华大HC32L130 485接收影响AD稳定
11935|8
 楼主| 流浪的屁屁 发表于 2021-6-29 09:53 | 显示全部楼层 |阅读模式
HC, AD, dc, ADC, TI
问题现象:AD值会波动,波动值在0~80左右,具体如下,请教大佬有遇到过吗?
尝试分析测试试验(采用官方库例程,配置串口跟AD部分):
1.485EN脚配置为高电平,AD就稳定,再次配置成低电平,AD波动;
2.485EN脚配置到PC13或PD7,初始化配置输出低电平,AD波动;
3.485EN脚加硬件光耦隔离电路,仍旧配置输出低电平,AD波动;
4.485EN脚悬空,AD稳定;
5.485EN脚配置输出低电平,485上位机不接,AD稳定;
6.将串口(PA2/PA3)改为配置到串口0(PA9/PA10),PA2/PA3默认不配置,AD波动,PA2/PA3配置成输出,AD稳定;
7.尝试将AD优先级配置1,串口优先级默认3,AD也还是波动;
综上,初步判定是485接收导致AD波动,与优先级无关,但是,该测试板是在原先ST板上换上华大芯片改的,ST量产的没发现这个问题。
/** \file main.c
** A detailed description is available at
** @link Sample Group Some description @endlink
**   - 2017-05-28 LiuHL    First Version
* Include files
#include "adc.h"
#include "gpio.h"
#include "bgr.h"
#include "uart.h"
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
volatile uint32_t u32AdcRestult0;
volatile uint32_t u32AdcRestult0_1;
volatile uint32_t u32AdcRestult2;
volatile uint32_t u32AdcRestult5;
* Local type definitions ('typedef')
volatile static uint8_t u8RxData;
volatile static uint8_t u8TxCnt=0;
volatile static uint8_t u8RxCnt=0;
* Local function prototypes ('static')
* Local variable definitions ('static')                                      *
* Function implementation - global ('extern') and local ('static')
void App_AdcPortInit(void);
void App_AdcInit(void);
void App_AdcJqrCfg(void);
void App_UartCfg(void);
void App_PortInit(void);
** \brief  Main function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
      //串口引脚配置
    App_PortInit();
    //串口配置
    App_UartCfg();
    ///< ADC 采样端口初始化
    App_AdcPortInit();
    ///< ADC模块初始化
    App_AdcInit();
    ///< ADC插队扫描功能配置
    App_AdcJqrCfg();
    while(1)
        delay1ms(100);
          Adc_JQR_Start();
///< ADC中断服务函数
void Adc_IRQHandler(void)
    if(TRUE == Adc_GetIrqStatus(AdcMskIrqJqr))
        Adc_ClrIrqStatus(AdcMskIrqJqr);
        u32AdcRestult0   = Adc_GetJqrResult(AdcJQRCH0MUX);
        u32AdcRestult2   = Adc_GetJqrResult(AdcJQRCH1MUX);
        u32AdcRestult5   = Adc_GetJqrResult(AdcJQRCH2MUX);
        u32AdcRestult0_1 = Adc_GetJqrResult(AdcJQRCH3MUX);
        Adc_JQR_Stop();
///< ADC采样端口初始化
    ///< 开启ADC/BGR GPIO外设时钟
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
    Gpio_SetAnalogMode(GpioPortA, GpioPin7);        //PA00 (AIN0)
    Gpio_SetAnalogMode(GpioPortB, GpioPin0);        //PA02 (AIN2)
    Gpio_SetAnalogMode(GpioPortB, GpioPin1);        //PA05 (AIN5)
///< ADC模块初始化
    stc_adc_cfg_t              stcAdcCfg;
    DDL_ZERO_STRUCT(stcAdcCfg);
    Sysctrl_SetPeripheralGate(SysctrlPeripheralAdcBgr, TRUE);
    Bgr_BgrEnable();        ///< 开启BGR
    ///< ADC 初始化配置
    stcAdcCfg.enAdcMode         = AdcScanMode;              ///<采样模式-扫描
    stcAdcCfg.enAdcClkDiv       = AdcMskClkDiv8;            ///<采样分频-1
    stcAdcCfg.enAdcSampCycleSel = AdcMskSampCycle12Clk;      ///<采样周期数-8
    stcAdcCfg.enAdcRefVolSel    = AdcMskRefVolSelAVDD;      ///<参考电压选择-VCC
    stcAdcCfg.enAdcOpBuf        = AdcMskBufDisable;         ///<OP BUF配置-关
    stcAdcCfg.enInRef           = AdcMskInRefDisable;       ///<内部参考电压使能-关
    stcAdcCfg.enAdcAlign        = AdcAlignRight;               ///<转换结果对齐方式-右
    Adc_Init(&stcAdcCfg);
///< ADC插队扫描功能配置
    stc_adc_jqr_cfg_t          stcAdcJqrCfg;
    DDL_ZERO_STRUCT(stcAdcJqrCfg);
    ///< 插队扫描模式功能及通道配置
    ///< 注意:扫描模式下,当配置转换次数为n时,转换通道的配置范围必须为[JQRCH(0)MUX,JQRCH(n-1)MUX]
