  #define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
将“#define HSE_VALUE ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */”的8000000改为12000000,代码如下:
#ifdef STM32F10X_CL
#else
  #define HSE_VALUE    ((uint32_t)12000000) /*!< Value of the External oscillator in Hz */
保存,编译,执行,发现收发数据正常了。
 楼主| wakayi 发表于 2021-6-4 10:10 | 显示全部楼层
总结
在使用新的板子开发项目的时候,首先一定确认好板子是用内部晶振还是外部晶振?使用外部晶振的话,是多大的外部晶振?然后修改system_stm32f10x.c和stm32f10x.h文件,特别是要记得在stm32f10x.h中修改外部晶振的宏定义HSE_VALUE,使其等于外部晶振,这一点很容易忽略。
