Dspic33EP512*写flash的问题
1864|0
 楼主| elephant00 发表于 2021-8-19 10:12 | 显示全部楼层 |阅读模式
用的是Dspic33ep512GM310,把一些参数写在flash里面保存,写的地址是0x52400,在擦除和写之后,Usart中断就停止工作了,是不是我的擦除函数和写函数有问题,熟悉的帮我看下
uint8 PageErase( uint32 flashAddress )
    NVMADR = ( flashAddress & 0xffff );
    NVMADRU = ( (flashAddress >> 16) & 0xffff );
    while(NVMCONbits.WR);
    NVMCON = 0x4003;
    __builtin_disi( 6);
    __builtin_write_NVM();
    Nop();
    Nop();
    Nop();
    Nop();
    NVMCONbits.WREN=0;
    Nop();
    if( (NVMCONbits.WRERR == 1) || (NVMCONbits.URERR == 1) )
        return ( WRERR_OR_UERR_ERROR );
    else
        return ( NO_ERROR );
uint8  WordWrite( uint32 flashAddress, uint16 ramBuffer1,uint16 ramBuffer2)
    // Set up the NVMADR registers to the starting address of the page
    NVMADR = ( flashAddress & 0xFFFF );
    NVMADRU = ( (flashAddress >> 16) & 0xFFFF );
    NVMCON = 0x4001;
    TBLPAG=0xfa;
    __builtin_tblwtl(0x0000,ramBuffer1);//(( flashAddress & 0xFFFF ),ramBuffer);
    __builtin_tblwth(0x0001,0x00);//(( flashAddress & 0xFFFF )+1,0x00);
    __builtin_tblwtl(0x0002,ramBuffer2);
    __builtin_tblwth(0x0003,0x00);
    __builtin_disi( 6);
    else
