[STM32F4] STM32F407查看时序
1290|1
 楼主| kxsi 发表于 2021-8-9 13:49 | 显示全部楼层 |阅读模式
void main(void)
        RCC_ClocksTypeDef    get_rcc_clock;   //结构体
        RCC_GetClocksFreq(&get_rcc_clock);    //获取时钟信息
        while(1)
STM32F407自带结构体
stm32f4xx_rcc.h
/* Exported types ------------------------------------------------------------*/
typedef struct
  uint32_t SYSCLK_Frequency; /*!<  SYSCLK clock frequency expressed in Hz */
  uint32_t HCLK_Frequency;   /*!<  HCLK clock frequency expressed in Hz   */
  uint32_t PCLK1_Frequency;  /*!<  PCLK1 clock frequency expressed in Hz  */
  uint32_t PCLK2_Frequency;  /*!<  PCLK2 clock frequency expressed in Hz  */
}RCC_ClocksTypeDef;
stm32f4xx_rcc.c
  * @brief  Returns the frequencies of different on chip clocks; SYSCLK, HCLK,
  *         PCLK1 and PCLK2.
  * @NOTE   The system frequency computed by this function is not the real
  *         frequency in the chip. It is calculated based on the predefined
  *         constant and the selected clock source:
  * @note     If SYSCLK source is HSI, function returns values based on HSI_VALUE(*)
  * @note     If SYSCLK source is HSE, function returns values based on HSE_VALUE(**)
  * @note     If SYSCLK source is PLL, function returns values based on HSE_VALUE(**)
  *           or HSI_VALUE(*) multiplied/divided by the PLL factors.
  * @note     (*) HSI_VALUE is a constant defined in stm32f4xx.h file (default value
  *               16 MHz) but the real value may vary depending on the variations
  *               in voltage and temperature.
  * @note     (**) HSE_VALUE is a constant defined in stm32f4xx.h file (default value
  *                25 MHz), user has to ensure that HSE_VALUE is same as the real
  *                frequency of the crystal used. Otherwise, this function may
  *                have wrong result.
  * @note   The result of this function could be not correct when using fractional
  *         value for HSE crystal.
  * @param  RCC_Clocks: pointer to a RCC_ClocksTypeDef structure which will hold
  *          the clocks frequencies.
  * @note   This function can be used by the user application to compute the
  *         baudrate for the communication peripherals or configure other parameters.
  * @note   Each time SYSCLK, HCLK, PCLK1 and/or PCLK2 clock changes, this function
  *         must be called to update the structure's field. Otherwise, any
  *         configuration based on this function will be incorrect.
  * @retval None
void RCC_GetClocksFreq(RCC_ClocksTypeDef* RCC_Clocks)
  uint32_t tmp = 0, presc = 0, pllvco = 0, pllp = 2, pllsource = 0, pllm = 2;
  /* Get SYSCLK source -------------------------------------------------------*/
  tmp = RCC->CFGR & RCC_CFGR_SWS;
  switch (tmp)
    case 0x00:  /* HSI used as system clock source */
      RCC_Clocks->SYSCLK_Frequency = HSI_VALUE;
      break;
    case 0x04:  /* HSE used as system clock  source */
      RCC_Clocks->SYSCLK_Frequency = HSE_VALUE;
      break;
    case 0x08:  /* PLL used as system clock  source */
      /* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLLM) * PLLN
         SYSCLK = PLL_VCO / PLLP
      pllsource = (RCC->PLLCFGR & RCC_PLLCFGR_PLLSRC) >> 22;
      pllm = RCC->PLLCFGR & RCC_PLLCFGR_PLLM;
      if (pllsource != 0)
        /* HSE used as PLL clock source */
        pllvco = (HSE_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> 6);
      else
        /* HSI used as PLL clock source */
        pllvco = (HSI_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> 6);
      pllp = (((RCC->PLLCFGR & RCC_PLLCFGR_PLLP) >>16) + 1 ) *2;
      RCC_Clocks->SYSCLK_Frequency = pllvco/pllp;
      break;
    default:
      break;
  /* Compute HCLK, PCLK1 and PCLK2 clocks frequencies ------------------------*/
  /* Get HCLK prescaler */
  tmp = RCC->CFGR & RCC_CFGR_HPRE;
  tmp = tmp >> 4;
  presc = APBAHBPrescTable[tmp];
  /* HCLK clock frequency */
  RCC_Clocks->HCLK_Frequency = RCC_Clocks->SYSCLK_Frequency >> presc;
  /* Get PCLK1 prescaler */
  tmp = RCC->CFGR & RCC_CFGR_PPRE1;
  tmp = tmp >> 10;
  /* PCLK1 clock frequency */
  RCC_Clocks->PCLK1_Frequency = RCC_Clocks->HCLK_Frequency >> presc;
  /* Get PCLK2 prescaler */
  tmp = RCC->CFGR & RCC_CFGR_PPRE2;
  tmp = tmp >> 13;
  /* PCLK2 clock frequency */
  RCC_Clocks->PCLK2_Frequency = RCC_Clocks->HCLK_Frequency >> presc;
 楼主| kxsi 发表于 2021-8-9 13:50 | 显示全部楼层
中文参考手册
watermark,type_ZmFuZ3poZW5naGVpdGk,shadow_10,text_aHR0cHM6Ly9ibG9nLmNzZG4ubmV0L3Nnamlhamlh,size_16,color_FFFFFF,t_70#pic_center.jpg
英文数据手册 watermark,type_ZmFuZ3poZW5naGVpdGk,shadow_10,text_aHR0cHM6Ly9ibG9nLmNzZG4ubmV0L3Nnamlhamlh,size_16,color_FFFFFF,t_70#pic_center.jpg
STM32CubeMX