    stcAdcJqrCfg.bJqrDmaTrig = FALSE;
    stcAdcJqrCfg.u8JqrCnt    = 4;
    Adc_JqrModeCfg(&stcAdcJqrCfg);
    Adc_CfgJqrChannel(AdcJQRCH0MUX, AdcExInputCH7);
    Adc_CfgJqrChannel(AdcJQRCH1MUX, AdcExInputCH8);
    Adc_CfgJqrChannel(AdcJQRCH2MUX, AdcExInputCH9);
    Adc_CfgJqrChannel(AdcJQRCH3MUX, AdcExInputCH7);
    ///< ADC 中断使能
    Adc_EnableIrq();
    EnableNvic(ADC_IRQn, IrqLevel1, TRUE);
    ///< 启动插队扫描采样
    Adc_JQR_Start();
//UART1中断函数
void Uart1_IRQHandler(void)
    if(Uart_GetStatus(M0P_UART1, UartRC))         //UART1数据接收
        Uart_ClrStatus(M0P_UART1, UartRC);        //清中断状态位
        u8RxData = Uart_ReceiveData(M0P_UART1);   //接收数据字节
        u8RxCnt++;
    if(Uart_GetStatus(M0P_UART1, UartTC))         //UART1数据发送
        Uart_ClrStatus(M0P_UART1, UartTC);        //清中断状态位
        u8TxCnt++;
//串口引脚配置
    stc_gpio_cfg_t stcGpioCfg;
    DDL_ZERO_STRUCT(stcGpioCfg);
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE); //使能GPIO模块时钟
    ///<TX
   stcGpioCfg.enDir = GpioDirOut;
    Gpio_Init(GpioPortA, GpioPin2, &stcGpioCfg);
    Gpio_SetAfMode(GpioPortA, GpioPin2, GpioAf1);          //配置PA02 端口为URART1_TX
    ///<RX
    stcGpioCfg.enDir = GpioDirIn;
    Gpio_Init(GpioPortA, GpioPin3, &stcGpioCfg);
    Gpio_SetAfMode(GpioPortA, GpioPin3, GpioAf1);          //配置PA03 端口为URART1_RX
        /// 485EN
                stcGpioCfg.enPu = GpioPuDisable;
                stcGpioCfg.enPd = GpioPuDisable;
          Gpio_Init(GpioPortA, GpioPin1, &stcGpioCfg);
            Gpio_ClrIO(GpioPortA, GpioPin1);
            //Gpio_SetIO(GpioPortA, GpioPin1);
//串口配置
    stc_uart_cfg_t    stcCfg;
    DDL_ZERO_STRUCT(stcCfg);
    ///< 开启外设时钟
    Sysctrl_SetPeripheralGate(SysctrlPeripheralUart1,TRUE);///<使能uart1模块时钟
    ///<UART Init
    stcCfg.enRunMode        = UartMskMode3;          ///<模式3
    stcCfg.enStopBit        = UartMsk1bit;           ///<1bit停止位
    stcCfg.enMmdorCk        = UartMskEven;           ///<偶检验
    stcCfg.stcBaud.u32Baud  = 9600;                  ///<波特率9600
    stcCfg.stcBaud.enClkDiv = UartMsk8Or16Div;       ///<通道采样分频配置
    stcCfg.stcBaud.u32Pclk  = Sysctrl_GetPClkFreq(); ///<获得外设时钟(PCLK)频率值
    Uart_Init(M0P_UART1, &stcCfg);                   ///<串口初始化
    ///<UART中断使能
    Uart_ClrStatus(M0P_UART1,UartRC);                ///<清接收请求
    Uart_ClrStatus(M0P_UART1,UartTC);                ///<清接收请求
    Uart_EnableIrq(M0P_UART1,UartRxIrq);             ///<使能串口接收中断
    Uart_EnableIrq(M0P_UART1,UartTxIrq);             ///<使能串口接收中断
    EnableNvic(UART1_IRQn, IrqLevel3, TRUE);       ///<系统中断使能
* EOF (not truncated)
cyclefly 发表于 2021-7-3 11:36 | 显示全部楼层
一般不会有影响的,
而且485的选择引脚, 说白了,只是一个IO电平。
想不到原因在哪里
ZYQFBW 发表于 2021-7-3 15:58 | 显示全部楼层
电源波动
daichaodai 发表于 2021-7-3 18:51 来自手机 | 显示全部楼层
485发送数据的时候有没有影响?
zheng79 发表于 2021-7-4 10:47 来自手机 | 显示全部楼层
485是5V供电的吧,输出给单片机的是5V信号,估计单片机那个脚是不可以输入5V电压的。
tail066 发表于 2021-7-15 13:56 | 显示全部楼层
楼主解决了么?
会是外部干扰么?
liangzhou1988 发表于 2021-7-15 14:07 | 显示全部楼层
检查485与华大L130的管脚连接,该连接管脚不能有高于MCU VCC的电平。否则会形成压差,影响MCU VCC的电源域导致ADC基准不稳定。这是MCU IO端口决定的,某些友商的IO端口不是这种结构确实不会有这种问题,无所谓优劣。@流浪的屁屁
wuha 发表于 2021-7-15 14:14 | 显示全部楼层
是不是485的电平高于单片机的电源了?华大单片机的IO输入电平最高不能超过VCC,否则直接影响ADC采样值。这个不如ST的好。ST的即使电源3.3V,但是很多引脚是兼容5V电平的。
 楼主| 流浪的屁屁 发表于 2021-7-28 09:13 | 显示全部楼层
是不是485的电平高于单片机的电源了?华大单片机的IO输入电平最高不能超过VCC,否则直接影响ADC采样值。这 ...
正如你所说,问题已解决,原因是HC的IO口最大电压只有VCC+0.3,而485是5V供电的
