[应用相关] STM32H750XBH6 - RT-Thread 开启RTC 与 Alarm组件
2086|29
 楼主| 八层楼 发表于 2021-7-3 09:28 | 显示全部楼层
static void rtc_alarm_second_start(void)
    if (p_alarm_sec != RT_NULL)
        rt_alarm_start(p_alarm_sec);
static void rtc_alarm_second_stop(void)
        rt_alarm_stop(p_alarm_sec);
static void rtc_alarm_second_delete(void)
        if (rt_alarm_delete(p_alarm_sec) == RT_EOK)
            p_alarm_sec = RT_NULL;
 楼主| 八层楼 发表于 2021-7-3 09:29 | 显示全部楼层
static void rtc_alarm_minute_create(void)
    static time_t now;
    static struct tm tm;
    if (p_alarm_min != RT_NULL)
        return;
    now = time(NULL) + 60;
#ifdef _WIN32
    _gmtime32_s(&tm, &now);
#else
    gmtime_r(&now, &tm);
#endif
    p_alarm_min = rtc_alarm_test_create(alarm_minute_cb, RT_ALARM_MINUTE, &tm);
 楼主| 八层楼 发表于 2021-7-3 09:30 | 显示全部楼层
static void rtc_alarm_minute_start(void)
        rt_alarm_start(p_alarm_min);
static void rtc_alarm_minute_stop(void)
        rt_alarm_stop(p_alarm_min);
static void rtc_alarm_minute_delete(void)
        if (rt_alarm_delete(p_alarm_min) == RT_EOK)
            p_alarm_min = RT_NULL;
 楼主| 八层楼 发表于 2021-7-3 09:31 | 显示全部楼层
static void rtc_alarm_hour_create(void)
    static time_t now;
    if (p_alarm_hour != RT_NULL)
        return;
    now = time(NULL) + 3600;
#ifdef _WIN32
#else
#endif
    p_alarm_hour = rtc_alarm_test_create(alarm_hour_cb, RT_ALARM_HOUR, &tm);
static void rtc_alarm_hour_start(void)
        rt_alarm_start(p_alarm_hour);
static void rtc_alarm_hour_stop(void)
        rt_alarm_stop(p_alarm_hour);
static void rtc_alarm_hour_delete(void)
        if (rt_alarm_delete(p_alarm_hour) == RT_EOK)
            p_alarm_hour = RT_NULL;
 楼主| 八层楼 发表于 2021-7-3 09:32 | 显示全部楼层
void rtc_alarm_start(int argc, char **argv)
    int index = 0;
    if (argc >= 2)
        index = atoi(argv[1]);
    switch(index)
        case 0:
            rtc_alarm_hour_start();
            break;
        case 1:
            rtc_alarm_minute_start();
            break;
        case 2:
            rtc_alarm_second_start();
            break;
        case 3:
            rtc_alarm_time_start();
            break;
        default:
            break;
 楼主| 八层楼 发表于 2021-7-3 09:33 | 显示全部楼层
void rtc_alarm_stop(int argc, char **argv)
    int index = 0;
    if (argc >= 2)
    switch(index)
        case 0:
            rtc_alarm_hour_stop();
            break;
        case 1:
            rtc_alarm_minute_stop();
            break;
        case 2:
            rtc_alarm_second_stop();
            break;
        case 3:
            rtc_alarm_time_stop();
            break;
        default:
            break;
 楼主| 八层楼 发表于 2021-7-3 09:34 | 显示全部楼层
void rtc_alarm_create(int argc, char **argv)
    int index = 0;
    if (argc >= 2)
    switch(index)
        case 0:
            rtc_alarm_hour_create();
            break;
        case 1:
            rtc_alarm_minute_create();
            break;
        case 2:
            rtc_alarm_second_create();
            break;
        case 3:
            rtc_alarm_time_create();
            break;
        default:
            break;
void rtc_alarm_delete(int argc, char **argv)
    int index = 0;
    if (argc >= 2)
    switch(index)
        case 0:
            rtc_alarm_hour_delete();
            break;
        case 1:
            rtc_alarm_minute_delete();
            break;
        case 2:
            rtc_alarm_second_delete();
            break;
        case 3:
            rtc_alarm_time_delete();
            break;
        default:
            break;
MSH_CMD_EXPORT(rtc_gettime, rtc get time);
MSH_CMD_EXPORT(rtc_alarm_create, rtc alarm_create);
MSH_CMD_EXPORT(rtc_alarm_delete, rtc alarm_delete);
MSH_CMD_EXPORT(rtc_alarm_start, rtc alarm_start);
MSH_CMD_EXPORT(rtc_alarm_stop, rtc alarm_stop);
#endif
 楼主| 八层楼 发表于 2021-7-3 09:35 | 显示全部楼层
总结
  • RT-Thread RTC alarm组件,配置起来,稍微有点麻烦。
  • Alarm闹钟功能,使能组件后,还是需要创建闹钟、开启闹钟、停止闹钟、删除闹钟业务代码的配合。
  • 多使用,多总结。
