调试运行时间偏长
2291|23
houcs|  楼主 | 2021-7-3 15:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
KIT3调试运行时间偏长
以5s延时为例,调试运行需要大概15s时间,烧录运行只需1.5s左右,
也就是说运行的指令时间有问题
llia| | 2021-7-3 15:31 | 只看该作者
程序
houcs|  楼主 | 2021-7-3 15:33 | 只看该作者
#include<xc.h>
// CONFIG1
#pragma config FOSC = XT        // Oscillator Selection (XT Oscillator, Crystal/resonator connected between OSC1 and OSC2 pins)
#pragma config WDTE = SWDTEN     // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE =  ON         // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN =   OFF      // Brown-out Reset Enable (Brown-out Reset enabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = ON        // Internal/External Switchover (Internal/External Switchover mode is enabled)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config VCAPEN = OFF     // Voltage Regulator Capacitor Enable bit (Vcap functionality is disabled on RA6.)
#pragma config PLLEN = ON       // PLL Enable (4x PLL enabled)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LPBOR = OFF      // Low Power Brown-Out Reset Enable Bit (Low power brown-out is disabled)
#pragma config LVP =  OFF         // Low-Voltage Programming Enable (Low-voltage programming enabled)
void delayms(unsigned int x)    //延时 x ms
    unsigned int i,j;
    for(i=x;i>0;i--)
        for(j=110;j>0;j--);
void main()
        TRISD=0x00;
while(1)
         LATD=0X00;
        delayms(5000);
        LATD=0XFF;
        delayms(5000);
zhenykun| | 2021-7-3 15:35 | 只看该作者
先不要怀疑KIT3,通常都是代码中有鬼
chuxh| | 2021-7-3 15:37 | 只看该作者
应该是配置字的问题
houcs|  楼主 | 2021-7-3 15:39 | 只看该作者
我认为是配置字的问题,器件我也更换了,结果相同
stly| | 2021-7-3 15:41 | 只看该作者
你这种delay时间很难精准的,不过Debug和Release为什么会差别这么大,确实很奇怪,
xxrs| | 2021-7-3 15:43 | 只看该作者
你可以考虑用Timer做delay
jiajs| | 2021-7-3 15:45 | 只看该作者
你的watchdog enable了,但是没有看到喂狗。所以我怀疑贴出的代码段,应该是截取出来的代码。
chenjun89| | 2021-7-3 16:55 | 只看该作者
你这个也偏差太大了吧,程序设置问题。
xxmmi| | 2021-7-3 17:14 | 只看该作者
你代码中有中断吗,中断会影响你的通过指令来delay的时长。
wyjie| | 2021-7-3 17:16 | 只看该作者
你的程序Release模式有没有使用优化,如果有的话,可以试试关掉优化,重新编译烧写,再看效果如何
houcs|  楼主 | 2021-7-3 17:18 | 只看该作者
看门狗配置位设置为01(即SWDTEN模式),这是看门狗使能由WDTCONbits.SWDTEN控制。
supernan| | 2021-7-3 17:20 | 只看该作者
打开了吗
houcs|  楼主 | 2021-7-3 17:22 | 只看该作者
本程序阶段我并未打开此位(并暂停查看过次位为0,即为禁止)
juventus9554| | 2021-7-3 17:24 | 只看该作者
用定时器timer0做过延时吗
houcs|  楼主 | 2021-7-3 17:25 | 只看该作者
嗯,同样的情况,也就是不是延时函数的问题,而是程序运行指令的时间并不是4M晶振下1us的时间,这是我不懂的!!!
zhanghqi| | 2021-7-3 17:28 | 只看该作者
zwll| | 2021-7-3 17:32 | 只看该作者
有没有现成的驱动安装,支持PRO-06的呢?
wangpe| | 2021-7-3 17:34 | 只看该作者
