[STM32F4] 设置到外部SDRAM
2528|13
 楼主| lizye 发表于 2021-8-8 22:45 | 显示全部楼层 |阅读模式
在 STM32F429 上,IAR 中如何将堆(HEAP)设置到外部SDRAM?
zhenykun 发表于 2021-8-8 22:48 | 显示全部楼层
什么意思?不是很明白你说的什么,能再解释一下这个现象吗
 楼主| lizye 发表于 2021-8-8 22:51 | 显示全部楼层
搜索网上资料,对 icf 进行了调整,编译可以通过,但实际运行时死机,不知道哪位大师成功设置过
下面是我设置的icf内容:
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Specials-*/
define symbol __ICFEDIT_intvec_start__ = 0x08000000;
/*-Memory Regions-*/
define symbol __ICFEDIT_region_ROM_start__    = 0x08000000;
define symbol __ICFEDIT_region_ROM_end__      = 0x080FFFFF;
define symbol __ICFEDIT_region_RAM_start__    = 0x20000000;
define symbol __ICFEDIT_region_RAM_end__      = 0x2003ffff;
define symbol __ICFEDIT_region_RAM1_start__   = 0xD0700000;
define symbol __ICFEDIT_region_RAM1_end__     = 0xD07fffff;
define symbol __ICFEDIT_region_CCMRAM_start__ = 0x10000000;
define symbol __ICFEDIT_region_CCMRAM_end__   = 0x1000FFFF;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = 0x1000;
define symbol __ICFEDIT_size_heap__   = 0x80000;
/**** End of ICF editor section. ###ICF###*/
define memory mem with size = 4G;
define region ROM_region      = mem:[from __ICFEDIT_region_ROM_start__   to __ICFEDIT_region_ROM_end__];
define region RAM_region      = mem:[from __ICFEDIT_region_RAM_start__   to __ICFEDIT_region_RAM_end__] | mem:[from __ICFEDIT_region_RAM1_start__   to __ICFEDIT_region_RAM1_end__];
define region CCMRAM_region   = mem:[from __ICFEDIT_region_CCMRAM_start__   to __ICFEDIT_region_CCMRAM_end__];
define block CSTACK    with alignment = 8, size = __ICFEDIT_size_cstack__   { };
define block HEAP      with alignment = 8, size = __ICFEDIT_size_heap__     { };
initialize by copy { readwrite };
do not initialize  { section .noinit };
place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };
place at address mem:__ICFEDIT_region_RAM_start__ { readwrite section .data };
place at address mem:__ICFEDIT_region_RAM1_start__ { readwrite section .bss };
place in ROM_region   { readonly };
place in RAM_region   { readwrite, block CSTACK, block HEAP };
 楼主| lizye 发表于 2021-8-8 22:54 | 显示全部楼层
SDRAM在RAM1,首地址为 0xD0000000, 大小为 0x800000, 我想将 HEAP 设置到 0xD0700000 ~ 0xD07FFFFF,并未超过范围
llljh 发表于 2021-8-8 22:59 | 显示全部楼层
不是很了解
ousj 发表于 2021-8-8 23:02 | 显示全部楼层
icf文件是干嘛用的啊
supernan 发表于 2021-8-8 23:04 | 显示全部楼层
不知道怎么做
chenjunt 发表于 2021-8-8 23:06 | 显示全部楼层
不太了解这个文件
 楼主| lizye 发表于 2021-8-8 23:08 | 显示全部楼层
唉,还是没有什么结果,算了,多谢大家啦
huquanz711 发表于 2021-8-9 08:19 来自手机 | 显示全部楼层
需要更改链接文件,将RAM地址映射到外部SDRAM。
磨砂 发表于 2021-9-8 07:54 | 显示全部楼层
链接文件是哪个文件啊
八层楼 发表于 2021-9-8 10:24 | 显示全部楼层
如何更改链接文件呢
香水城 发表于 2021-9-8 16:12 | 显示全部楼层
除了链接文件配置正确外,你还得保证使用它时 SDRAM已经初始化好了。
一般在进启动文件后就进行相应初始化。
一般在进启动文件后就进行相应初始化。
