[DemoCode下载]
用NUC开发键盘鼠标示例
1892|4
huahuagg|  楼主 | 2021-7-10 18:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
EC_NUC122_USBD_HID_KB_MS_MMKey_LEDCtrl_V1.00.zip (3.42 MB)
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* @brief
*           This sample code supports to use GPIO to simulate key input.
* @note
* Copyright (C) 2019 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC122.h"
#include "hid.h"
#include "string.h"
#include "usbd_user.h"
extern uint8_t volatile g_u8Suspend;
uint8_t volatile g_u8EP2Ready = 0;
uint8_t volatile g_u8EP3Ready = 0;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock */
    CLK_SetCoreClock(48000000);
    /* Enable module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(USBD_MODULE);
    /* Select module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(USBD_MODULE, 0, CLK_CLKDIV_USB(2));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD);
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS->IPRSTC2 |=  SYS_IPRSTC2_UART0_RST_Msk;
    SYS->IPRSTC2 &= ~SYS_IPRSTC2_UART0_RST_Msk;
    /* Configure UART0 and set UART0 Baudrate */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
    UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
void PowerDown()
    printf("Enter power down ...\n");
    SYS_UnlockReg();
    /* Wakeup Enable */
    USBD->INTEN |= USBD_INTEN_WAKEUP_EN_Msk;
    /* To check if all the debug messages are finished */
    UART_WAIT_TX_EMPTY(UART0);
    CLK_PowerDown();
    if(g_usbd_RemoteWakeupEn && g_u8Suspend)
        /* Enable PHY before sending Resume('K') state */
        USBD->ATTR |= USBD_ATTR_PHY_EN_Msk;
        /* Keep remote wakeup for 1 ms */
        USBD->ATTR |= USBD_ATTR_RWAKEUP_Msk;
        CLK_SysTickDelay(1000); /* Delay 1ms */
        USBD->ATTR ^= USBD_ATTR_RWAKEUP_Msk;
        printf("Remote Wakeup!!\n");
    printf("device wakeup!\n");
void GPCD_IRQHandler(void)
    /* To check if PD1 or PD2 interrupt occurred */
    if(GPIO_GET_INT_FLAG(PD, BIT1))
        GPIO_CLR_INT_FLAG(PD, BIT1);
        printf("PD.1 INT occurred.\n");
    else if(GPIO_GET_INT_FLAG(PD, BIT2))
        GPIO_CLR_INT_FLAG(PD, BIT2);
        printf("PD.2 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PA and PB interrupts */
        PC->ISRC = PC->ISRC;
        PD->ISRC = PD->ISRC;
        printf("Un-expected interrupts.\n");
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    SYS_Init();
    UART0_Init();
    printf("\n");
    printf("+-------------------------------------------------------+\n");
    printf("|              NuMicro USB HID Sample Code              |\n");
    printf("Use GPD1 to move mouse pointer right when GPD1 = 0\n");
    printf("Use GPD2 to report a key 'a' when GPD2 = 0\n");
    printf("Use GPD3 to report key - Volume + when GPD3 = 0\n");
    printf("Use GPD4 to report key - Volume - when GPD4 = 0\n");
    /* Set GPD5 output */
    GPIO_SetMode(PD, BIT5, GPIO_PMD_OUTPUT);
    /* Enable PD Interrupt for Remote Wakeup */
    GPIO_EnableInt(PD, 1, GPIO_INT_FALLING);
    GPIO_EnableInt(PD, 2, GPIO_INT_FALLING);
    NVIC_EnableIRQ(GPCD_IRQn);
    USBD_User_Open(&gsUserInfo, HID_ClassRequest, NULL);
    /* Endpoint configuration */
    HID_Init();
    USBD_Start();
    NVIC_EnableIRQ(USBD_IRQn);
    /* start to IN data */
    g_u8EP2Ready = 1;
    g_u8EP3Ready = 1;
    while(1)
        HID_UpdateKbData();
        HID_UpdateMsData();
        /* Enter power down when USB suspend */
        if(g_u8Suspend)
            PowerDown();
        if(memcmp(SetReport, PreSetReport, 2))
            if(SetReport[1] &  0x2)
                PD5 = 1;    /* Turn On CapsLock LED */
            else
                PD5 = 0;    /* Turn Off CapsLock LED */
            memcpy(PreSetReport, SetReport, 2);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
huahuagg|  楼主 | 2021-7-10 21:57 | 只看该作者
学习一下,以后做个高级的键盘。
fuqinyyy| | 2021-7-11 09:02 | 只看该作者
可以做个键盘模拟游戏
twjiang| | 2021-7-12 10:01 | 只看该作者
想开发  USB-UVC 的摄像头 streaming 吗?
